Cooling w/ removed heater core
Old Sep 16, 2010 | 05:35 PM
GreenGoblin's Avatar
GreenGoblin
So I think I have my issues sorted out. I have been battling overheating issues now that I removed the heater. I studied the flow charts etc, and look at the spare heads I have, and if you delete the bypass across the front of the motor and the heater, the t-stat never gets hot water across it to open. I tried everything from spill free funnel to, having the system pressurized and back filled. Still over heated no mater what and stat would not open.
So here is the solution.
4an to supply hot water from the radiator, to t-stat. I also modified the Nismo stat by removing the tiny plunger to help relieve any air that would want to get trapped.
Old Sep 17, 2010 | 07:01 AM
binder's Avatar
binder
good work!
why a 4an though?
Old Sep 17, 2010 | 09:36 AM
GreenGoblin
To be honest the reason I choose 4, was they had the fittings in stock at the local speed shop.
Old Sep 17, 2010 | 09:49 AM
GreenGoblin
A few pics with the fitting welded on.
Old Sep 17, 2010 | 02:22 PM
binder's Avatar
binder
makes sense. I didn't know if there was a flow reason or whatever. I guess it probably wouldn't make much difference.
Now use your spill free and fill your system as slow as possible and no air should ever get trapped in that tstat. Awsome!
Old Sep 18, 2010 | 10:13 AM
GreenGoblin
Ya I honestly do not think flow will be an issue, as long as some hot water can get behind the the stat, it will work. The rest of the fittings should be here Tuesday or Wednesday, so we will know soon. I am going to vac fill the cooling system for zero chance of any air.
Old Sep 24, 2010 | 12:51 PM
GreenGoblin
Some updates line is made and installed. Bleeding it as we speak.
Old Sep 24, 2010 | 03:08 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Nice
Old Sep 24, 2010 | 07:21 PM
bbs350z's Avatar
bbs350z
did you keep the crossover tube from the front of both coolant pipes? i removed the heater core but kept the crossover tube on my track car, as ive been told and read about motors cavitating when both are removed. any reason behind removing the heater core?
when i removed the heater core, i just rerouted the heater core hoses to eachother instead of inside the car
Old Sep 24, 2010 | 07:39 PM
GreenGoblin
No the cross over tube on the front of the motor has been gone for about 1.5 years. Heater was just recently deleted with this round of clean up.
Old Sep 25, 2010 | 12:56 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Good job man on finding the solution to the problem.
Old Sep 25, 2010 | 02:43 PM
binder's Avatar
binder
looks good
so i take it this is purely a track car or do you live in a hot climate where you don't need heat?
Old Sep 25, 2010 | 07:11 PM
str8dum1's Avatar
str8dum1
south florida doesnt need the heat much.
Old Sep 26, 2010 | 04:42 AM
GreenGoblin
Ya most of the time its so unbearable hot, I can not tell you the last time I used the heat.
Old Sep 26, 2010 | 06:30 PM
binder's Avatar
binder
ah, i see
Old Sep 30, 2010 | 10:17 PM
bbs350z's Avatar
bbs350z
was in florida this past february, 50 in the day, 40 at night.
your making me miss my g sedan lol, now i just got this dumb evo *kicks ground*
Old Oct 1, 2010 | 11:28 AM
GreenGoblin
ya this winter was a fluke coldest recored in l like 10 years
Old Oct 1, 2010 | 11:43 AM
  #38
JasonZ-YA's Avatar
JasonZ-YA
any hwy driving, testing to verify all is well???
-J
Old Oct 1, 2010 | 02:06 PM
  #39
GreenGoblin
tomorrow i am off work so i ill verify
Old Oct 2, 2010 | 10:36 PM
  #40
JasonZ-YA's Avatar
JasonZ-YA
