WHO SAID CAN'T get Flat AFR'S a Vortech FMU
Old Jan 11, 2011 | 03:07 PM
OldManZ350's Avatar
OldManZ350
Default WHO SAID CAN'T get Flat AFR'S a Vortech FMU
Attached is a Log of AFR'S, is this Flat?
What do you Think Tim.......?
Vortech, Walbro, 440cc, FMU, 2.87, 32/28 Conservative Street Tune by TimRod Engineering
Attached Thumbnails WHO SAID CAN'T get Flat AFR'S a Vortech FMU-dynojet-pic.jpg
File Type: pdf
Old Jan 11, 2011 | 03:25 PM
str8dum1's Avatar
str8dum1
why make another thread for this?
Old Jan 11, 2011 | 03:31 PM
OldManZ350's Avatar
OldManZ350
I wanted to post up my street tune, is that OK with you, Str8dum1 ?
Old Jan 11, 2011 | 04:15 PM
str8dum1's Avatar
str8dum1
seems like you wanted to just bust someones *****....
should be in the tuning section anyhow..
Old Jan 11, 2011 | 04:42 PM
OldManZ350's Avatar
OldManZ350
Not at all... Just want to show the Facts.
Also One of the Tuners here asked for Vortech guys to post of their Tunes, so I did.
Old Jan 11, 2011 | 07:51 PM
mazymus's Avatar
mazymus
great numbers man, thanks for posting
what program was used to record that data?
Old Jan 11, 2011 | 08:59 PM
Alberto's Avatar
Alberto
Cranky FI Owner
This community is full of overbuilders and people that want to believe the extra parts they have are needed.
Old Jan 12, 2011 | 09:13 PM
mazymus's Avatar
mazymus
oldmanz, do you have stock engine w/ that setup?
Old Jan 12, 2011 | 09:47 PM
OldManZ350's Avatar
OldManZ350
Totally Stock.....
Old Jan 13, 2011 | 05:54 AM
ramirj2's Avatar
ramirj2
Your A/F ratio looks pretty good and consistent.
Were these logged on a Dynojet?
At the tail pipe or bung pre cat?
I finally installed my Tuner TXS wide band and have not do any data log yet but my A/F ratios at the display are 1 point rich over the ones logged in the dyno.
I had low 11’s on the dyno pull and low 10’s in the wide band.
Should I adjust through the wide band?
Old Jan 13, 2011 | 07:20 AM
OldManZ350's Avatar
OldManZ350
Innovate WideBand, No cats but installed in that area.
What do your exhaust tips look like? black? clean? do you wipe them out often so you can monitor fuel?
Old Jan 13, 2011 | 07:26 AM
350Z_Al's Avatar
350Z_Al
Looks good!
Old Jan 13, 2011 | 07:38 AM
ramirj2's Avatar
ramirj2
Originally Posted by OldManZ350
Innovate WideBand, not cats but installed in that area.
Black and spitting carbon every time I turn the car on.
Old Jan 13, 2011 | 07:55 AM
mazymus's Avatar
mazymus
Nice numbers. I do see that you have >12 AFRS till mid 5k rpms and around boost of 9. Isn't that a bit dangerous on the engine? Obviously your running great on your stock engine.
Old Jan 13, 2011 | 07:56 AM
mazymus's Avatar
mazymus
Makes me want to go 2.87
Old Jan 13, 2011 | 08:03 AM
RetchedOne's Avatar
RetchedOne
I made the same power on my 3.12
Old Jan 13, 2011 | 08:15 AM
OldManZ350's Avatar
OldManZ350
Way to Rich, work on the tuning some more.
Old Jan 13, 2011 | 08:31 AM
mazymus's Avatar
mazymus
I see your car is done! how do you like it?
Old Jan 13, 2011 | 08:33 AM
str8dum1's Avatar
str8dum1
no. 11.8-12.1 is perfect for power and safety. anything richer is leaving power on the table.
Old Jan 13, 2011 | 08:37 AM
OldManZ350's Avatar
OldManZ350
Anything is Possible, but I think that if we were on the Same Dyno on the Same Day and Same Conditions that you would Not say that.
Everything is Relative........
Every Dyno is Different.....
Nobody with 1/2 a brain would Dyno a car in Joe blows Shop in Summer and make say 450whp, make some modifications and then in Winter, Dyno in Sam Tucks Shop and make say 480whp. Then say "I made 30whp with those modifications."
When you can Post Up some 118 MPH Plus Traps on a 80-85 degree day in Humid Florida, Then I will say your making the same power....
But then, all tracks are Different Too. Et can vary .040-.060 and 3-4 mph between tracks
