method of tuning for TT?
Old Aug 4, 2010 | 10:36 PM
jdm-v35's Avatar
jdm-v35
Default method of tuning for TT?
I am in the process of getting a JWT TT kit with 255l walbro and upgraded injectors(possibly)
I am looking into emanage ultimate, osiris(if it can be done by mail) at the moment.
I dont have the money to spend on a standalone and I have had a bad experience with utec before so I am looking into other options.
im leaning more towards the emanage ultimate right now.
any input?
Old Aug 5, 2010 | 05:25 AM
GBoger's Avatar
GBoger
well if you want the method of tuning where you don't blow your **** up then don't go with the emanage. I would deffinitely go with the osiris but would try to get it dyno tuned.
Old Aug 5, 2010 | 05:45 AM
jdm-v35's Avatar
jdm-v35
yea i figured that but we are just limited by what people here can tune. there is an osiris tuner here but ive heard his tuning isnt the best.
Old Aug 5, 2010 | 05:56 AM
XKR's Avatar
XKR
Do you have money to replace the motor if it blows up?? If the answer is yes.... Then you have money for a Utec and a plane ticket for s good tuner to fly over there!!
You are in a location where any good tuner would be happy to come to!!!
Old Aug 5, 2010 | 06:34 AM
TwoFiveBar's Avatar
TwoFiveBar
Old Aug 5, 2010 | 06:52 AM
jdm-v35's Avatar
jdm-v35
probably going to end up going utec at this point. Also I thought the main problem with emanage is that it cannot control the ecu in closed loop mode?
Old Aug 5, 2010 | 07:10 AM
TwoFiveBar's Avatar
TwoFiveBar
Its archaic in a way, but the UTEC gets the job done for a relativity low price. I'm sure you will be happy, even with its quirks. Just don't run anything larger than say a 600cc injector.
Old Aug 5, 2010 | 07:25 AM
GBoger's Avatar
GBoger
Originally Posted by TwoFiveBar
The E-manage ultimate is not that bad. Its no worse than the UTEC if properly installed and tuned. Just check the P'n'P main harness (not the blue to ultimate upgrade harness), GReddy made a bad batch, which they wont admit, that was improperly pinned. Just check the harness wires from pin pin and make sure the wires are going to the correct location if you decide go that route.
you're kidding right? The emanage has proven itself to be worthless. There is not comparison to even the lowly utec.
Old Aug 5, 2010 | 07:37 AM
TwoFiveBar's Avatar
TwoFiveBar
Old Aug 5, 2010 | 08:02 AM
djamps's Avatar
djamps
The UTEC actually does ALOT for the money -- you would be VERY hard pressed to blow up a motor with a competent tune on a UTEC.
Stuff on the UTEC like active knock control, overboost cut, full open loop timing/fuel control is typically only found on high end full standalone EMS.
Old Aug 5, 2010 | 09:31 AM
streetzlegend's Avatar
streetzlegend
On what car will this be going on? I ask because of your name (VQ30), cefiro, maxima,..?
If money is an issue, then go with the EU. I have always been using it, from the Emanage Blue to the Ultimate, no complaints at all and no issues, full timing control, full fuel injector control(except for changing their firing order, such as batch fire, etc..), a crap load of useful features, logging, you name it, it has it. Ofcourse being able to build your own tables via a standalone is great and also some of those have built in knock control, EU dosnt. My tuning devices are EU and J&S. As for my setup, its a built vq35, single turbo at 15-17psi with meth and occasional spray.
Old Aug 5, 2010 | 09:37 AM
streetzlegend
Perhaps I have missed something, where did you find your facts about EU proving itself to be worthless? This has been covered many times on here, and conclusion is that emanage got a bad rep when people were installing them on FI setups without timing control(harness), then automatically people assume its the device and not the tuner. I am not saying EU is the best thing out nor is it better than others such as utec or others, but it does not mean its crap. No matter what device your using, its all about the tuner.
Old Aug 5, 2010 | 12:59 PM
jdm-v35's Avatar
jdm-v35
I used to have a stillen s/c maxima long time ago. its going on a 03 g35 5at.
Old Aug 5, 2010 | 01:12 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Originally Posted by Sylvan Lake V35
Jim Wolf supplies a split second box with his kits that comes with a great base tune....use that its not the best but it is much better than an e-manage.
Are you going to ask all of the same questions on both G35 driver and here?
http://g35driver.com/forums/forced-i...ml#post5273126
http://g35driver.com/forums/forced-i...ock-boost.html
Looks like you have about five threads going between the two forums!?! One thread on each forum would probobly work fine, the FI sections are not very tolarant although if you don't annoy everyone they can be very helpful.
Old Aug 5, 2010 | 01:21 PM
jdm-v35's Avatar
jdm-v35
yes thats me too haha. i figured id get pretty different answers from each forum.
Old Aug 5, 2010 | 01:37 PM
Sylvan Lake V35
The G35 guys with serious FI builds are on this forum, alot more info available over here.
Old Aug 5, 2010 | 02:15 PM
jdm-v35's Avatar
jdm-v35
cool ill keep this thread more active then. seems the tuner i want to go to mainly uses accessport and theyre a dealer so its taken care of. so i just need injectors now.
Old Aug 5, 2010 | 05:22 PM
streetzlegend
btw here is a quick link, just as an example of the Emanage Ultimate being used on decent amount of HP (600+). https://my350z.com/forum/forced-indu...anna-join.html
Old Aug 5, 2010 | 06:45 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Talk about a blast from the past! "UTEC beta testing"
Old Aug 5, 2010 | 07:15 PM
streetzlegend
yeah its old, just wanted to show some evidence to back up the EU, so people stop bashing the poor thing lol. If your broke and know what your doing when it comes to tuning EU is your friend, now if money aint an issue then ofcourse standalones and other superior devices are available.
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
