misfires with PL kit
Old Aug 11, 2010 | 03:45 PM
Bigalow's Avatar
Bigalow
Default misfires with PL kit
I have the powerlab kit installed in my '03 track. After getting tuned at Function: Tuned with an Osiris flash I received the SES about a week later. Dave from FT says that it's caused by the large injectors and to keep an eye on it.
I have to take it to Dave but that probably won't be anytime soon since HPDE, drifting, etc events are around the corner. Is anyone else running the PL kit with their SES on? If so, any possible solutions? Can I damage my engine but tracking my Z? Thanks.
Old Aug 11, 2010 | 04:07 PM
DavesZ#3's Avatar
DavesZ#3
What's the code?
Old Aug 11, 2010 | 04:18 PM
Bigalow's Avatar
Bigalow
Originally Posted by davesz#3
what's the code?
"troubleshooting p0300
oem brand: Nissan/datsun
definition
aa random cylinder misfire detected
probable cause
1. Ignition system fault
2. Fuel system fault
3. Large vacuum leak
4. Maf sensor fault
5. Af/ho2s (air0fuel/heated oxygen sensor) sensor fault"
On a side note. The SES has deactivated (twice) after not driving the Z around for >3 days. It's only when I drive it like a DD does that happen... hmmm.
Old Aug 11, 2010 | 05:24 PM
GreenGoblin's Avatar
GreenGoblin
what plugs are you running?
Old Aug 11, 2010 | 05:28 PM
str8dum1's Avatar
str8dum1
might also want to try closing the gap on the plugs.
Old Aug 11, 2010 | 05:54 PM
jeffie7's Avatar
jeffie7
What's your idle at?
Old Aug 11, 2010 | 06:05 PM
Bigalow's Avatar
Bigalow
Green,
600cc Denso Injectors
Jeffie,
about 950-1000 smooth idle.
Old Aug 11, 2010 | 06:07 PM
Bigalow's Avatar
Bigalow
I have the HPX MAF also but I don't think that's the cause.... just sayin, really..
Old Aug 11, 2010 | 08:21 PM
Elperuano's Avatar
Elperuano
My SES light is on also but i kinda just ignore it really.. I'm sure its nuttin really.. I haven't gotten the code checked but the car runs strong and i've experienced no problems at all. It also goes away when not turning the car on for 3 days or so but usually comes back on.
Old Aug 11, 2010 | 09:39 PM
Vas_Z33's Avatar
Vas_Z33
you shouldnt have a ses/cel... Im running NGK 1 step colder, osiris, hpx, dw 800cc. No lights here for me... idk why people ignore it lol ( not you elperuano ^ )
Old Aug 12, 2010 | 02:28 AM
Bigalow's Avatar
Bigalow
what dyno did you get your numbers from? I don't want to ignore that thing. Its really annoying to me and I just want it off...
Old Aug 12, 2010 | 03:49 AM
marra23's Avatar
marra23
Permanent light here as well but I am ignoring it. After some trouble shooting, I believe it's my utec.
Old Aug 12, 2010 | 05:06 AM
Elperuano's Avatar
Elperuano
I'll get the code checked n tell u what it is.
Old Aug 12, 2010 | 05:45 AM
djamps's Avatar
djamps
If you've got the right plugs and gap (1 step colder), then it's usually tune related.
Do you notice your car driving less smooth than stock in part throttle?
Old Aug 12, 2010 | 06:06 AM
Elperuano's Avatar
Elperuano
In my case nope. Car runs good at WOT or part throttle n idles fine at 750 which was my stock idle or at least NA idle.. More than likely its some sensor.
The SES light comes on for NA guys when they put test pipes without the extended 02 sensors... simple stuff...
Old Aug 12, 2010 | 06:22 AM
Vas_Z33's Avatar
Vas_Z33
DJ dyno.
Old Aug 12, 2010 | 06:23 AM
Vas_Z33's Avatar
Vas_Z33
yeah but the NA cars dont throw a misfire if you replace the cats.
Old Aug 12, 2010 | 06:38 AM
Elperuano's Avatar
Elperuano
Yea tru, id like to see him troubleshoot it more to find out the exact cause in his case.
Old Aug 12, 2010 | 08:40 AM
str8dum1's Avatar
str8dum1
a miss at startup with a turbo kit is not uncommon. If you get misses while you are driving or everytime you start the car, then you have a problem with your tune or ignition system
Old Aug 12, 2010 | 09:57 AM
Bigalow's Avatar
Bigalow
I happens when I drive around, park for a while, then drive again. when I was driving a couple of weeks ago the ses was flashing, stayed solid for about 30 minutes then turned off
