Looks like my engine is dying ( knocking ), but it doesn't seem to be FI related.
Old Oct 19, 2010 | 03:06 PM
streetzlegend's Avatar
streetzlegend
knocking is not good at all, if its always there, and even when car is warm, not good. When I 1st swapped vq35 into my maxima it had a very faint knock, could hear it at idle but also driving, i thought it was normal since most vq's are noisey. Was then driving on the highway, gave it a quick WOT for the first time, perfect tune btw, then kept driving and suddenly, tack tack tack tack tack, got off the highway and BAM, snapped a rod. No other symptoms before this, car drove perfect, except for the very faint knock. Probably the engine had been damaged before i bought it at the junkyard. I would inspect ur engine if I were you.
Old Oct 19, 2010 | 04:47 PM
GT-ER's Avatar
GT-ER
I've done over 20 WOT runs and it still runs the same. But the knock is kinda worrying. I'm not going to take the engine out to rebuild it without forging it...and that's the problem...lol.
Old Oct 19, 2010 | 05:44 PM
djamps's Avatar
djamps
Just check ur pan or filter sooner than later. You'll know if it's time to forge or not.
Old Oct 19, 2010 | 05:49 PM
djamps's Avatar
djamps
FYI, here's a bad case of rod knock:
https://my350z.com/forum/engine-and-...help-guys.html
Old Oct 19, 2010 | 07:48 PM
GT-ER's Avatar
GT-ER
Oh no... my car doesn't sound NEARLY that loud. Heck, you can just barely hear it.
Honestly, I'm very worried about it. I don't wish to have to build the engine just yet. It being my only car, getting to work will be kinda hard without it and I HATE depending on other people to get to work. I guess it is what it is.
Old Oct 20, 2010 | 07:34 AM
tylerxfire's Avatar
tylerxfire
only a matter of time..hasnt this car always had problems making the power it should? u had to put it up to 17psi just to make the same power i basically made at 9-10 psi?? probably an ongoing problem that just getting worse and worse
Old Oct 20, 2010 | 09:43 AM
Quamen's Avatar
Quamen
Sounds like your shooting for too high of a goal if this is you DD.
Old Oct 20, 2010 | 12:15 PM
QuadCam's Avatar
QuadCam
does your car make a sound like a bunch of BBs bouncing around? Does it only happen at light throttle (no boost) situations? But, it doesn't happen at higher loads or while in boost? What engine management system are you using?
Old Oct 20, 2010 | 04:49 PM
GT-ER's Avatar
GT-ER
You think 500whp in a daily driver is too much? I know someone with a 750whp G35 and it's his daily driver but he's insane imo...I think 500whp would be the limit between fast and somewhat reliable not making a fool of yourself spinning 1st, 2nd and 3rd.
Old Oct 20, 2010 | 04:51 PM
GT-ER's Avatar
GT-ER
It sounds like someone tapping the block with a hammer very softly in a rythmic fashion. It'll do it in light throttle and very VERY FEW times in idle and NEVER in higher loads nor under boost.
I run Osiris.
Old Oct 20, 2010 | 04:54 PM
str8dum1's Avatar
str8dum1
is he on the forums?
Old Oct 20, 2010 | 05:09 PM
GT-ER's Avatar
GT-ER
I don't think so. I know him personally ( not as a friend or anything ). His is twin turbo + N2O.
Old Oct 20, 2010 | 08:49 PM
Quamen's Avatar
Quamen
I by no means feel that 500whp is too much to handle on the street. It just seems that with all the issues you have been having there is some work to be done prior to that goal being achieved.
Old Oct 20, 2010 | 09:34 PM
GT-ER's Avatar
GT-ER
Well, I found out what the noise was. Tonight I romped on it to try out my rebuild Vortech and the damper came apart and broke my front timing chain cover. Problem solved....I guess.
Old Oct 21, 2010 | 05:12 AM
4SHIZZIL's Avatar
4SHIZZIL
I do recommend buying a $1500 honda civic at the least....
once you go boosted you are driving a race car that requires a full team to include a tuner, crew chief and many others (forum) to keep it running.
I would not spend 15K on my only car....spend 14K and buy another daily.
my two cents. 600RWHP can be daily driven as long as you are out of boost.
even built motors can break, be put together improperly, have issues, and downtime.
DO NOT expect to drop in it and forget about it... there is always something.
Old Oct 21, 2010 | 08:03 AM
Quamen's Avatar
Quamen
This is my point exactly.
Old Oct 21, 2010 | 12:19 PM
djamps's Avatar
djamps
Huh?
Old Oct 21, 2010 | 01:20 PM
  #38
GT-ER's Avatar
GT-ER
Originally Posted by djamps
Huh?
Well, today I took my oil pan cover off and found about 1 pound aluminum gravel. My engine blew up.
Old Oct 21, 2010 | 01:38 PM
  #39
Nexx's Avatar
Nexx
damn... been there and done that. good luck.
liqalu04
Jan 2, 2022 12:58 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Depravity
Oct 1, 2015 04:49 PM
