Couple questions about built motor
Old Feb 25, 2011 | 11:50 AM
  #41
ttg35fort's Avatar
ttg35fort
Professional
Thank you, Kyle!
Old Feb 25, 2011 | 01:02 PM
  #42
ggutierrez's Avatar
ggutierrez
hey i was just wondering about rod bearings.
can someone explain the dif sizes,
pros and cons.
also ive been told alot to use the OEM ones.
engine lab in tampa is going todo all my machine work and have agreed to custom fit the OEMs to proper fit,so should i stick to those or upgrade to ACLs
Old Feb 28, 2011 | 01:28 PM
  #43
Zquicksilver's Avatar
Zquicksilver
Originally Posted by SuperBlack350z
i want to ask here because it seems all of the smarter gear heads are here with experience. Please don't flame. i just want some direct answers.
I want to get a built motor from IPP. Their stage one seems to be affordable.
http://www.importpartspro.com/st1vqloblni3.html
Wiseco Pistons .020 over
Eagle/SCAT H Beam Rods
ARP Rod Bolts
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Block prepped and assembled
New OEM Head Gaskets
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
3 angle valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for stock cams
Heads prepped and assembled
New OEM Rev-up Oil Pump
OP, the deal from IPP seems very reasonable... unless I'm missing something!?
GTM basic longblock build:$5799
Labor:
Teardown inspection and cleaning of the core
Cleaning and Inspecting Cylinder heads
Mag and micro polishing of the crankshaft
Balancing of the rotating assembly
Resurfacing (decking) of the block
Boring and honing of the block (with a torque plate)
Assembly of the long block
Fully timed and ready to drop in
Parts:
Wiseco®/GTM® Extreme Duty pistons
Eagle® rods (with their alignment and resizing)
Rear main seal assembly
OEM bearings
ARP® 8740 main studs
ARP® 2000 11mm head studs (torqued to 85ft. lbs.)
OEM Rev-Up Oil Pump
OEM Oil pick up screen
OEM Camshaft Bolt seals
OEM Engine Gasket Set
I'm also considering a rebuild. I've got 115k on my 04 350Z and considering going FI (supercharged to be exact) at somepoint thereafter. I'm not a fan of the turbo torque curve, never have been, but I guess it's what makes our FI community diverse I also plan to stay 10.3:1 on the compression, just in case I decide to remove the FI setup and go strictly NA.
I'm a noob to all of this and learning...
Zquicksilver
Old Feb 28, 2011 | 02:33 PM
  #44
Cass007's Avatar
Cass007
LOL... Dipping a toe in the F/I kiddie pool.
I'd say it definitely is, but nothing is safe if you plan on beating on it every day. I'll hit full boost in my car maybe once a month.
Careful Chris, you may have your F/I posting privileges suspended. I hit full boost every time the car leaves the garage.... maybe thats why it doesn't run very much before blowing up
Old Feb 28, 2011 | 02:42 PM
  #45
Zquicksilver
^ why yes i am...
if SC'd gets me to 400whp with a very linear trq. curve on my non DD, then i'm good with that.
i've beaten the **** out of my Z for 115k glorious n/a miles... it's time to upgrade, or at least get my Z to feel like it has a small V8 in it. besides... i'm tired of 335i's rolling on me at every light
Zquicksilver
Old Feb 28, 2011 | 03:38 PM
  #46
chrisjersey06's Avatar
chrisjersey06
Hah, well if you lived around my area you'd understand. Its not smart to do high speed runs because the highway is littered with police, and clocking a Z at 100+ would make their day. There is also a police helicopter in the air on nice days that catches your speed and then they send the registered owner a citation in the mail! (Just to show you how hardcore they are about catching speeders.) There really are no straight enough sections to do that on anyway. Around town, the tires just spin in 1st, 2nd, and sometimes even 3rd, and that's not fun to me. These RE-11's aren't cheap either! The only times I get to have "fun" are coming out of toll booths, and sometimes a short burst off an onramp when there's nobody in front of me (which there usually always is during the hours that I travel). If I wanted to go do a pull right now, I don't even know where I would go aside from driving an hour or more away. Not a great place to live with a car like this!
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
35reilly
Sep 28, 2015 07:42 AM
codek
Sep 28, 2015 03:03 AM
