Say hello to my little friend
Old Jun 4, 2010 | 12:14 PM
SH Luciano's Avatar
SH Luciano
results should be interesting.
Old Jun 4, 2010 | 12:31 PM
psychoballistic's Avatar
psychoballistic
Wow, nice man... Looking good, in for numbers.
Old Jun 4, 2010 | 05:45 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by str8dum1
believe me, any shop is nervous about running that much boost on an open deck aluminum motor. I didnt stop at 38psi because the turbos were outta breath or I was at more than 80%IDC
What...
You running 38psi?
Old Jun 4, 2010 | 06:11 PM
rrmedicx's Avatar
rrmedicx
I cant wait.
Old Jun 4, 2010 | 06:33 PM
binder's Avatar
binder
you did it on an open deck right rich?
Old Jun 4, 2010 | 07:59 PM
blackthreefifty's Avatar
blackthreefifty
Looks like a pretty legit setup. I think I may have heard about Precision having issues with their billet wheels? Has anyone else heard this?
Old Jun 4, 2010 | 08:27 PM
binder's Avatar
binder
nope
they put down crazy hp for the evo's and supras without problems. with as many that run them i'm sure there would be tons of info on failures. Haven't found any yet by searching their forums.
Old Jun 5, 2010 | 03:24 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
I've heard their non billet failure but haven't hear about billet yet.
Not just evo/supra makes crazy numbers, I've read pushed limit 6262 on s2k made around 700~800whp but diff motor, those motors can handle easy 20psi+ on stock block.
I believe this turbo power is there but idk if VQ can handle ton of boost to see limit of this turbo.
But very interesting to see result on vq tho. Good luck op.
Old Jun 5, 2010 | 06:54 AM
binder's Avatar
binder
vq can handle boost just like any motor if you build it right.
hal is 30+ psi, rich just did upper 30's on his 6262 twins and there are a lot that are mid-upper 20's.
Old Jun 5, 2010 | 07:31 AM
Cass007's Avatar
Cass007
VERY NICE!!!
Old Jun 5, 2010 | 07:47 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
cant wait to c numbers
Old Jun 5, 2010 | 08:58 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
I hear ya
Oh btw I take it back about 6262&s2k, I looked again and it was 6265@around 31-32psi.
Old Jun 5, 2010 | 10:09 AM
binder's Avatar
binder
I hear ya
ya, slightly larger exducer so it'll put down more top end power. Doesn't really change the ability to take higher psi though. The billet wheel compressors have shown to do extremely well with high psi.
Old Jun 5, 2010 | 03:43 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Well, today was another day in the garage. I figured, a large turbo should have a larger intake:
4" to 3.5" reducer 90:
See what kind of an air filter we can fit here:
And still good on clearance:
I should also mention that the T4 flanges will be changed from taped to drilled. This will make the install/removal of the turbo easier, because the trubine does not need to be seperated from the CHRA. Just 4 bolts/nuts/lock washers.
My flange was taped, so I just drilled the threads out. Works great now.
Old Jun 5, 2010 | 03:45 PM
OCMan's Avatar
OCMan
thread title sounds very sexy.
Old Jun 5, 2010 | 04:18 PM
zmedic16's Avatar
zmedic16
Without a doubt a good looking kit. Props on the first true t4 large turbo avaliable in the market for the z. I'm planning to keep my redline a bit below or exactly at 8krpms. This kit should definetly make the highest powered s.t kit on pump gas.
Old Jun 5, 2010 | 06:47 PM
Vas_Z33's Avatar
Vas_Z33
im so happy your close to me ... just sayin
Old Jun 5, 2010 | 07:01 PM
  #38
Boosted Performance
Nothing like some bromance...
How is the car runing Vas? I hope you post those numbers tomorrow as soon as you get off the dyno.
Old Jun 5, 2010 | 07:08 PM
  #39
Vas_Z33's Avatar
Vas_Z33
Yes sir!! monday is the day!
Old Jun 7, 2010 | 03:40 PM
  #40
binder's Avatar
binder
so a gt4088 is pretty much identical except when swapped with a 6765 billet on the same supra it produces more power up top but same curve. Taking that into account i had to use the gt4088 to do my compressor map.
For my engine.
.43 bsfc
8k redline
7800 peak power (it was producing peak just slight of peak due to my ported heads/cams)
11.5 afr
1.5psi loss for intercooler
estimation of 4700rpm full spool
says 20.1 psi and 2.43 pressure ratio
oh ya, calculated for 800hp so that would be 704hp at the wheels.
looks like it should be decent enough for me.
