Generally, what's more noticable in a DD?
Old Nov 6, 2010 | 08:03 PM
mazymus's Avatar
mazymus
Default Generally, what's more noticable in a DD?
30 more HP or 30 more Torque?
I could either get Vortech (3.12 pulley) w/ ~390HP/310Trq or for ~$3K more (final cost including install, get HKS SC (modified, not base HKS) w/ ~365HP, 345 Trq.
Above numbers are very rough ideas, my car can definitely put different numbers... I'm just using what I could gather from other posts.
I know Turbo can provide both, but I'm focusing on SC at the moment.
Old Nov 6, 2010 | 08:13 PM
twitch579's Avatar
twitch579
If your really that worried about power then forget about a SC and go turbo. Youll make equal trq and Hp. I have several friends with Vortech SC's with various pulleys and my crappy TN setup eats them for breakfast from any speed. Vortech is easier on a stock block though. But with me, if im spending alot of money I better be going real fast.
Old Nov 6, 2010 | 08:31 PM
mazymus's Avatar
mazymus
It's illegal to have turbos here in Cali, otherwise I'd be ALL over turbos
Old Nov 6, 2010 | 09:20 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
I'd say Torque
Old Nov 6, 2010 | 09:30 PM
streetzlegend's Avatar
streetzlegend
Higher torque hands down is more noticeable daily driving.
Old Nov 7, 2010 | 01:51 AM
Zian's Avatar
Zian
Higher torque is more noticeable on a day-to-day street driven basis, especially since you'll spend more time at lower speeds and feeling acceleration over top-end speed.
Old Nov 7, 2010 | 01:10 AM
_ink's Avatar
_ink
Torque = acceleration which is my vote.
Old Nov 7, 2010 | 05:46 AM
roger22's Avatar
roger22
Many here have turbos in Cali, not a problem at all....
Old Nov 7, 2010 | 05:51 AM
mazymus's Avatar
mazymus
True, but if cops pull you over and give you ref ticket, then you're screwed as you will have to get rid if everything and bring car to stock... It's a chance people take, I just don't want to take . It's prob a very low chance, but all I takes is a cop to hear your bov or suspects you have a turbo and you're down tons of $$$
Old Nov 7, 2010 | 06:01 AM
IslandZavage's Avatar
IslandZavage
Why not just register the car in different state. get a PO box.
Old Nov 7, 2010 | 09:15 AM
We did this 19 months ago but thanks for asking: https://my350z.com/forum/forced-indu...ound-loud.html
Old Nov 7, 2010 | 10:20 AM
mazymus's Avatar
mazymus
seems like a lot of hassle, but I'll look into it more. I think it'll be difficult since I my license is already Cali. I think they want everything to be registered to state in 6 months or so.. but I'll see thanks
Old Nov 7, 2010 | 10:23 AM
jpc350's Avatar
jpc350
Default 928 impeller
3 K for maybe an additional 30 ft lbs seems a bad trade-off..Consider the 2.87 and the 928 impeller for less than a third of 3k and get conservatively about half of the 30 ft-lbs...Of course a dyno tune will be necessary regardles of what you choose...
Old Nov 7, 2010 | 12:04 PM
Alberto's Avatar
Alberto
Cranky FI Owner
TQ is what makes cars fun when not redlining everywhere.
And what most forget is the area under the peak is what makes a huge difference when racing as well, especially when two cars have similiar peaks but way different curves.
Thats why peak numbers dont mean squat to me, look at the curves, especially the TQ thats more important IMO.
Old Nov 7, 2010 | 12:09 PM
mazymus's Avatar
mazymus
I'm Starting to feel this is the way for me to go. Re impeler, I guess I need to get it from 928motorsport and just exchange it out w/ the V3 SC trim? My only reservation would be that te extra 10-15% boost on the stock 03 engine may be too much (2.87 pulley will def not help
I'll dig around and see how people are setting up their cars w the 928 impeller/2.87 pulley. Maybe I should get forged rods?!
Old Nov 7, 2010 | 01:21 PM
str8dum1's Avatar
str8dum1
boost does not equal HP. it took me 17psi on my stock block V3 Si trim vortech to make 460/405 on the dyno dynamics. 17 psi on my turbos was like 550ish on the same dyno.
the new V3's have revised impellers, so you'd even have to see if the 928M ones fit. they were made for V1/V2 SC trims. you'd wanna make sure the volutes didnt change.
Trq is what can make your car undrivable like XKR's car. 2 cars with similar trq peaks would be way offset in HP. more rpms for same trq = faster car, but like you said, probably not as fun on the street without brake boosting.
Old Nov 7, 2010 | 05:23 PM
mazymus's Avatar
mazymus
I do get that boost does not equal HP, and have seen people w/ low boost turbos (~6-7) get low 400 hp.. I guess it's not the pressure, but the overal volume of air that counts (I'm no physicist or mechanic, but I understand the basics of fluid mechanics from medicine somewhat).
Your numbers w/ the 17psi on stock block w/ V3 Si trim are very impressive, but aren't you concerned about the increased pressure on your stock engine? I thought the non-rev engine's weak points were the rods and around 400's hp, (and ~>12-13 boost psi) you would get worried about bents rods. That's why I'm entertaining the idea of HKS SC, which claims to have higher torq for lower boost):
GTM stage 5 for example:
http://www.gtmotorsports.com/product...cat=258&page=1
The kit does cost a penny, but to me seems to deliver pretty descent numbers on the stock engine
http://www.gtmotorsports.com/images/...768_STAGE5.jpg
I could alternatively go for the Stage III which is a bit cheaper and just a bit less torque/hp
If I can get same torque profile w/ the vortech, I would be much more for it. I think there were some dyno's by other people w/ vortech, but from what I remember, they had to have very high boosts to get the torque.
Alternatively, having low compression engine or breathing mods such as header/HFC will prob help reduce the high boost from 2.87 pulley...
There are times when I think I should just sell the car and get a car that already comes w/ turbo But I like the Z's too much to let go
Old Nov 7, 2010 | 09:50 PM
maXmood's Avatar
maXmood
Under Boost!
i remember i saw this on someone's signature (which i like very much), it says: HP is how hard u hit the wall, TQ is how much of the wall u take with you..
seriously tho, TQ is more noticeable than HP.
Old Nov 8, 2010 | 04:26 AM
roger22's Avatar
roger22
true, but if cops pull you over and give you ref ticket, then you're screwed as you will have to get rid if everything and bring car to stock... It's a chance people take, i just don't want to take . It's prob a very low chance, but all i takes is a cop to hear your bov or suspects you have a turbo and you're down tons of $$$
5.0=fail
Old Nov 8, 2010 | 05:00 AM
binder's Avatar
binder
"Horsepower sells cars; Torque wins races" -Carol Shelby
