Osiris and base Z
Old Apr 28, 2011 | 07:49 PM
ace32x's Avatar
ace32x
Default Osiris and base Z
got a base z thats pretty much had everything swapped out, its a HR TT tuned with osiris. problem being i can only run one map being as i do not have cruise control. my question is for anyone who might have some knowledge on the subject. Is the ecu capable of getting the cruise control wires and hooking them up or just sticking a wheel on that had cruise control and is all wired up for it. Not sure if the base is compatable with that or not
Old Apr 28, 2011 | 10:15 PM
hellsoldiers08's Avatar
hellsoldiers08
i remember reading a thread on this. I think the person did it but wasnt able to get cruise control working because of the sensors needed for it or something. I wanna say your idea should be sound but i cant give you a 100% answer. I would wait for more of the experience members to response to give you a better answer.
Old Apr 28, 2011 | 10:17 PM
jookyshank's Avatar
jookyshank
Hey Mo
Couldn't you just wire in a momentary switch to a diff system and achieve the same effect? Just sayin
Old Apr 29, 2011 | 05:59 AM
djamps's Avatar
djamps
Originally Posted by jookyshank
Hey Mo
I think there's a mux in the steering wheel then a serial feed into the BCM which then sends the signals over the CAN bus... so I don't think it's that simple! But I do think it's possible to retrofit the system...just not as simple as it might seem. I think you need the upper clutch switch as well...
Old Apr 29, 2011 | 07:25 AM
nathanwl2004's Avatar
nathanwl2004
would you need this to simply use the map selection and not the cruise function?
Old Apr 29, 2011 | 09:14 AM
djamps's Avatar
djamps
Guess not... I just tried switching maps with clutch in and out and it didn't matter. In fact, I'm considering hooking my clutch switch up to the 'cancel' button somehow so I can have true launch control
https://my350z.com/forum/forced-indu...ere-close.html
Actually having enough traction to be useful, that's another story altogether haha
Old Apr 29, 2011 | 10:21 AM
ace32x's Avatar
ace32x
hmm, so the ecu's are the same and will be able to set up somethingto connect the line in. just making sure there is actually some where to hook it up or that the ecu will read it. been told the ecu varies between base and other models since there is some other features it doesnt have
Old May 1, 2011 | 08:19 AM
ace32x's Avatar
ace32x
bump for someone who might have an idea
Old May 1, 2011 | 08:33 AM
=Cerberus='s Avatar
=Cerberus=
I don't know if you noticed, but Uprev talks about this on their site. They say they can help with the wiring to get map switching.
Old May 1, 2011 | 08:51 AM
ace32x's Avatar
ace32x
i asked on thier site they said they didnt know and people who claim to have done it never show them diagrams so they werent sure : /
Old May 1, 2011 | 10:21 AM
Boostguru's Avatar
Boostguru
in for info! Also on a base model soon to be uprev'd.
I'd love to see this done via a momentary switch, i'd be a pioneer but half of anything electronic is my weak spot.
Old May 1, 2011 | 12:45 PM
ace32x's Avatar
ace32x
i wouldnt care really, but with the new build gonna be doing i want a c16 map and a hi and low boost map : /
Old May 1, 2011 | 05:23 PM
Barnabas's Avatar
Barnabas
National Z Club President
I am having this problem as well. I have hit a brick wall as far as figuring out a way to make it work.
In theory though if the proper ohm's could be had for the cruise control buttons, you could wire in a generic switch with the selector set to fire off specific ohm signals and be able to make a small module that would work as a map selector.
Old May 3, 2011 | 02:27 AM
nismo1234's Avatar
nismo1234
well i figured it all out and i got it working on my car, it allows you to switch maps through steering wheel. i am working one developing a kit to make this all work which hopefully would go on sale soon. but unfortunatly i didnt have enough time to put together a diy but hopefully i can get it done soon.
Old May 3, 2011 | 04:49 AM
Barnabas's Avatar
Barnabas
What about with afteemarket wheels? Can you do it as an external Switch?
Old May 3, 2011 | 09:21 AM
nismo1234's Avatar
nismo1234
Wheels don't have anything to do with cruise control and the way I did it was through the factory switches which go on the factory steering wheel.
Old May 3, 2011 | 10:00 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
^^I think he meant aftermarket steering wheels..
Old May 3, 2011 | 10:08 AM
nismo1234's Avatar
nismo1234
https://my350z.com/forum/showthread....Cruise+control
This diy would be used for the relocation.
Old May 3, 2011 | 10:49 AM
ace32x's Avatar
ace32x
im not talking about aftermarket. im refering to the base model not having cruise control of any sort. was wondering if a wheel with all it already was a possible plug and play, or if it was even possible to wire it into the ecu on a base vs the ecu on a different model. been told they were different being as the base has no abs traction control or cruise control
Old May 3, 2011 | 05:31 PM
Barnabas's Avatar
Barnabas
this! I have a base model as well. No buttons on the steering wheel at all. Now I have aftermarket steering wheel soo even less. lol
