APS single turbo, want to build motor
Old Feb 12, 2011 | 01:01 PM
travismaser's Avatar
travismaser
Default APS single turbo, want to build motor
Hey guys, iv been driving my Z for about 2 years now on stock internals and the APS single turbo kit with the GTM single upgrade kit (pretty much throws a true GT35R on it)...since I upgraded, the car runs WAY better (made 408whp on stock internals and the stock tune on the unichip)...there has been zero tuning work on the car...it runs great, I run it how it should be and have daily driven it for 2 years...but since I did the upgrade kit, I havnt been able to run a filter because there just isn't any room to run an intake...it does have a screen covering it...but I'm scared that's just not enough..
My question for you guys is, what should I do?? I want to buy a built short block (looking at forged performance) but is it worth it...I'm going to have to figure out some sort of intake...
Or should I just keep saving for a 2jz swap?...2j swaps going to cost somewhere close to 10grand after single turbo and tuning...
Old Feb 12, 2011 | 01:30 PM
graffkid732's Avatar
graffkid732
I say build it. I am not a fan of most swaps if it is not needed in the car. How much power are you looking for?
Old Feb 12, 2011 | 01:32 PM
travismaser
I'm looking for a very respectable dd....and a better tuning software haha...I hate the unichip... id love to hit 500hp, or close to that
Old Feb 12, 2011 | 01:35 PM
travismaser
But mainly I need to fix my no filter problem and build the internals....or go in a whole new direction with a swap
Old Feb 12, 2011 | 01:49 PM
graffkid732
If you're only looking for 500, I honestly would keep the VQ, build it and go from there. Do you have pics of your set up? No one will be able to throw ideas of we can't see it what is going on.
Old Feb 12, 2011 | 01:51 PM
ttg35fort's Avatar
ttg35fort
Professional
Can you change the intake piping so that you can locate the intake in a location where you can use a filter? If so, I would look at doing this.
If you are going to go through the trouble of doing a swap (it is a lot of work), I would look at a swap to an LS3 motor. As the saying goes, there is no replacement for displacement. And, the LS3 only weighs about 100 lb. more than the VQ35. I think SnyperZ's LS2 build is pretty impressive.
https://my350z.com/forum/forced-indu...stage-3-a.html
There is a kit for doing LS swaps into the 350Z, I just don't remember who provides it.
The LS3 is aluminum, but there is much more structural support around the cylinders than on the VQ35. It has serious power potential. If you want to go ***** to the wall, an LSX is an iron block with quite a few more head studs. It will take a LOT of boost, though it is heavier than the LS3.
travismaser
I'm on my phone right now...as soo as I'm home ill post the couple pics I have....my turbo sits right up against the stearing rack....under the pedals beside the trans....really crappy spot
Old Feb 12, 2011 | 02:00 PM
erichsherrill's Avatar
erichsherrill
kyle at IPP.. nice guy
http://www.importpartspro.com/st1blon.html
Old Feb 12, 2011 | 02:01 PM
ttg35fort's Avatar
ttg35fort
Professional
Old Feb 12, 2011 | 02:17 PM
str8dum1's Avatar
str8dum1
built motor and a GT35 is a waste of money. a ton of expense and projected unreliability for 80-90 more hp.
If you are going with a built motor, dump that turbo kit and get a greddy or something that can make more HP with less stress on the turbo.
Old Feb 12, 2011 | 02:38 PM
travismaser
I like the idea...but to do that would cost me another 8g on a turbo setup....with that much in the car I might as well just drop a 2j in it....yes or no?
Old Feb 12, 2011 | 03:27 PM
ttg35fort's Avatar
ttg35fort
Professional
I would look to see if there are any kits offered for dropping the 2j into the 350Z. If not, you will be fabricating your own kit.
Note, the 2J is a heavy motor (cast iron straight 6), which will offset your weight distribution quite a bit. If you are not that concerned about handling, it may be a non-issue.
The VQ35DE is about 330 lbs, whereas the 2JZ is nearly double that at about 594 lbs. An LS3 is somewhere around 415 lbs.
http://wiki.answers.com/Q/What_is_th...ota_2jz_engine
http://wiki.answers.com/Q/What_is_th...let_LS3_engine
I think even the LSX is lighter than the 2JZ, and is capable of a LOT of torque/HP.
http://www.streetfire.net/video/lsx-...yno_168394.htm
Old Feb 12, 2011 | 03:35 PM
jerryd87's Avatar
jerryd87
Im not super familiar with the 2jz but the last i researched the single turbo swap on the 2jz alone cost 10k and thats if you already have a 2jzgte installed in your platform. Quick search online shows a jdm spec 2jz with trans,harness and computer is another 3400 even though computer isnt needed still need the harness. Figure all the custom fab work to install it plus mods to fuel system for single turbo system to work another 3k unless you do it mostly yourself. These are just estimates but unless something has changed from 2 years ago(which it probably has but i can imagine by much) when i checked out swapping a 2jz into a 240 your looking at roughly 16-17k for 500hp although system should support more with a little extra invested.
In comparison ive estimated roughly the same for 700hp from the vq35de with sasha's 6765 turbo kit, custom fuel system built by me with parts from various sources, meth kit, cosworth intake, headers, jwt cams, haltech, coolant system upgrade, and ipp stage 2 block with hks head gaskets, ip girdle, and arp l19 head studs.
granted im just sourcing parts atm and ordering, it wont actually go togeather until next year when i get back from deployment we will see what i actually make then.
Old Feb 12, 2011 | 03:47 PM
travismaser
I can do the 2jz swap with everything for under 10g thru my sponsor (www.shiftedperformance.com)...and the short block id do myself....
Old Feb 12, 2011 | 04:42 PM
str8dum1's Avatar
str8dum1
a turbo'd LS swap makes a ton more sense. its a 6L v8. theres a cheap production kit to do it. LS motors are super easy to source and domestic aftermarket parts are way cheap.
JDM upgrades are much more $$ than USDM. A 88mm turbo on a LS2 swap will cost about 1/2 what it would to properly build a 2JZ. read supraforums. Big hp cars there are just as expensive as a VQ. Then read vette/G8/etc forums and see how cheap they can make 800+whp.
Old Feb 12, 2011 | 04:58 PM
ttg35fort's Avatar
ttg35fort
Professional
+1000
Old Feb 12, 2011 | 05:21 PM
travismaser
You know, iv thought about an LS swap...and my buddy owns a shop here in pittsburgh and he mainly only does ls1 swaps....but I kinda wana be different then all my buddys with their chevys..haha...I know the ls1 has a lot of potantial...but I kinda wana stay turbo import....
Old Feb 12, 2011 | 05:23 PM
IslandZavage's Avatar
IslandZavage
tech2motorsports.com makes 2jz swap kits for the Z..
Old Feb 12, 2011 | 05:26 PM
IslandZavage
if all else fails i'll be going this route...
Old Feb 12, 2011 | 05:31 PM
ttg35fort's Avatar
ttg35fort
Professional
Being different is cool. As I have said before to other people, it is your car and your money. DO IT, and let us know how it turns out.
