High Idle - Suggestions required
Old May 25, 2011 | 05:51 PM
  #61
ddc665350ztt's Avatar
ddc665350ztt
AWESOME! congratulations on the fix. glad it was simple.
Old May 25, 2011 | 06:29 PM
  #62
djamps's Avatar
djamps
Old May 25, 2011 | 07:31 PM
  #63
binder's Avatar
binder
never would have guessed that. good job getting it fixed!
Old May 26, 2011 | 02:12 PM
  #64
pez1111's Avatar
pez1111
Good on ya Mike. Maybe we should meet up at the Longueville for brew to celebrate.
Old May 26, 2011 | 03:56 PM
  #65
rcdash's Avatar
rcdash
Originally Posted by MR RIZK
yes the sensor goes only one way into the tube but i have an adapter on the pipe which was part of the hks kit which allows the tube to sit in either direction. So maf was installed correctly but tube wrong way around.
If you go into the haltech Main Configuration > inputs outputs tab > Mass Air Flow Settings
Once you set it to "MAF Output Table" then the "Copy through settings" are highlighted in RED meaning it is not set correctly. See image below
Well that is unfortunate. Ah well, one less "mod" to consider.
Old May 26, 2011 | 05:46 PM
  #66
_ink's Avatar
_ink
FAr out!!!! FINALLY!!
Well done Mike!!!!!
Finally got there!!!
