SP Boost Actuated Exhaust Cut-Out for my Greddy EVO TT
Old Aug 27, 2010 | 02:26 PM
Vas_Z33's Avatar
Vas_Z33
looks sick! I love my 3" cutout
Old Aug 27, 2010 | 02:33 PM
str8dum1's Avatar
str8dum1
actually I was quite surprised they didnt just use a pair of their pre-fabbed 3" y pipes and cut the difference out of each exhaust pipe.
Originally Posted by rrmedicx
Lots of trial and error by people who do this every day of the week. It's not easy. Now unless you are an exhaust fabricator, in
that case, its probably easy.
Old Aug 27, 2010 | 03:22 PM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
He has 2.5" downpipes and all we have in stock is 3" cutouts. I RARELY sell 2.5" cutouts. This is why we chose to use one 3" !!
Old Aug 27, 2010 | 03:23 PM
Vas_Z33's Avatar
Vas_Z33
Thats what i figured at first... I thought they would be 2 of these.. but this setup is nice as well
Old Aug 27, 2010 | 03:38 PM
zmedic16's Avatar
zmedic16
vas you have this setup on your bp kit?
Old Aug 27, 2010 | 05:20 PM
Vas_Z33's Avatar
Vas_Z33
I dont have this setup.. I have a custom downpipe with a custom 3" electronic cutout .. just not boost activated.
Old Aug 27, 2010 | 05:35 PM
xzotklr's Avatar
xzotklr
While visiting SP this week, I decided to take advantage of some of their innovations and went with the Boost Actuated Exhaust Cut-out. My original intent was to install the pair. Due to time constraints and to make life simpler for all, rather than attempt to remove the downpipes on the Greddy Kit (PITA), we opted to install a single dump in between the 1st set of behind the cat pipes seen below:
***(I apologize for any blurry pics, only had my cell phone)***
Before Shots:
After:
First came assembling the actual 3" cut-out with the necessary down facing tip:
Then some more fab work:
Test fitting (Tacked it up):
Then final welding run the boost line and voila:
Done.
I utilized this set-up to counteract the anticipated hp losses I would incur by going with the Cosworth intake. Worked out pretty well. No overall power losses than previous set-up.
That's my buddy....you got a killer Z!!! Nice to see you getting where you want to be!!!
Old Aug 27, 2010 | 05:36 PM
streetzlegend's Avatar
streetzlegend
Looks awesome, congrats. Very weird that you did not have to retune (most likely unique to your situation). Usually means that your exhaust system is not restrictive at all so having the cutout really dosnt do much, or your map is tuned good enough that even if theres increased intake flow its still in good afr/timing etc...
Old Aug 27, 2010 | 05:54 PM
IslandZavage's Avatar
IslandZavage
how does it sound with your open dumps? Is it louder same or etc...?
Old Aug 27, 2010 | 06:11 PM
str8dum1's Avatar
str8dum1
Open exhaust is super loud. I have to drive my car with earplugs, but mine are dumps off the down pipes. I'm sure past 11psi, Randy's is suepr loud as well.
Old Aug 28, 2010 | 10:07 AM
Cass007's Avatar
Cass007
Nice Randy
Thanks for the info on the intake as well, looks like I will be sticking with my APS then.
Old Aug 28, 2010 | 12:23 PM
rrmedicx's Avatar
rrmedicx
Thanks for the compliments fella's. Truth be told (Larry)...The downpipes are 3" SGP downpipes. The Greddy Cat back pipes are 2.75" pipes. But because we were not about to attempt to remove the downpipes based on location, we decided to do the job at the front most pipes right after the downpipes.
Honestly, the system is already loud to begin with because of the open wastegate dumps. I didn't notice any difference in terms of loudness when we were tuning. I only noticed the difference when I began to drive the car and the exhaust opened. I felt the grumble coming from under the car. Wonderful sensation I have to say!
Old Aug 28, 2010 | 01:03 PM
Z PHAT Z's Avatar
Z PHAT Z
I'm on an APS 2.5 dual exhaust and thinking about upgrading to a 3" exhaust. Would this be a better upgrade say in power and money wise? If you don't mind, how much is this unit cost? Thanks.
Old Aug 28, 2010 | 02:06 PM
str8dum1's Avatar
str8dum1
you are looking at a 6-700$ modification to your exhaust. If that is worth your money then go for it!
Old Aug 30, 2010 | 09:12 AM
rcdash's Avatar
rcdash
Looks bigger in the pics but - the 2.5" downpipes certainly helps to explain that torque curve... Time to step up to 3" downpipes Randy!!!
Old Aug 30, 2010 | 09:23 AM
str8dum1's Avatar
str8dum1
he has 3" already...
Old Aug 30, 2010 | 09:24 AM
str8dum1's Avatar
str8dum1
how long til you guys get some more 4" cutouts in?
Old Aug 30, 2010 | 09:43 AM
  #38
rcdash's Avatar
rcdash
ok - nm then - not sure why the torque and power peak so early...
Old Aug 30, 2010 | 04:30 PM
  #39
Mr_pharmD's Avatar
Mr_pharmD
so no gains with the ecut? so why upgrade to an ecut out?
Old Aug 30, 2010 | 04:49 PM
  #40
2004Black350z's Avatar
2004Black350z
Exhaust Whore
medic wheres the Vid??
