What oil do you use?
Old Feb 3, 2011 | 02:39 PM
Barnabas's Avatar
Barnabas
National Z Club President
good read cass! hmm I wonder at what intervals that type of oil would need to be changed?
Old Feb 4, 2011 | 02:59 PM
superchargedg's Avatar
superchargedg
Damn Noobs
0w40 mobil 1
Old Aug 10, 2011 | 06:03 AM
taywan's Avatar
taywan
im a little late, just cruising around, i use royal purple 5w30, change 3-4k miles
Old Aug 10, 2011 | 06:26 AM
binder's Avatar
binder
rotella 5-40 synthetic. Used in our semi's with over a million miles on them. Used it in all my race bike engines for 15 years now.
There are a couple research projects from universities studying the property of oils and rotella synthetic has rated highest on all that i have read so that's enough evidence to tell me it's a great oil. could there be a better oil, ya, but i trust my results, results from others and the research on it so i'm good with my choice.
The bike race engines are 19k rpm redline and usually don't drop below 16k rpms during races so the oil works pretty good.
Old Aug 10, 2011 | 10:40 AM
psychoballistic's Avatar
psychoballistic
Was personally running 10w-40 of various brands, but recently went to 15w-50 mobil one synthetic to help oil pressure when really heating up the oil... Been pleased so far.
Old Aug 10, 2011 | 12:10 PM
drdave2387's Avatar
drdave2387
Not a big fan of synthetic...when motor was stock I used synthetic and changed oil every 2800miles and not driven hard at all...pulled head when I decided to build the motor and the cams were chewed all to pieces like it had been starved of oil on the heads when I pulled motor cars dipstick still read full and drained 4.75 quarts to be exact, not too bad...so only thing I can think Of was cams were dry when I would start the car up...well replaced cams built the motor and had been running 10w40 regular mobil along with 1/2 quart of Lucas oil stabilizer (HIGHLY Recommended) but pulled motor again to rebuild during last winter and everything was perfectly smooth on the cams and no sign of starvation or wear at all...so I see no benefit to synthetic on a built motor...I recommend 6 1/4 qts regular conventional oil, now running 10w30 and 1/2qt Lucas stabilizer...Also my friend is running this setup on his 1200whp supra for 3 years now and motor with 15k miles on it still going strong as well at the 650whp scion tc we built which has 10k on the motor and still running perfect...
Btw here's a vid of the tc we built, oh and it's my friends girlfriends car she drives daily lol http://m.youtube.com/index?desktop_uri=%2F&gl=US#/home
Old Aug 10, 2011 | 12:15 PM
catdog's Avatar
catdog
Mobil1 10w30/40 whatever is available
Old Aug 11, 2011 | 07:31 AM
binder's Avatar
binder
Could have been something clogging the oil passages in the heads or it could have been a bad machining match from the factory. My oem block had RTV clogging the oil gally on one of my cams so they aren't always goign to do a great job assembling them at the factory.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
