? about the oil feed line for a greddy turbo.
Old Jun 4, 2010 | 03:26 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Default ? about the oil feed line for a greddy turbo.
Hey yall while i did the install on my TT set up i now need to replace the pass side oil feed line for the turbo as it is leaking.It has been over 2 years since i put this kit on and i have forgotten how hard is it to to do with the turbo still mounted to the manifold.
Do i have to remove the turbo or can i still get at it with the removal of the coolant tube on the pass side.............i just cant remember(im old ok).I have a extra set of lines but i just cant remember this process.....i know it was a pita the first time.Looks like ill be buying some more cheap wrenches again.
Thanks for helping one of the old guys.
Old Jun 4, 2010 | 03:33 PM
jeffie7's Avatar
jeffie7
Wish I had an answer for you, my guess is with the right combo of cheap modded tools with tape, it can be done with everything in tact.
I'd give Frank a call and see if he can give you a pointer.
Old Jun 4, 2010 | 03:43 PM
superchargedg
Damn Noobs
*** that Jeffie....you should no me by now.We are the same lets do it ourseleves or it aint gonna get done.I still remember it is a ***** to do this but thats ok as i wont have to help any customers on monday when i fix it.
Old Jun 4, 2010 | 03:58 PM
GreenGoblin's Avatar
GreenGoblin
I have done this... its not fun but def doable. I took just the turbo out form the bottom, but some crappy wrenches up and made it work. There was no need to remove the manifold.
Old Jun 4, 2010 | 04:21 PM
jeffie7's Avatar
jeffie7
I thought maybe since you made it over the hill you might think twice about this kind of stuff =)
Glad to know when I'm old things wont change.
Old Jun 4, 2010 | 07:05 PM
phunk's Avatar
phunk
CJ Motorsports
It's not going to happen without taking the turbo off the manifold
Old Jun 5, 2010 | 01:55 PM
superchargedg
Damn Noobs
Whats fed up is you ever read the greddy instructions it said bolt the turbo up first and the connect the lines.I quess ill be cussing and throwing wrenches again.
Old Jun 5, 2010 | 02:09 PM
superchargedg
Damn Noobs
Thanks to you and Phunk as i just cant wait till monday(sarcasm at its best).All i can say is fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuk.
Old Jun 5, 2010 | 02:19 PM
JasonZ-YA's Avatar
JasonZ-YA
whats the cause of the leak??? 2 years doesnt sound bad, but what material is the end of the line? and what does the end of the line mount into? cast turbo housing??
seems to me it sounds like a dissimilar metal issue and heat......over time, rtv or teflon, whatever is called for during install may have burned out and failed??
may wanna look into more similar material fittings/lines.......
insight??
-J
Old Jun 6, 2010 | 03:06 AM
superchargedg
Damn Noobs
insight??
-J
Its the braided steel lines that came with the kit but i also had Sharif send me his updated lines but still used the original Greddy lines.
Old Jun 6, 2010 | 06:54 AM
GreenGoblin
Ahahha sorry bro, but its what needs to be done. In a few hours and some bloody knuckles you will be done.
Old Jun 6, 2010 | 07:46 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The Greddy lines can be problematic with time and heat, as they are not compression fit. Put our lines on and you will never have this problem again.
Old Jun 6, 2010 | 07:47 AM
superchargedg
Damn Noobs
I should have done it the first time...lol.
Old Jun 7, 2010 | 02:10 PM
superchargedg
Damn Noobs
Hey Sharif i have found the adapters but i only see 3 so still send me the stuff and thanks man.I also got the lines of without dropping the turbo of the manifold.........i may be old but im still crafty.
Old Jun 8, 2010 | 07:44 AM
SH Luciano's Avatar
SH Luciano
lol nice work!
Old Jun 8, 2010 | 02:57 PM
superchargedg
Damn Noobs
Originally Posted by SH Luciano
lol nice work!
Its still a PITA though.
Old Jun 8, 2010 | 04:01 PM
NNOCENT's Avatar
NNOCENT
so theres probably no amount of money that will convince you to drive to crofton to remove the greddy twins from my car... without a lift or removing the engine
but im serious
Old Jun 9, 2010 | 04:04 AM
superchargedg
Damn Noobs
but im serious
You are right.
Old Jun 9, 2010 | 05:44 AM
JasonZ-YA's Avatar
JasonZ-YA
aaahhhhh, thats the insight i was wanting........pfff. no wonder...that bites...
-J
Old Jun 12, 2010 | 08:44 AM
nyqueenz's Avatar
nyqueenz
If you have a Greddy setup go stop by Hills and see if you can get the directions/instructions that came wit my kit.
