LS2 350z Stage 3? =)
Old Mar 10, 2011 | 09:49 AM
  #81
SnyperZ's Avatar
SnyperZ
Originally Posted by str8dum1
i run a 28" tire at the strip all the time with no problem and the car is pretty low. its nowhere near as wide though as a 325 which will be the bigger issue.
Theres no issue at all. Last year I ran 325/45/17s(which are the exact same size tire as a 325/40/18) with 0 issues. The rims/tires actually sat inside the fenders a little. I had my fenders lightly stretched and since im not running a coil over setup, ill have some room to spare. The only issue like mentioned above is the ride is a little "soft" with such a tall sidewall tire. Unfortunately, I have no choice but to run a tire that size or id be lucky to beat a stock honda from all the tire spin.
Old Mar 10, 2011 | 01:42 PM
  #82
scotts300's Avatar
scotts300
Awesome!
Actually, the 325/40/17 is about 1/4" taller than the 325/40/18! I run a Mickey Thompson ET Street, I know what you mean about the "soft" ride with the tall sidewall.
Old Mar 10, 2011 | 03:58 PM
  #83
litoflow's Avatar
litoflow
Yeah this beast does spin like a little BitsH! lol. Its super loud and annoying, i cant wait to smoke you while you run your street tires and i run my skinny jeans hahaha :P
Looking sick homie, cant wait to see it in the streets soon. Weather is getting better, after all this rain the salt should be washed off, get that z ready son!!!
Old Mar 10, 2011 | 05:18 PM
  #84
SnyperZ's Avatar
SnyperZ
Yeah, it will come together really quick. I torqued the heads down today..only thing left on the engine is install the oil pick up, windage tray, pushrods, lifters and all the covers.
Old Mar 12, 2011 | 06:25 PM
  #85
SnyperZ's Avatar
SnyperZ
The engine is all together. Just need to torque down the rocker arms which ill do once the engine is in the car(to keep the valves closed and any **** out of the engine) Since everything in the engine bay is going to be black I figured id off set it a little with a wrinkle red compressor cover and valve covers.
Old Mar 13, 2011 | 06:08 AM
  #86
Quamen's Avatar
Quamen
Just not feeling the whole LS swap thing...
Looking great! Can't wait to see what she puts down at over 20psi!
Old Mar 13, 2011 | 08:49 AM
  #87
Vas_Z33's Avatar
Vas_Z33
is that the Nick Williams 102mm electronic tb?
Old Mar 13, 2011 | 10:21 AM
  #88
SnyperZ's Avatar
SnyperZ
No. I was going to get it but then I heard people had tuning issues with it. And for FI, I don't really think its needed. Maybe next year when I have nothing left to do to the car ill start adding things like that. But for this year the 90 will do just fine.
Old Mar 15, 2011 | 06:44 PM
  #89
bbs350z's Avatar
bbs350z
snyper, howd you go about getting the ecus to communicate? you did the CAN correct? also are you using both ecu's? or just the ls ecu. im doing throttle cable so im unsure if a can will work with a z ecu communicating to an e38 ecu
Old Mar 15, 2011 | 10:59 PM
  #90
SnyperZ's Avatar
SnyperZ
Both Ecus are standalone. The NISSAN ecu is in the car to control whatever its supposed to in the car and the E40 ECU controls the engine.
Old Mar 15, 2011 | 11:00 PM
  #91
SnyperZ's Avatar
SnyperZ
Got a lot of work done tonight. Welded little block off plates in the holes where the old harness and wires used to go through, sanded and painted the engine bay, bled the clutch, finished the wiring, mounted the engine in place, ect. Not much more to go as far as getting it running. I still have to finish the front end and mount the radiator and new lines. Ive decided to put an oil cooler on the car to help with temps. The cooler will be mounted in the driver side well in front of the tire.
Old Mar 15, 2011 | 11:12 PM
  #92
bbs350z's Avatar
bbs350z
and you synced them together with the CAN correct? would you happen to know if that would work with an e38 ecu by chance?
Old Mar 15, 2011 | 11:21 PM
  #93
SnyperZ's Avatar
SnyperZ
No. They are both standalone. They don't have to be linked to eachother. The only responsibility of the GMECU is to control the engine. It has nothing to do with the car itself. All the gauges work off the car itself minus the tach and water temp gauge.
Old Mar 16, 2011 | 12:19 AM
  #94
bbs350z's Avatar
bbs350z
ahh, so how did you get power to the ls motor? i would assume just connecting the starter to the battery?
did you leave the nissan engine harness plugged into the ecu? did you modify the nissan harness at all?
sorry for the questions, wirings not my thing, i hate it lol
Old Mar 16, 2011 | 03:54 AM
  #95
Quamen's Avatar
Quamen
Do you still run your fender liners sniper?
Old Mar 16, 2011 | 10:01 AM
  #96
SnyperZ's Avatar
SnyperZ
Absolutely. And if you want to keep your front bumper in one piece and not have the wheels eat it, you should too haha. I have them off because of the wire tuck. I have the wires running on the inside of the fenders.
Old Mar 18, 2011 | 07:48 AM
  #97
GBoger's Avatar
GBoger
which boost controller are you going with for the boost by mph?
Old Mar 18, 2011 | 09:20 AM
  #98
SnyperZ's Avatar
SnyperZ
Eboost2 with twin 4port solenoids and a custom box by gsspeed.
Old Mar 21, 2011 | 10:26 AM
  #99
Vas_Z33's Avatar
Vas_Z33
Mark, what did you use to tune it when you were NA? I got everything coming.. i just need a tuning solution
Old Mar 21, 2011 | 10:47 AM
  #100
thePunkville's Avatar
thePunkville
im new to this... did you make your own kit or buy one?
