Vortech install update (G35s)
Old Dec 10, 2003 | 05:44 PM
  #41
zimbo's Avatar
zimbo
Default Re: Re: Sounds
Originally posted by blubyu
Thats if Steve doesn't mind me videoing his car
Don't mind at all.
--Steve
Old Dec 10, 2003 | 05:47 PM
  #42
zimbo's Avatar
zimbo
Default Re: Sounds
Originally posted by G3po
Does the PCV vent in to tract after Air filter or is there and external breather?
I'm trying to figure out the gist of this question
--Steve
Old Dec 10, 2003 | 06:18 PM
  #43
fastvtecCL's Avatar
fastvtecCL
matt,
thanks for posting and helping me keep steve and others informed
steve like matt said the car was runing about 8pm tonight.... we are going to put it on the dyno tomorrow and see how much tuning it's going to need.. i'll give you a call in the morning some time.....
dyno sheets will also be posted tomorrow...
ps... if anyone else is intrested in supercharging there SEDAN, COUPE or 350Z... give me a call at work 704-527-0123 keith
(we are also in the process of becoming a sponcer for the site)
Old Dec 11, 2003 | 08:57 AM
  #44
G3po's Avatar
G3po
Default PCV / oil breather setup
I guess the question was miss worded, I mean't were is the crankcase breather inlet located? Open air or tapped between Air filter vs. Compressor inlet? Only reason I asked was that the way ATI has it on thier G35 "kit" is via open air "aka draft tube", and that method would never pass smog).
Old Dec 11, 2003 | 12:09 PM
  #45
blubyu's Avatar
blubyu
Default Re: PCV / oil breather setup
I believe I understand your question so I'll answer it to the best of my knowledge. The breather line is tapped into the K&N filter provided with the kit. It had a line tapped into the coupler part of th air filter. The line is run from the crankcase to the air filter. Hopefully that was the answer you were looking for.
Matt
Old Dec 11, 2003 | 01:35 PM
  #46
G3po's Avatar
G3po
Default breather
yup, that's the right way. thanx
350Z_Al
Oct 29, 2020 07:44 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
