What Fuel Pres. should i use?
Old Jul 4, 2011 | 01:34 PM
specialist's Avatar
specialist
Default What Fuel Pres. should i use?
vq35tt with cjm pump and cosworth rails id 1000cc at 20psi what should my psi be at?
Should i run 50psi at idle? and let it go to 70psi when in boost?
Old Jul 4, 2011 | 04:41 PM
meatbag's Avatar
meatbag
What is your base pressure set at?
Old Jul 4, 2011 | 05:54 PM
specialist's Avatar
specialist
I am just asking what ppl run?
Old Jul 4, 2011 | 05:55 PM
specialist's Avatar
specialist
my aps extream kit did 55 psi
Old Jul 4, 2011 | 10:33 PM
midz350's Avatar
midz350
Originally Posted by str8dum1
base FP is also determined by how much boost you are running.
Plenty of graphs showing that past 70psi, Walbro's really fall off with regards to flow. So if you are at 50psi base and run more than 20psi, you could be asking for trouble.
I personally run low 40s BFP. 50 is just fine
Originally Posted by coachk
base FP is around 45 with the vaccuum line disconnected.
Old Jul 4, 2011 | 11:01 PM
herrschaft's Avatar
herrschaft
Mine is about 42 PSI
Old Jul 5, 2011 | 04:59 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
I recommend 43.5psi base with no vacuum/boost, which is common/standard 3bar base fuel pressure. This means fuel pres will be in the 30s at idle, and 63.5psi with 20psi boost.
There are a few occasions where I will be intentionally have it higher/lower (such as running high fuel pres on a setup with plenty of fuel volume/pump availability but small injectors), but for a normal setup 43.5psi base fuel pres.
Old Jul 5, 2011 | 06:29 AM
psychoballistic's Avatar
psychoballistic
I run mine around 40psi also.
Old Jul 6, 2011 | 03:44 AM
tonyzS/C03's Avatar
tonyzS/C03
I'm running a built motor with JWT twins a Walbro 255 and DW 880's with CJM stg 1 FRS and i'm set at about 40-41 psi at idle...
Old Jul 7, 2011 | 07:52 AM
ashtrojan2008's Avatar
ashtrojan2008
what hal said. this is what i run on all my cars. especially if you input "injector flow" in whatever ems you have, you set the pressure at what the flow of your injectors is rated at. if not your injector flow will be incorrect.
jacking up the pressure is (usually) just a band aid. The right components with enough flow won't have this issue.. these aren't honda civics, do it right.
Old Jul 23, 2011 | 06:12 AM
taywan's Avatar
taywan
i have the t 60-1 kit, 8psi, 380cc injects, stock internals, if i were to get a F.P.R, what should my pressure be set at??
thanks.
