FI with x pipe?
Hey all, i've seen alot of posts with those running true dual 3" setups but I was wondering if you can add a x pipe to that set up? Reason being is i'm hoping to cut down on the rasp a bit and it worked on my true dual NA setup. If anyone has done this, how was the power affected in the long run? was it a minute drop of 2-3 hp or drastic enough to be considered not being put on? any input would be appreciated, thanks!
I thought about going motordyne, but i've already built my exhaust system and all i have to do now is change the piping and dump the 2.5 x pipe from magnaflow, i posted to see if its worth welding a 3" x pipe (magnaflow) to the new 3" piping.
