Powerlab kit help!
Old Jun 4, 2011 | 05:52 PM
thePunkville's Avatar
thePunkville
Default Powerlab kit help!
currently in the process as we speak installing the kit! i bought the kit off a 03 350z an im puttin it on my 06 g35, im having a problem with the mid pipe and up pipe any ideas? on whats different?
Old Jun 4, 2011 | 06:26 PM
thekinn's Avatar
thekinn
Does this help?
https://my350z.com/forum/forced-indu...ure-diary.html
Old Jun 4, 2011 | 07:11 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
The steering rack is different between the '03 and '06. PowerLab has 2 different versions of the kit for this reason. Therefore, that kit off of an '03 Z won't fit your '06 G. Contact Intense to get the pipes for '06 steering rack fitment.
Old Jun 4, 2011 | 07:26 PM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
Shoot me a pm (with your contact info) or a call on monday 480-635-8888
I can get you the parts you need to convert that kit from 03 Z to 06 G35... fear not you will be able to install your kit.
Old Jun 8, 2011 | 06:06 PM
thePunkville
has anyone wrote a diy on a g35 powerlab kit? im having a hard time understand how the intake goes on because of the cuttin/ac lines in the way! plz help
Old Jun 8, 2011 | 11:23 PM
thatv35guy's Avatar
thatv35guy
Smile
My G35's at my parents house right now so I don't have pics to show… but you should have a 90 degree coupler coming off the cold side of the turbo, connecting to a 8” - 10” inch aluminum pipe (the intake pipe and coupler would roughly be in the 5 o'clock position), and of course the intake filter should be connected to the end of it… We also had to bend the supplied A/C line a little bit to make clearance for the coupler. Sorry, if that’s not very clear, if you still need to see it installed I can snap some pics Saturday morning when I get back to the car. I’ve attached the closest picture I have on hand.
Old Jun 9, 2011 | 02:28 PM
thePunkville
where does it go?!
Old Jun 9, 2011 | 02:29 PM
thePunkville
i need more pics but cant find anything!
Old Jun 9, 2011 | 03:18 PM
IntenseSales
I can email you the instruction manual if it helps, shoot me your email and Ill pm you as well.
Old Jun 12, 2011 | 03:24 PM
thePunkville
how do i run the wastegate lines and bov lines? im not currently running a boost gauge or boost controller, so anyone have any ideas or pics? i also have a kentix intake manifold if that makes a difference
Old Jun 14, 2011 | 07:41 AM
bmccann101's Avatar
bmccann101
punkville.. you sound scared and bewildered my man... just call Pete!
He'll surely go over everything with you and get you taken care of completely.
Call before lunch time or yer not gna get him by phone.. gets super busy over there.
Old Jun 15, 2011 | 09:57 PM
thePunkville
so i called powerlab, an fixed all my bugs in the car got it off the lift an threw my base map tune i got from awdtuning in dallas, my car will start and if i try to got over 2500 it cuts out an floods they say its the maf which mine is still stock, so im asking what maf upgrade should i get!? i have uprev as ems, so should i get a hpx? or is there something better?
Old Jun 16, 2011 | 05:57 AM
str8dum1's Avatar
str8dum1
HPX is the only option if you wanna tune using a reflash
EnjukuRacing
Sep 30, 2015 06:55 AM
