huge problem. three cylinders not firing
Old Jun 20, 2011 | 02:51 PM
  #141
Eno's Avatar
Eno
Frick do I ever get a sinking feeling when I keep reading this. Op- stand up job gettin on it but dayum I hope you catch a break soon.
Old Jun 23, 2011 | 11:23 PM
  #142
ddc665350ztt's Avatar
ddc665350ztt
Originally Posted by mpickar1
Followed this thread and have a suggestion (didn't see this discussed). I had a similar problem with two cylinders. Your lucky since the engine should not run with 3 bad mis-firing cyclinders. It can't be the timing since some of the cylinders are firing and the. A scope is the best tool for checking, but a VOM will work. With the engine running, disconnect each wire from the suspect injector and check for a pulse. Next check the voltage to the coil packs. If the ECU was disturbed at some time, it could be the connections out of the ECU or piggyback if you are using one. Hope this helps.
Thanks for the help. I checked the voltage to the plugs and they were good. coil packs were swapped with known good packs and I got the same output. If you know a way to disconnect injector plugs one by one while the engine is running please let me know. Cause its impossible with the intake plenum installed. I guess i could remove the plenum, take off the all three injector plugs on bank one, have some type of wires connected to the plugs where i could connect a scope to from an easier location, install the plenum and check them one by one while the cars running that way.
The three cylinders misfiring are all of bank 1, my friend from nissan already ran the consult II and flow tested the injectors. And they checked good.
Old Jun 23, 2011 | 11:30 PM
  #143
ddc665350ztt
also checked the entire engine harness for breaks which took me two full days. and even swapped the ecm which made a pretty deep hole in my pocket with no success. had my nissan tech reprogram the ecu to the key and vehicle an i got the same exact p0300 dtc.....
Old Jun 25, 2011 | 04:21 AM
  #144
ddc665350ztt
Also what was the cause of you problem and how did you fix it? What type of injectors are you running, assuming your injectors went bad since you're suggesting to check the injectors.
Old Jun 25, 2011 | 11:00 AM
  #145
k6750gsxr's Avatar
k6750gsxr
just saw this thread..... I have a similar problem now if you look at my thread. My only happened a couple days ago but have not had time to really diagnose like you. If you figured out any fix please pm me.. thanks .
Old Jun 27, 2011 | 02:00 AM
  #146
mpickar1's Avatar
mpickar1
I have DeatschWerks injectors and found that one of them failed to inject when installed on the car, but worked fine on the bench. Sent all them back and got a replacement that was matched to the others. I found this by removing the plenum and placing a paper towel beneath each injector and turned the engine over. The paper towel was wet under the good injectors but was dry as a bone under the failed one. be carefull not to let the paper towel get into the valves. I got pretty quick at removing and installing the plenum. I also confirmed the failed injector by swapping all the injectors between banks. This moved the problem to the other bank. In my case, I could not smell fuel from the exhaust on that bank which led me to this check.
Old Jun 27, 2011 | 07:33 PM
  #147
rocks's Avatar
rocks
If you look back at my old post from months ago, and I am suprised you did not do what I said. Take the intake manifold off the car. Pull the fuel rails out with the injectors still in them. Have someone hold the fuel rails and watch the injectors while you crank the car. Also pull the coil packs out and crank the car and look for spark, spark plug in is easier. This checking for spark is explained with pictures in the FSM.
On another thought my stupid pos nissan has a Multiple missfire at partial throttle and runs perfect at wot. I think I have a vacum leak from last time I took the intake manifold off but im not sure considering it took months to show up. Either that or its a bad battery, was cranking really slow. Now won't hold a charge. No time to screw with it. I am thinking the battery since its from 2006...
I acutally cut the the wires from the bad injector and ran a jumper wire to the ecu just to make sure it wasnt the wire.
Old Jul 5, 2011 | 11:41 PM
  #148
ddc665350ztt
i could be going crazy here, but i think i need to check the base timing and remove the timing chain cover. Im thinking the chain jumped a tooth on only the drivers bank cam gear. is this to far-fetched? LMK if Im getting to ridiculous with my troubleshooting.
Old Sep 15, 2011 | 01:37 PM
  #149
SH Luciano's Avatar
SH Luciano
what's the word? have you solved the problem? mad props for doing all your own diagnosis.
Old Nov 10, 2011 | 11:36 AM
  #150
ddc665350ztt
im actually deployed right now. i get back in january. so its gonna be a while till i can rip into my engine. in the mean time i'm just researching all the replacement parts/seals ill need. I might as well change the chains if im in there. Im hoping i actually find something wrong this time.
Old Jan 27, 2012 | 05:31 AM
  #151
GWord256's Avatar
GWord256
I just got my catalytic converters replace. Here was my problem.
https://my350z.com/forum/maintenance...eshooting.html
Old Apr 1, 2012 | 10:09 PM
  #152
ddc665350ztt
dont have cats. just test pipes.
thanks for the input tho.
Old May 10, 2012 | 09:36 PM
  #153
devnull420's Avatar
devnull420
Damn just found this thread searching for random misfires and I was really hoping when I got to the end it'd be resolved. Any news?
Old May 12, 2012 | 03:02 AM
  #154
GWord256's Avatar
GWord256
Yes cat's were replaced.
Old Jun 22, 2014 | 05:38 PM
  #155
Glover41's Avatar
Glover41
Sorry for bringing this up from ice age .. howz the car now ?! were you able to find out what was the prob ?!
Old Feb 17, 2022 | 03:51 PM
  #156
kikogod's Avatar
kikogod
Default Problem Solved ? Any Updates ?
im having this same issue with my 06 350z ive done plugs , injectors , coil packs , cleaned maf sensor , cleaned my fuel rail , compression test was good (150) , cylinders 4 and 6 arent firing and 2 is running weak , i dont have any cats , could it be an internal vacuum leak or even something with the exhuast since its starts on the same side as bank 2 which is where my misfires are ?
Old Feb 17, 2022 | 04:59 PM
  #157
travlee's Avatar
travlee
Master
11.5 years since last post in here
Old Feb 18, 2022 | 07:59 AM
  #158
RENFRO's Avatar
RENFRO
What plugs did you get? What gap? What coils? I just had a brand new set of coils go bad after 250 miles. There were not OEM. I've switched back to a hitachi coil and solved my issues.
Old May 4, 2022 | 12:14 AM
  #159
kakaboy's Avatar
kakaboy
Originally Posted by ddc665350ztt
this problem did not happen post spark plug/ coil checkout. so i dont think they are switched. at least one of the cylinders would be firing anyways, if that was the case. if you read back i checked which cylinders were firing by pulling the coils out while the car was running. all the drivers side cylinders had no effect when i pulled the coils. and all the passenger side coils made a noticeable difference when pulling them. i also switched the coils to see if the same thing happened and it did. so all the driver side cylinders are non-contributing cylinders.
This is what started happening to me also, the car has been siting around for a year.
Old May 4, 2022 | 02:38 AM
  #160
travlee's Avatar
travlee
Master
he hasnt logged in for 10 years, dont expect a response from him
