Building My 06 350Z
Old Nov 4, 2010 | 03:16 PM
Lemans350zTT's Avatar
Lemans350zTT
Default Building My 06 350Z Need input/advice
Whats up guys! So its time for me to build my Z car.
Currently running:
Powerlabs GT35R ST Kit
600cc injectors
Turbo XS Utec
Walboro 255
ETC.. you guys know whats in the kit.
Running HKS true Cat Back with custom revers Y pipe due to single turbo set up to keep the dual exhuast look which I like much more than single.
my goal is to be 500-550whp with the following.
Wiseco piston and ring set.
Eagle connecting rod set.
ACL main bearing set.
ACL rod bearing set.
Engine thrust washers.
ARP main stud kit.
ARP head stud kit.
Engine gasket set.
Do not want to do Cams, fuel system upgrade, or larger injectors. etc...
This is a basic build but I fell I can reach this goal. However there are plenty of much more knowledgable guys and girls out there than me. so with that said
What do you guys/girls think...
Old Nov 4, 2010 | 04:16 PM
IslandZavage's Avatar
IslandZavage
id probably at least upgrade your fuel system...
Old Nov 4, 2010 | 04:21 PM
cdoxp800's Avatar
cdoxp800
I agree. He should look at doing a FRS. Over all it looks good.
Old Nov 4, 2010 | 05:13 PM
rh_334's Avatar
rh_334
you would have a VERY hard time hitting those kind of numbers even with Cams and a fuel system, you might want to reconsider your power goal, or upgrade to the GT37
Old Nov 4, 2010 | 06:58 PM
Lemans350zTT
Whats your guess? I mean I know guys hitting 420-430ish on stock internals stock boost etc... was hoping that atleast 500 would be attainable :-(
Old Nov 4, 2010 | 07:02 PM
Lemans350zTT
I'll look into a fuel system as well. And Thx
Old Nov 6, 2010 | 04:36 AM
james12345pt's Avatar
james12345pt
Meth and an 1.06 AR housing might get you there but you will have the turbo maxed out. Look at a bigger turbo from the get-go and you will be alot happier with the results and possible growth down the road. A bigger turbo from the beginning will be cheaper than experimenting with your current GT35r.
Old Nov 6, 2010 | 01:42 PM
Lemans350zTT
I keep hearing that the turbo is not big enough, however intensepower was able to make 653rwhp with the same kit and from what i was told all they did were larger injectors, cams,fuel upgrade, and ofcourse internals. I honestly didnt think that the turbo would be a problem. I guess it is going to be a waiting game now. already bought the parts car is at the shop now. thanks for the input man
Old Nov 6, 2010 | 01:46 PM
marques1's Avatar
marques1
I believe the car made 653rwhp on meth, big difference.
Old Nov 6, 2010 | 02:01 PM
Cass007's Avatar
Cass007
You are getting some solid advice here. Watch the duty cycle on the injectors as well. Also, I am assuming that your number is a DJ, correct?
Old Nov 6, 2010 | 02:07 PM
Lemans350zTT
Yea i agree guys diff know what they are talking about. Guess i just had to high of hopes. total bummer!!
I guess to much over 500whp isnt exactly very usuable power on a 350z daily driving anyway.
And yea diff talk about a DJ
Old Nov 6, 2010 | 02:09 PM
Lemans350zTT
that i did not know!! and your right that does make all the diff in the world. maybe ill look into meth....
Old Nov 6, 2010 | 04:42 PM
SlideFox's Avatar
SlideFox
I don't think Han's G had Meth?!
Old Nov 6, 2010 | 05:04 PM
Lemans350zTT
I'm really not sure. I just remember talking with them and them telling me that I would be able to get to 500whp easily with just internals. Guess we will see soon. Car should be rdy in bout 2-3 weeks
Old Nov 6, 2010 | 05:10 PM
SlideFox's Avatar
SlideFox
What type of Dyno will it be tuned on? I know there was a lot of controversy with another member because he couldn't make XXXwhp on his DD, but would have easily made his number on a DJ. Simply by the way they read. Just something to keep in mind.
Old Nov 6, 2010 | 05:54 PM
str8dum1's Avatar
str8dum1
a gt35r will only make over 600Dj on full boost and race gas.
You can make 500 on a DJ with a aggro tuned pump gas gt35. I wouldnt drive it like that, but it would be up to you.
Thats a common turbo on 2L 4 bangers. definitely too small for top end a 3.5L V6, esp with that turbine housing. PL chose response over top end. If you already have the PL kit, a good option would be cut off the T3 flange and put a T4 flange on with a divided housing gt40 and a quick spool valve.
You'll make more power with similar response. Otherwise, be happy with the quick spool and stop chasing numbers.
Old Nov 6, 2010 | 06:40 PM
Lemans350zTT
Think my shop has a DD my car currently is running 386whp on his dyno at 8psi was installed and tuned by ray at PFS. have had no issues at all just want more power. Thought 500whp would be easy to get to. figuring out I'm wrong...
Old Nov 6, 2010 | 06:43 PM
Lemans350zTT
This is a good idea. I'll diff talk with my tuner about this on Monday. Thx bro!!!!!!
Old Nov 7, 2010 | 06:54 AM
SlideFox's Avatar
SlideFox
Str8dum makes a good point. Are you trying to make a 500whp street tune with pump or race gas? I do know the 653 Intense made was on C16.
Old Nov 8, 2010 | 10:03 AM
Lemans350zTT
Yea was hoping to get there on pump gas.
