After 3 years of patiently waiting
Old Jan 25, 2011 | 10:33 AM
usingthejohn's Avatar
usingthejohn
I think I'm ok. I have a revup sedan. Thanks for looking out
Old Jan 25, 2011 | 10:34 AM
usingthejohn
Originally Posted by boosted806
How could you forget the intercooler?
Cause I'm an idiot. I was in a rush to make my 7th drive home hahahah
Old Jan 25, 2011 | 11:09 AM
ADMAN's Avatar
ADMAN
Congrats. And, good luck with the install.
Old Jan 31, 2011 | 12:19 PM
usingthejohn
well, started the install last night. worked on it about 3 hours or so, and just removed the front bumper, intake, undercar shroud things, cats and Y-pipe.
the pictures suck, but forgive me. i took them at 1am.
Old Jan 31, 2011 | 12:34 PM
Barnabas's Avatar
Barnabas
National Z Club President
I dont think those tires will work well on the Z
Old Jan 31, 2011 | 02:43 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Good luck with the install and you will be cussing a lot...and possibly throwing tools.
Old Jan 31, 2011 | 07:21 PM
usingthejohn
those are for my Titan, haha
Thanks...and yes I was cussing tons last night...not quite at the tool throwing level.
Old Jan 31, 2011 | 08:42 PM
ITOzann's Avatar
ITOzann
Best of luck. Props for the DIY!
Old Jan 31, 2011 | 09:02 PM
usingthejohn
OK...need help fellas. i'm trying to install the middle up-pipe, and can't get it through. It looks like the 4-bolt flange is hitting the heat shields on the headers. Do these need to be removed, or am I just a bumbling moron?
rraaaggggeeee
EDIT:
after an hour of searching teh intranetz, i realized i was using the wrong piping for the mid up-pipe....FML
found the right piping, but still couldn't get it to fit the way it was supposed to. Went back to the pictures i previously found, and realized the stock exhaust manifolds have a heat shield on my car, which was A) not found on the other installs, and B) was never mentioned to be removed on the PowerLab instructions.l
took those off, and was able to get the piping in, but now it's hitting the steering column. gonna probably do a big of hammer massaging in the morning to avoid any rubbing, and get the clearance I need. Looks like i only need about 1/4 to 1/2" of additional clearance.
Old Feb 1, 2011 | 04:03 AM
GoJira33's Avatar
GoJira33
Hey man nice to see you making progress. I wanted to give you some guidance on the walbro install if you didnt do it yet. The link I posted is to cj motorsports (CJM). It shows you exactly how to mod your housing for the pump. They also have other helpful fuel system instructions.
http://www.cj-motorsports.com/342install.htm
Hope this helps
Old Feb 1, 2011 | 06:17 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
OP,
What year is your sedan? I think I may know what the issue is regarding fitment with the steering rack.
Old Feb 1, 2011 | 07:49 AM
usingthejohn
Originally Posted by RudeG_v2.0
OP,
I have an 05 revup.
Old Feb 1, 2011 | 09:14 AM
tonyzS/C03's Avatar
tonyzS/C03
keep it up man, i'm interested to hear what you make for final numbers...
Old Feb 1, 2011 | 12:31 PM
thatv35guy's Avatar
thatv35guy
Originally Posted by usingthejohn
EDIT:
It probably wasn't in the instruction cause you don't need to remove the heat shields from the car; my G35 Coupe still has them and so does my brother's 350Z.
Old Feb 1, 2011 | 12:43 PM
usingthejohn
Maybe it's me I'm not sure. No many how many times we tried, the piping was hitting the shields. As soon as I removed it, I was able to get the pipe to fit. But now it hits the steering column. Gonna probably use a hammer for some adjustments if I can't get it to sit properly
Old Feb 1, 2011 | 02:37 PM
GoJira33's Avatar
GoJira33
no dont use a hammer lol. Is it hitting the coupler?? Some kits need the coupler to be swapped out for clearance like the GTM kit.
Old Feb 1, 2011 | 02:46 PM
usingthejohn
I'll have to upload a picture. But it's the actual pipe that's hitting. If you've seen the middle up pipe, it's where one of The bends is.
Old Feb 1, 2011 | 05:30 PM
  #38
usingthejohn
well im close to throwing tools are there differences in the steering rack between G sedans vs coupes? or am i just a bloody idiot hahaha?
Old Feb 1, 2011 | 07:47 PM
  #39
zmedic16's Avatar
zmedic16
There is a difference in steering rack from rev up and non rev up. Find out if your kit was for a rev up motor.... BTW u didn't let me know if u got rid of that hydra. There are different up pipes for rev up n non rev up.
Old Feb 1, 2011 | 08:00 PM
  #40
usingthejohn
The guy who I bought the kit from said it was for a rev-up coupe. But no matter how many times I rotate the piping and/or try different angles in bringing up the piping, a certain section always contacts the steering knuckle. even if i were to hypothetically "massage" that center section jsut to simply fit, i'm sure i'd encounter some serious rubbing.
i don't have a picture of it yet, but compared to the photo i posted, the left section of the piping is different; on this posted photo there appears to be a distinct curve present. the piping i have is just a straight section, with the same curve thats present on the right of the photo. is this the difference you're talking about between revup vs non-revup motors?
Originally Posted by zmedic16
There is a difference in steering rack from rev up and non rev up. Find out if tour kit was for a rev up motor.... BTW u didn't let me know if u got rid of that hydra. There are different up pipes for rev up n non rev up.
that was my fault; it just slipped my mind with everything thats been going on between the install and work. I did sell it for some cash and a UTEC.
