E85 injector sizing
Old May 27, 2010 | 04:56 PM
racer59's Avatar
racer59
Default E85 injector sizing
Hi i am about start a new engine build a vq35 hr.
Looking to make around 750 crank hp on e85 does any one have experience
with injector sizing and injectors to make this power?
Old May 27, 2010 | 05:02 PM
Blackbird CPV35's Avatar
Blackbird CPV35
You will be maxed out at 650ish whp with 1200cc injectors. I am getting a set of 2200cc injectors now. If you don't plan on going any higher than 700 whp then 1600s will be fine
Old May 27, 2010 | 05:11 PM
03threefiftyz's Avatar
03threefiftyz
Blackbird....what are you using for pumps?
Old May 27, 2010 | 05:14 PM
IslandZavage's Avatar
IslandZavage
what brand injectors?
Old May 27, 2010 | 05:31 PM
str8dum1's Avatar
str8dum1
hands down the best big injector out there
http://www.injectordynamics.com/ID2000.html
plus they are already denso, so they just drop in.
be interested to know what you IPW is at idle with your 1200s
Mine idles at 12.5 with an IPW of between 0.018 and .13 (-10 to -9psi at ~800 rpm).
Old May 27, 2010 | 06:14 PM
Blackbird CPV35
Modified CJM Twin pump setup
and im either going with the FIC 2150's of ID 2000's. So far it looks like the ID2000's are going to be the winner
Old May 27, 2010 | 06:19 PM
Blackbird CPV35
and im using Precision 1200s. They may be on sale very soon if anyone is interested
Old May 27, 2010 | 06:42 PM
Elperuano's Avatar
Elperuano
U guys must literally see the fuel gauge drop everytime u hit WOT....
Old May 27, 2010 | 07:30 PM
rcdash's Avatar
rcdash
Which means not even 550 whp with my 1000 cc injectors.
Old May 27, 2010 | 08:27 PM
Blackbird CPV35
I can get about 200 miles to a tank with highway driving and some WOT
Old May 27, 2010 | 08:57 PM
IslandZavage
modified how?
Old May 27, 2010 | 09:11 PM
Blackbird CPV35
Typically a walbro has a pressure bypass at like 75 psi or so, the Evo guys have been modifying the bypass so it can hold higher pressures than 75.
http://www.driven2modify.com/showthread.php?t=11702
Old May 28, 2010 | 05:14 AM
str8dum1's Avatar
str8dum1
interesting. I had no problems holding FP at ~85psi (47 base +38psi boost) Wonder what Charles says about that.
Old May 28, 2010 | 06:42 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
The Precision 1200s work great, very nice spray pattern at low pulse widths. On E85 and base pressure of 48 psi I have made 1000 RWHP on a 6 cyl. At a normal fuel pressure of 43ish you can get 850 RWHP safely, 900 if you really push them. The car will idle like stock too!!
And the best part is that they are not very expensive... I think like $73 each.
Old May 28, 2010 | 06:44 AM
SoundPerformance
Sound Performance
I have never seen this. We have run 55 psi of boost on supras with FP hitting 95 with no issues using 3 walbros.
Old May 28, 2010 | 06:50 AM
IslandZavage
are the precisions drop-in plug-n-play?
Old May 28, 2010 | 06:52 AM
SoundPerformance
Sound Performance
I put them in the stock rails all the time, different electrical connectors though (standard injector type). They are a bit taller than the stock injectors so you can either grind the manifold to clear them, or use the lower manifold spacer that injected sells, or get aftermarket rails. I always use the spacer.
Old May 28, 2010 | 06:57 AM
IslandZavage
i run the CJM fuel rails.
Old May 28, 2010 | 07:25 AM
thom000001's Avatar
thom000001
The precision 1200's are what Larry just dropped in my motor this week
Tom
Old May 28, 2010 | 08:56 AM
Blackbird CPV35
Tom
Fool! you should have went bigger!!
