Motordyne TDX w/ built block and turbos?
Old Apr 19, 2011 | 08:46 AM
rcdash's Avatar
rcdash
Very mellow - slightly louder than stock maybe (don't really remember "stock" anymore!). At WOT they are still quieter than the v2 shockwave but obviously they are both straight through pipes at that point, so both way louder than stock. Still, I suspect it will be too quiet for most folks. I like the fact that I can now listen to music at low volume levels and use bluetooth to carry on phone conversations without issue cruising around town.
Old Apr 19, 2011 | 03:13 PM
suprasam's Avatar
suprasam
Originally Posted by rcdash
Replaced the axle back from the v-band flange. I got some weld-able v-band flanges from Tony and the above mufflers and clamps from Summit Racing and my exhaust shop did the rest (for $300).
I'll be at ZdayZ and the airstrip if you want to see/hear them in person. Although there shouldn't be a performance hit (and I don't feel any difference), until I dyno the two (shockwave v2 vs Dynomax VT) I won't know for sure. So I'm not selling my v2 until I get that done.
I'll be gone by the time zdayz rolls up. Raj, I love all of your experimentation.
Old Apr 19, 2011 | 09:56 PM
Everybodywildou's Avatar
Everybodywildou
Soooo nobody has the TDX v2 on their built block turbo setup?? lol
Old Apr 20, 2011 | 05:09 AM
rcdash's Avatar
rcdash
I do.
Old Apr 20, 2011 | 09:26 AM
Honda2Nismo's Avatar
Honda2Nismo
Built and boosted with NVIDIA and you can't hear my car at all until the wastegates open.
Old Apr 20, 2011 | 10:06 AM
Everybodywildou
I do.
Oh haha. So it wasn't the full 3" setup correct?
Old Apr 20, 2011 | 07:03 PM
rcdash's Avatar
rcdash
I've had both. First I had the 2.5" primaries that opened up to 3" and then I got the full 3" set up. They are quite different set ups. The 2.5" uses the XYZ pipe that takes 2.5" pipes that come together to form a single 3.5" or 4" pipe and that single goes into a muffler that splits out tp two 2.5" pipes that then expand to 3". The 3" uses separate 3" pipes that goes to a dual 3" in/out X pipe muffler.
I also went from the shockwave v1 axle back to the v2 and now also have had a custom muffler axle back set up fabricated...
Old Apr 20, 2011 | 10:32 PM
Everybodywildou
How did the full 3" sound? How loud was it? Does it really not have any drone? How is it when cruising on the highway? Tolerable?
Old Apr 21, 2011 | 05:39 AM
rcdash's Avatar
rcdash
The sound for both versions really depend on the axle back components you put on it. The shockwave v2 (with the side resonators) is a very clean tone, modest at cruise but loud at WOT and no drone to speak of. The shockwave v1 is similar to the v2 but it has significant drone below 2500 rpms. My new custom Dynomax VT axle back has no drone, is very quiet at idle and cruise, and moderate at WOT (i.e. quieter all around).
I think 95% of folks will love the TDX 3" with shockwave v2 axle back. I'm very conservative when it comes to noise and although it is still a bit too loud for me, it is a wonderful note for spirited runs.
Old May 17, 2011 | 10:56 AM
Everybodywildou
I bit the bullet and ended up purchasing the Full 3" TDX v2 for my G35 coupe. I'm just hoping it wont be too loud when cruising on the highway at 80ish. Do you think it might be an issue?
Old May 17, 2011 | 12:40 PM
djamps's Avatar
djamps
Anyone concerned with noise shouldn't do 3" piping.
Old May 17, 2011 | 01:50 PM
Everybodywildou
whoops? Lol. This is the only video I could find.
http://vimeo.com/11722634
Old May 17, 2011 | 02:23 PM
rcdash's Avatar
rcdash
I think highway cruising with the v2 is very mild. Getting rid of drone is key! After having some time with the Dynomax VT, I will say that there is a definite small hit in performance. Turbos spool slower and max power is down about 15 whp - not bad but it's there and it's across the rpm range.
Old Sep 18, 2011 | 11:52 AM
Tanman1986's Avatar
Tanman1986
Not bad at all! in not a fan of the new nismos body but she sure is clean and sounds great!
Old Sep 21, 2011 | 09:10 AM
Resmarted's Avatar
Resmarted
thing sounds way clean. I like.
Recirc wastgates ftw
Old Sep 25, 2011 | 05:26 PM
kaminariZ's Avatar
kaminariZ
would you guys recommend one of these mufflers on a NA Z? i want to buy the single 3" and dual outlet and get it fitted in the position that the stock muffler sits in. thoughts?
Old Sep 26, 2011 | 11:04 PM
Everybodywildou
Umm just the muffler? Why not just buy the whole system and have a sweet dual setup. The exhaust sounds like a beast on my car. Especially with the cams.
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
Nihsnek
Dec 20, 2007 02:10 PM
GurgenPB
Feb 20, 2006 06:43 AM
XBS
Dec 27, 2005 08:56 PM
