AFR 15 @ Boost! HELP
Old Dec 5, 2010 | 10:30 PM
z_333's Avatar
z_333
Originally Posted by djamps
You're leaning out very badly on your cold starts...
it runs open loop for about 30 sec on cold startup so my guess is your MAF is jacked up or the MAF table itself is totally off. Try setting MAF table back to stock (or HPX if thats what your running) then starting over.
I basically did 80% of my tune on MAF adjustmanets alone starting with cold starts, then idle, then no load revving, then light load, then boost... the fuel comp table is +/- 5% top to bottom.
Are you using HPX or stock? Is it possible if you could post a shot of your MAF adjustment?
All this while I wasn't tuning using the MAF tables but on the fuel & ignition map instead. Guess I've got it wrong. Any link where I can learn and understand more about tuning uprev the right way?
Thanks.
Old Dec 6, 2010 | 10:21 AM
binder's Avatar
binder
check the tuning section or search for threads i have created. I had a few threads about tuning in osiris and questions were answered by Jared at uprev. It's very informative.
Old Dec 6, 2010 | 12:41 PM
djamps's Avatar
djamps
Thanks.
I use HPX but no 2 are alike so there's no point in posting the table... start with the one uprev provides if you're running HPX.
There's nothing 'wrong' with tuning around your MAF (instead of making some adjustments to the MAF) but you can end up with cold/warm start issues, unstable idle, ect ect. I never did have issues in boost though even when I left the MAF table alone. I think you have a bad MAF or bad MAF signal.
Old Dec 11, 2010 | 08:44 AM
z_333's Avatar
z_333
Alright I've did some data logging. Found out that bank 1&2 is leaning out one after the other around the said rpms. Mine Z is a 2003 so I have no wideband as standard. All this while I am relying the AFR from LC-1. Do I have a bad O2 sensor or is it anything worse. This only happen at part throttle. Everything is fine when I go full throttle. Please help
Old Dec 19, 2010 | 06:10 PM
djamps's Avatar
djamps
It is normal to see the voltage from a narrowband bouncing back and forth (at least from my experience).
Old Jan 7, 2011 | 12:17 AM
ddc665350ztt's Avatar
ddc665350ztt
bump for a guy who's going through the same shet ill be going through in a few weeks when i get the uprev tuner.
Old Jan 7, 2011 | 12:18 AM
ddc665350ztt
now im thinking about getting another lc-1 so i can monitor both banks.
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 28, 2015 03:03 AM
Bigsyke
Sep 11, 2015 06:19 PM
