Meatbag's G35
Old Mar 22, 2011 | 03:22 PM
  #141
meatbag's Avatar
meatbag
Originally Posted by RudeG_v2.0
Thanks for the candid response Charles.
Hopefully meatbag can shed some light on this, since we both have a G and the same hood. It's been a while since I've stopped by the shop and taken a look at the underside of my TS hood.
The hood has to be cut if you do the piping over the radiator. I have to cut out the hood latch area and whatnot for sure, will know for sure when it comes time to mount the hood on permanently.
There isnt as much in the G35.
Old Mar 22, 2011 | 03:30 PM
  #142
str8dum1's Avatar
str8dum1
perfect candidate for a custom Howe radiator. just make it 2 or 3" shorter.
Old Mar 22, 2011 | 03:38 PM
  #143
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I would do a 90 degree elbow behind the radiator to connect to the existing IC piping on the PL kit. I don't recall... is there any hood support structure in that area between the front timing cover and the radiator that might have to be cut?
Old Mar 22, 2011 | 04:30 PM
  #144
meatbag's Avatar
meatbag
You can use a 56mm "stock" sized rad you just have to clearence a small part.
I didnt want to loose and surface area so that is why I sectioned the end tank instead of making the entire unit smaller. And I didnt have any room to make it thicker. Plus the small part that I sectioned out allowed for a straight shot into the throttle body.
Just one small rib that runs down the centerline of the hood. You might have to cheat the cut a little but you should be fine.
Old Mar 22, 2011 | 04:35 PM
  #145
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
OK Thnx!
Old Mar 22, 2011 | 06:03 PM
  #146
GreenGoblin's Avatar
GreenGoblin
Damn Charles, better get some of those cutting. I am going to start saving my pennies.
Old Mar 22, 2011 | 07:39 PM
  #147
meatbag's Avatar
meatbag
Its going to be interesting to see how Charles's manifold does with some real turbos pumping air into it
Old Mar 22, 2011 | 08:05 PM
  #148
phunk's Avatar
phunk
CJ Motorsports
how soon do you plan on doing that??
Old Mar 22, 2011 | 08:09 PM
  #149
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Charles,
Any updates or progress you can share with us about the EFR turbos and Full Race manifolds on your 370Z? Or are you sworn to secrecy by Full Race?
Old Mar 23, 2011 | 06:46 AM
  #150
str8dum1's Avatar
str8dum1
we've already seen it on the SP car....
Old Mar 23, 2011 | 01:56 PM
  #151
350zfun19's Avatar
350zfun19
Charles,
+1 I cant wait to see this.
Old Mar 23, 2011 | 02:57 PM
  #152
meatbag's Avatar
meatbag
Not really the same design, but it is similar.
Old Mar 23, 2011 | 03:13 PM
  #153
str8dum1's Avatar
str8dum1
ya but there arent many 1200+whp cars to make any meaningful comparisons.
big enough turbos and cams will extend your powerband out as far as you want. i made power to 8000rpm with no headwork and just c2 cams, just being carried by the turbos.
Old Mar 29, 2011 | 08:10 PM
  #154
batboyvaj's Avatar
batboyvaj
Meatbag, did you have all the head upgrades done when you originally dyno'd at 619?
Old Mar 30, 2011 | 10:16 AM
  #155
meatbag's Avatar
meatbag
Yes. internally nothing changed on the motor except for swapping out the Nismo competition oil pump.
Car is coming back from the body shop this week from having everything fitted and trimmed. Will be bringing the car back to the shop to do a race gas tune before it goes back in for paint.
Old Mar 30, 2011 | 07:01 PM
  #156
meatbag's Avatar
meatbag
Car being fitted with the new body work finally
Old Mar 30, 2011 | 07:11 PM
  #157
phunk's Avatar
phunk
CJ Motorsports
and you thought our intake manifold took a long time!
Old Mar 30, 2011 | 07:12 PM
  #158
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I Top Secret widebody kit for the G.
Old Mar 30, 2011 | 08:19 PM
  #159
meatbag's Avatar
meatbag
I know right. What was originally going to be 4-6 weeks for body work turned into 8 months.
Old Mar 30, 2011 | 10:57 PM
  #160
DéDé's Avatar
DéDé
Nice!
