Vortech Cog Belt Messed up Cam Wire....
Old Jun 1, 2010 | 07:05 PM
350Z400rwhp's Avatar
350Z400rwhp
Default Vortech Cog Belt Messed up Cam Wire....
This is a continuation from a previous thread I started. A few weeks back I had a failure of my cog belt and it took out my "cam wire" and blew my ecu fuse. Tonight I replaced the plug and re-connected it to the sensor. My car idles rough when this wire is connected and idles smooth when it is disconnected. I went to Autozone to clear codes and they immediately came back when I restarted my engine (I believe it was a multiple cylinder misfire and a air/fuel code). Before I left I unplugged the connector and the engine runs smooth but of course my service light stays on. So now my situation is, I have repaired this damaged wire and when it's plugged in the car runs rough and when it is unplugged it runs smooth. Of course I need this wire to be plugged in so just leaving it unplugged is not an option. Sound like ecu damage? If I replace my ecu, will I need a re-tune? Could this cam sensor (or whatever it's called) be damaged? I have a friend who is a Nissan mechanic who I will hopefully talk with tomorrow but just trying to get some ideas in the meantime. This just makes me want to park this car in my garage and say Fu@k it!
Attached Thumbnails Vortech Cog Belt Messed up Cam Wire....-broken-belt-and-cam-sensor-plug.jpg
Old Jun 1, 2010 | 07:08 PM
0jiggy0's Avatar
0jiggy0
If the fuse blew that means the wire grounded as it was cut. Its possible the sensor was taken out in that time.
Old Jun 1, 2010 | 08:02 PM
350Z400rwhp
I just pulled my computer out, loosened a few screws and peeked inside. There doesn't seem to be any physical damage nor any burnt electrical smell but I guess this still doesn't rule out the ecu completely. I will know more tomorrow after I talk with my friend but it does seem that the car runs fine until I plug in the sensor. I guess if the wire did ground out it could of taken out the sensor before it tripped the fuse. Not sure if this is good news or not.
Old Jun 2, 2010 | 05:12 AM
tylerxfire's Avatar
tylerxfire
good luck, off topic but i just changed my cog belt yesterday, how tight is ur belt?i feel my belt is much tighter than it was when i did the original install..
Old Jun 2, 2010 | 05:42 AM
str8dum1's Avatar
str8dum1
well u already know what I had to do.. But you should be getting the IVT solenoid code. If you are not getting that, then something is wrong with your car.
you might need a touchup tune, but thats nothing you cant do yourself.
Old Jun 2, 2010 | 06:03 AM
_ink's Avatar
_ink
Might seem obvious, but did you:
a) replace the fuse
b) reset the ecu
Old Jun 2, 2010 | 07:57 AM
rx7/350z's Avatar
rx7/350z
that fried my ecu and split second box when it happened to me. the ecu fuse is on the power supply to the ecu, their is no fuse on the cam sensor circuit. if it tripped the ecu fuse the short ran through the ecu to get there. mine wasnt burnt just stuck in a limp mode
Old Jun 2, 2010 | 07:58 AM
rx7/350z's Avatar
rx7/350z
make a steel plate to cover those wires for next time
Old Jun 2, 2010 | 02:18 PM
350Z400rwhp
I'm going to take my car to Autozone today and try looking at the codes again and write them down. I guess I will be looking for the IVT solenoid like Str8t said. Wouldn't my car run poorly if my ecu or my utec was fried (it isn't in any kind of limp mode)? It only runs a little rough when I hook up the sensor. My next step is to replace this cam sensor, any chance anyone has a spare set of heads they want to part out? I guess once I replace that it will rule out everything and I will need to address the ecu. Off to Autozone and I will report the exact codes.
Old Jun 2, 2010 | 02:23 PM
rx7/350z's Avatar
rx7/350z
good luck I hope for you thats all it is, but how it was explained to me when it happened to my car when those 2 wires touch it grounds out the ecu. having the fuse blow is a bad sign.
i only noticed that something was wrong about 20 minutes after driving the car. the ecu lost control of the cam timing and it felt like it was slightly missing around 4k-4.5k rpm.
Old Jun 2, 2010 | 02:31 PM
350Z400rwhp
I'm not doubting you, just trying to rule out any other possibilities before I replace the ecu as that is the most expensive.
Old Jun 2, 2010 | 04:07 PM
350Z400rwhp
Just got back from Autozone. The code it is giving is P1136 (Manufacturer Control Fuel Air Metering). Again it runs and idles fine until I hook up this cam sensor. Thinking my next step should be to open up my utec and look for any damage to the circuit board. If that looks good then I am going to replace this sensor and if it is still a problem I really don't know, guess I will have to replace my utec/ecu...... Any other thoughts?
Old Jun 2, 2010 | 04:09 PM
Z_ology's Avatar
Z_ology
I don't think that you are on the right track. I sent you a pm also!
Old Jun 2, 2010 | 04:13 PM
str8dum1's Avatar
str8dum1
1136 is the blown ECU code. 100% the same as me. sorry
https://my350z.com/forum/forced-indu...-now-what.html
Old Jun 2, 2010 | 04:17 PM
Z_ology's Avatar
Z_ology
Yeah, what he said That is a code for the intake solenoid circuit. If you want to stop by, I can double check for you. But it doesn't look good.
Old Jun 2, 2010 | 04:36 PM
350Z400rwhp
Thanks guys, yeah it sounds like I'm fawkd. Just been hoping to get lucky but looks like I'm not. Nate I sent you back a pm, I'll stop by mid afternoon if that's cool with you. Thanks man!
Old Jun 2, 2010 | 04:38 PM
- bigc -'s Avatar
- bigc -
sorry to hear about this man. i hope you get everything sorted out ASAP!
Old Jun 2, 2010 | 04:53 PM
350Z400rwhp
Thanks. Well all Vortech guys out there please learn from my mistake and somehow protect these wires (like Str8dum did). I thought about doing it and never did and now I'm paying the price. It sucks to think of all the precautions I have taken with everything else and now a simple shredded belt has caused so much trouble.
Old Jun 2, 2010 | 05:53 PM
rx7/350z's Avatar
rx7/350z
i actually think this should be addressed by vortech. its their poor design that causes this problem.
Old Jun 2, 2010 | 06:01 PM
str8dum1's Avatar
str8dum1
and vortech will say it was poor maintainence.....
I had some threads about finding the correct ECU. I think you just have to match the 2 digit code on there and thats all.. I honestly dont remember though and your dealer will be able to tell you.
