Air in cooling system or...
Old Jul 7, 2010 | 05:41 AM
djamps's Avatar
djamps
Default Air in cooling system or...
Since installing the GTM (PWR) radiator a month or so ago I got a few observations...
Level in overflow doesn't seem to rise when engine is hot...only thing I notice is it always seems lower than the last time.
Twice I filled it up to the middle but both times it went back down to about 1/4 full within a few hundred miles or a few days worth of driving.
Do I have air in the system slowly bleeding out or maybe something worse?
Old Jul 7, 2010 | 05:58 AM
rcdash's Avatar
rcdash
The system is self bleeding, so likely just air. Get the spill proof funnel if you want to get it all out at once.
Old Jul 7, 2010 | 04:04 PM
350z006's Avatar
350z006
Or a slight leak...my overflow empties out every week and I re-fill it, it only leaks when being driven...I definitely have a leak somewhere around either the thermostat or other coolant piping around that area (and I can smell it too), but I haven't had a chance to fix it due to my supercharger bracket being in the way...
Old Jul 7, 2010 | 06:59 PM
djamps's Avatar
djamps
I did find a leak due to a loose overflow bung under the radiator cap and tightened it... but it wasn't leaking much and it still went down after that. I checked it this morning and the overflow was bone dry so I filled it up again.... hoping it's just air, I'll update the thread once I find out more.
Old Jul 7, 2010 | 09:50 PM
- bigc -'s Avatar
- bigc -
if your overflow was bone dry then you're sucking air back into your coolant system. bleed that bish with the lisle spill-free funnel!
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
