Stillen Stage 2 Supercharger vs Turbonetics Single Turbo Kit
Old Sep 3, 2010 | 08:51 AM
doug's Avatar
doug
you claim you did research and picked the two worse FI Kits? i'm not buying that bullsht
Old Sep 3, 2010 | 10:13 AM
StillD1's Avatar
StillD1
Well, we all know what opinions are like and that everyone has one.
Thank you for your helpful insight.
If you really wanted to add value, you would have shared the knowledge your research and experience has provided you .... genius!
Thanks for doing nothing but clogging up the internet.
Old Sep 3, 2010 | 10:44 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Really any FI can get you those power levels. But for the sake of reliability, I would just stay away from blowers altogether. You end up running into belt/pulley issues.
Old Sep 3, 2010 | 11:59 AM
Boosted Performance's Avatar
Boosted Performance
Very true. I have had s/c experience, along with some of my friends. It seems that there is always issues with bearings/pulleys.
My turboed Z is the most reliable FI car I have ever had.
Old Sep 3, 2010 | 06:50 PM
djamps's Avatar
djamps
Turbos are generally maintenance/trouble free if taken care of properly. I agree with Doug about the research...if you researched your choices you'd see that there are chronic issues with theTturbonetics, and the Stillen stage2 (hell even stage 4) isn't going to get you 330whp.
Old Sep 6, 2010 | 11:30 AM
weslutes's Avatar
weslutes
Sorry but I have to agree with Doug.
I think had my Stillen kit back in 2005. The only way to make it exciting was to add a 55 shot with the stage 4. Still not as fun as my TT now.
"Based on my research, and to keep our Z streetable without constantly working on it, and to add some HP without tearing into the internals, it looks like I should not push much beyond 400HP or approx. 325 -330 WHP."
Looks like ALL of your research was with Stillen. The "streetable" and "400HP" quote sounds like it came straight from the Stillen catalog.
I had tons of issues with the kit. Belts,belts,and more belts, Stillen pulley bearings, stock idler pulley bearings, killing my MAF, cam sensor wiring, SS box dying, IC water pump and on and on.
Old Sep 6, 2010 | 01:36 PM
StillD1's Avatar
StillD1
Default Update and Thank you
Thank you to all of you that provided useful feedback. It definitely points to not considering Stillen's S/C. I have contacted Boosted Performance and unfortunately, they do not make a kit for an automatic transmission. So, I al back to the drawing board. Any experiences with Vortech? I am not convinced I have to go S/C. But, I am not seeing a lot of turbo kits for an automatic, at a reasonable price.
Old Sep 6, 2010 | 06:36 PM
BoostedTreeFity's Avatar
BoostedTreeFity
If you go the route of the Turbonetics Single Turbo ensure you get the water cooled turbo, it has a lot less issues, the car I bought has the standard oil cooled turbo and it blows large blue clouds when shifting after full spool.
Old Sep 6, 2010 | 06:40 PM
twitch579's Avatar
twitch579
Didnt they all come watercooled after a certain year? How do u tell the differences in the generations of the Turbonectics kits?
Old Sep 6, 2010 | 08:28 PM
Scabd's Avatar
Scabd
Just like everything else in life, it's all in perspective. A local shop I do work with builds engines all day long with TT and SC setups (only positive displacement supercharger tho, ei those like Stillen not Vortec). With the stillen kit you won't have boost lag, with any turbo kit you will. But it is easier to put down higher numbers with the Turbonetics single turbo kit than the Stillen SC kit.
Now, here is how I see it...there is a problem with the Stillen kit, the supercharger is more designed for a much smaller engine. So the blower has to work much harder and runs higher boost to produce the low numbers that it does produce. And from what I have heard Stillen fixed the baring issue and the belt issue also. If not you can also find a stronger belt, baring issues, no clue how to keep that from happening.
If you want a SC really bad, "custom" do everything and put on a Whipple
Old Sep 7, 2010 | 06:12 AM
doug's Avatar
doug
If you did any research at all.. which you did not do.. you would have found threads where i provided evidence that the Stillen kit blew more motors with less than 330 whp than other kits did with over 400 whp..
its not about HP its about tuning and the ability to customize your tune.. which the Stillen can't offer.. you can act polite all day long and hope people are going to answer your questions.. personally i help those that help themselves.. and you've done nothing.. its not bullsht its the reality of the situation.. you don't like it.. read more
Old Sep 7, 2010 | 07:35 AM
BoostedTreeFity
The watercooled turbos will have 2 3/8" high pressure lines feeding and returning from the turbo aside from the required oil line which in my opinion isn't there to do any cooling just lubrication. I do believe the current kits are all watercooled due to this common parasitic problem. I'm not posative on this as I'm pretty new to these cars myself but I have dealt with alot of turbo 4 and inline 6's as well as my own turbo diesel
Joe
Old Sep 7, 2010 | 08:21 AM
IIQuickSilverII's Avatar
IIQuickSilverII
thsi thread need "dream thread tag alert"
OP, go with stillen kit.....they were offering disney tickets with a purchase of one
Old Sep 7, 2010 | 09:08 AM
doug's Avatar
doug
Joe
why is Staggered a mod? my car came staggered stock
Old Sep 7, 2010 | 09:35 AM
roger22's Avatar
roger22
And a wrap-around also....
Old Sep 7, 2010 | 01:20 PM
BoostedTreeFity
It's easier to say that then the loooong list of mods my car came with
Old Sep 7, 2010 | 02:48 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I wasnt going to comment in this thread
But Doug is back and let the party get started............woooooohooooo.
Old Sep 7, 2010 | 02:59 PM
  #38
roger22's Avatar
roger22
Just posted in another thread but here goes, DE rod after Stillen Stage 4 "hot setup"!!!!
Attached Thumbnails Stillen Stage 2 Supercharger vs Turbonetics Single Turbo Kit-rod.jpg
Old Sep 7, 2010 | 03:43 PM
  #39
djamps's Avatar
djamps
Wow... no stock rod is safe LOL
Old Sep 8, 2010 | 05:19 PM
  #40
BoostedTreeFity
Originally Posted by superchargedg
The turbonetic's kit was so flawed that they do not sell it anymore......and do not buy a used kit.
You might want to rethink that post guy. The Turbonetics Single Turbo Kit is alive and well. It underwent a major revision and was switched to a liquid cooled unit over the old plain turbo which I have on my 350Z. The problem with the kit WAS the turbo itself got too hot and the intercooler had no sheilding from the turbo, especially the cooler to throttle body pipe which runs 3" above the turbo. Go ahead and flame me for being a Noob but I have a 350Z with the kit you THINK you know something about, Do your research.
