Any interest in a SS catch can?
Old Mar 7, 2011 | 11:27 AM
  #41
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by str8dum1
told ya that catch cans would be easy money! Shops charging 3-400$ for a box with a baffle and some weld on fittings almost as insane as a person able to justify paying that.
Yeah, that is true. I just need to find some stainless -6 or -8 stainless weld on male bungs.
That is the hold up at the moment.
Old Mar 7, 2011 | 11:34 AM
  #42
Barnabas's Avatar
Barnabas
National Z Club President
Check out here I had very good luck on pricing and parts when I did my oil cooler setup.
http://www.racerpartswholesale.com/c...oPipeAdapters2
Old Mar 7, 2011 | 01:24 PM
  #43
Boosted Performance
Well, a local buddy came through once again:
http://www.summitracing.com/parts/AR...8212/?rtype=10
Thanks Travis.
These are steel, but not coated. Will be easy to weld, and look very good.
The price will go up a bit do the the price of all the fittings, but not much.
Old Mar 7, 2011 | 01:36 PM
  #44
suprasam's Avatar
suprasam
yeah, the idea of welded bungs instead of welded fittings is awesome.
Old Mar 7, 2011 | 05:12 PM
  #45
binder's Avatar
binder
summit has all when it comes to parts.
Old Mar 7, 2011 | 05:25 PM
  #46
jruocco's Avatar
jruocco
I am very interested, one of the next things I want to pick up
Old Mar 8, 2011 | 05:00 AM
  #47
rcdash's Avatar
rcdash
Being able to accomodate 1/2" hose would be good. Love the design. I would personally stick to npt ports as fittings are cheap and easy to come by but can always get adapters I guess.
Old Mar 8, 2011 | 05:07 AM
  #48
GreenGoblin's Avatar
GreenGoblin
Sasha just a welding geek question, are you back purging them?
Old Mar 8, 2011 | 05:30 AM
  #49
Boosted Performance
The one pictured was not purged, and there is no sugaring on the inside. If you hve the amperage turned down, you will not burn through...ever. So the inside is nice an clean.
I back purge all the exhaust stuff on the turbo kits, because here I need good penetration, and a solid weld all around. That is why I say that you will never see my exhaust welds crack.
Old Mar 8, 2011 | 06:39 AM
  #50
Barnabas's Avatar
Barnabas
sasha do you make Test Pipes as well?
Old Mar 8, 2011 | 07:36 AM
  #51
Boosted Performance
I don't but I could. At times I wish I didn't have a great day time job, so I can spend more time doing this stuff.
Old Mar 8, 2011 | 07:45 AM
  #52
Barnabas's Avatar
Barnabas
Just had been thinking about goign to a 3" exhaust and there arent allot of options for 2.5 - 3" TP's or even just straight 3" for that matter.
Old Mar 8, 2011 | 09:37 AM
  #53
binder's Avatar
binder
2.5" test pipes are easy to find.
Old Mar 8, 2011 | 09:47 AM
  #54
VQ35deMax's Avatar
VQ35deMax
I would be interested in just the can without any hoses.
Old Mar 8, 2011 | 10:05 AM
  #55
Barnabas's Avatar
Barnabas
I have 2.5's I meant as in Test pipes that i can mate to my current FI system that is 2.5" but opens up to a 3" for a 3" exhaust.
Old Mar 15, 2011 | 05:11 PM
  #56
Boosted Performance
Well, I finally got around to mounting this catch can. It seems that most of the catch cans out there get mounted somwhwere in the front of the engine or on top of the radiator shroud. It makes sense, as this is the half way point between the most common valve cover vents. I followed suit.
Rather simple bracket welded on:
Mounted:
These are 3/8" NPT fittings and again there is 4 of them for this specific application. If this goes in to production there will be two ports with a breather on top or something like that.
Old Mar 15, 2011 | 05:26 PM
  #57
Barnabas's Avatar
Barnabas
can you attach a couple of them?? I cant view photobucket at work ;(
Old Mar 15, 2011 | 06:05 PM
  #58
suprasam's Avatar
suprasam
looks good sasha. I could do with the 4 ports for more custom usage.
Old Mar 16, 2011 | 04:08 AM
  #59
rh_334's Avatar
rh_334
Nice work!
Any chance you could make an ARC type can as far as the style and mounting location?
Old Mar 16, 2011 | 07:22 AM
  #60
ace32x's Avatar
ace32x
not to take this off topic, but id be interested in a set of true 3" test pipes aswell, using the aam 2.5"s and theyre my choke point atm : /
