Spark plugs?
Old Jul 19, 2010 | 12:32 AM
1985zcar's Avatar
1985zcar
Default Spark plugs?
What plugs do you guys run? And gap?
I'm running GReddy TT kit, RC 750s, 11lbs of boost daily, and my car tends to run like crap quite often. It needs to be re-tuned, but I'm thinking my spark plugs may be some of the issue.
Car tends to run rich quite often and has hiccups when cruising sometimes. My friend says he had a car that had that issue, and when he changed the plugs, the hiccups went away...
Soooo yeah, any advice would be great. I know it's a pretty basic thing, but hoping someone has some good insight.
Old Jul 19, 2010 | 01:28 AM
wannabuy350z's Avatar
wannabuy350z
NGK LFR7iX works really well for me
Old Jul 19, 2010 | 04:57 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
For your setup, I would recommend NGK 1 step colder plugs, available here. Gap to .035.
Given your problems of running rich and having hiccups... changing the plugs may immediately make it run better, but if it is running rich then the problem will return. I would advise getting new plugs and having your tune fixed as a permanent solution.
Old Jul 19, 2010 | 05:29 AM
SV1098's Avatar
SV1098
What do you recommend for a TT HR? I'm putting in a set of 370Z plugs.. Any suggestions?
Sorry for the thready hijack..
Old Jul 19, 2010 | 05:52 AM
InjectedPerformance's Avatar
InjectedPerformance
^ from what we have found that is the most affordable option for TT HR guys... the 370 factory plugs are 1 step colder than the HR motor
Old Jul 19, 2010 | 01:11 PM
midz350's Avatar
midz350
Originally Posted by SV1098
What do you reccomend for a TT HR? I'm putting in a set of 370Z plugs.. Any suggestions?
the 370Z plugs would the job fine.
Old Jul 19, 2010 | 07:20 PM
Elperuano's Avatar
Elperuano
im runnin 1 step colder plugs as well and i had SLIGHT hiccups but that was due to tune... plugs r awesome
I was just wondering when should I change the plugs? Running 8lbs of boost.. Normally i know back in NA plugs would last awhile but how about with FI? I've read that you shouldn't run plugs beyond 10k miles on an FI car. (sorry for the thread hijack op)
Old Jul 19, 2010 | 07:38 PM
streetzlegend's Avatar
streetzlegend
I got 1 step colder plugs ngk vpower's (22 bucks shipped), at 15psi + meth + occasional spray. Recently had to change them out because I was getting some misfires. I had about 7k on them. Plugs look fine, no pepper or melting going on, but I think they got too much fuel so I might change them every 7-10k from now on, its my first plug change for this motor.
Old Jul 28, 2010 | 11:58 AM
binder's Avatar
binder
so at what boost/power levels is it a must to go to 2 steps colder?
hal? you'll be tuning this beast in aug so what's your input. We're shooting for the 600hp on your dyno and i'm 1 step colder, should i go to 2 steps colder or leave it be?
Old Jul 28, 2010 | 12:17 PM
seymore4's Avatar
seymore4
Professional
I'd be more interested in what EMS you're running... Get your tune checked, Osiris and new plugs will fix it
Old Jul 28, 2010 | 12:29 PM
thom000001's Avatar
thom000001
1 step colder plugs here, and made 801rwhp....off top of my head I want to say gap is in the .028 range (can't remember right now though).
Tom
Old Jul 28, 2010 | 12:48 PM
Dynosty's Avatar
Dynosty
1 step colder will likely be the best fit for you. We can pull a plug on the dyno and check though.
Old Jul 28, 2010 | 06:32 PM
binder's Avatar
binder
cool. I'm on 1 step colder with .03 gap right now. I just wasn't sure since i'm shooting for more hp if i should go even colder or not.
Old Jul 29, 2010 | 03:11 AM
str8dum1's Avatar
str8dum1
You have a highly modded engine, so like Hal said until he pulls the plugs and looks for pre-igintion, you might still need the 2 step colder iridiums.
Old Jul 29, 2010 | 06:11 AM
thom000001's Avatar
thom000001
I'd hope not...I like running my $2 plugs
Tom
Old Jul 29, 2010 | 10:13 AM
str8dum1's Avatar
str8dum1
link to 2$ coppers please they are not lfr6a-11's for 2$
Old Jul 29, 2010 | 11:38 AM
binder's Avatar
binder
ya, i got my coppers for 6$ a piece which i don't think is bad.
So do i need to bring 2 sets of plugs with me to the dyno?? I was going to replace them before i go back, so i was hoping to just have new ones in adn that be it. Sucks to blow 40$ on plugs i'm not going to use.
Old Jul 29, 2010 | 03:54 PM
350z006's Avatar
350z006
Thinking about switching to coppers from the iridiums...what's the typical life of a copper in FI?
And, is it advisable to replace sparkplugs after breaking in a fresh new built engine?
Old Jul 29, 2010 | 04:43 PM
str8dum1's Avatar
str8dum1
copper is 6-10,000 miles. so once or twice per year...
if your break-in tune wasnt overly rich/lean (as enough to foul or burn up the plugs), then you shouldnt have to change them
Old Jul 30, 2010 | 02:32 PM
binder's Avatar
binder
****, i don't even have 3k on my car this year :/
