2nd Oil Change With ATI Procharger (10 minutes)
Old Nov 22, 2003 | 04:12 PM
whosdady's Avatar
whosdady
Default 2nd Oil Change With ATI Procharger (10 minutes)
What a difference. It took all of 10 minutes, including opening and closing the hood..
I called ATI and asked if there were any other ways of changing the oil? I know last time some people took off belts, strut bar, ect. Well for those that have already done the first oil change, ATI has a new/easier way for Z's. ATI now sells a syringe type of devise that actually sucks the oil out. It was almost too easy.
I'm sure I'm not the first to use this but for those that didn't know about it, I would call and order it. It's around $10 plus shipping and worth every penny.
By the way I did my second oil change at 3000 miles, the first at 500 miles and it still looked pretty dirty. There were no metal particles but the oil was silver gray in color.
The blower actually seems a little quieter but it could just be in my head.
Old Nov 22, 2003 | 06:56 PM
12SecZ's Avatar
12SecZ
Would a turkey baster type thing work you think or is it proprietary? Good post, I want one. Did you buy more oil? How much is that?
Old Nov 22, 2003 | 07:23 PM
whosdady's Avatar
whosdady
I'm not sure about a turkey baster but my guess would be no
I bought the 3 year deal so I did get extra oil.
Old Nov 22, 2003 | 08:32 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I did mine a little bit ago as well. I don't use the oil sucker though. I had it done in about 25 minutes this time. I think once you do it once it is easier the subsequent times. Mine didn't have any metal the second time but still had that metallic silver color. ATI says this is normal. I got the extra oil with my three year extended warranty as well. I plan on doing mine with my regular engine oil every 3500 miles or so.
Old Nov 22, 2003 | 08:45 PM
12SecZ's Avatar
12SecZ
I guess I will buy the unit too then. Thanks.
Old Nov 23, 2003 | 12:39 PM
G3po's Avatar
G3po
Default oil sucker
you can get "oil suckers" from most Auto stores. most typically used to suck grease out of differentials.
You may also be able to retrofit a FumotoValve oil drain nipple to the SC gearcase, so one hand and a drain hose could provide really easy maintenance. But since I don't know how much clearance or what the drain diameter is? (I don't have the kit_. Just a possible idea....
Old Nov 23, 2003 | 02:35 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
The dipstick hole is very small. Not much room to fit "the sucker" down into. The tubing must be pretty small.
Attached Thumbnails 2nd Oil Change With ATI Procharger (10 minutes)-procharger-oil-change-025.jpg
Old Nov 23, 2003 | 04:54 PM
whosdady's Avatar
whosdady
Dr. Bonz, maybe you remember me posting about extracting the oil a few months ago? I purchased a syringe and tube from Walgreens/Home Depot and retro fitted it together. Needles to say, it didn't work.
The syringe needs to be large enough to make the process worthwhile. If you are forced to suck, then extract per CC, the tool becomes more of a hassel. Also the tubing needs to fit perfectly so it is strong enough to suck the oil out.
Anyway, I highly reccomend the kit. It is worth every penny.
Old Nov 23, 2003 | 05:14 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I remember Daddy. I was responding to the post above by G3po.
Old Nov 24, 2003 | 04:25 PM
G3po's Avatar
G3po
Default oil sucker
Yeh the hole is as small as the one on my KenneBell setup. I just shoved a piece of smaller vaccum hose into the end as a "stepdown".
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
