F/I clutch questions
Old Jul 5, 2011 | 08:57 AM
djamps's Avatar
djamps
Default F/I clutch questions
What clutch options work with an OEM flywheel and hold no more than 450 wtq and NOT break the bank? I am ditching the POS 13lb flywheel -- I really miss how quiet the OEM dual mass was.
I can get a smoking deal on a brand new OEM flywheel but are there any aftermarket clutch options that will interface with it?
Side story -- I blew the pressure plate on my comp. stage 4 at the track during staging so now I'm looking for another setup that is quieter/less harsh but can handle drag and F/I abuse.
Old Jul 5, 2011 | 10:01 AM
Cass007's Avatar
Cass007
jtgli was running a JWT setup and still may be at 700+whp. It drives like stock and is quiet too.
If you want to upgrade, check the link in sig and PM me to work something out
Old Jul 5, 2011 | 10:53 AM
tonyzS/C03's Avatar
tonyzS/C03
+1 on the JWT thing, and if i'm not mistaken i think there is a group buy for it going on right now through vivid racing...
Old Jul 5, 2011 | 11:25 AM
bmccann101's Avatar
bmccann101
good to hear.. i have brand new JWT combo on what was NA....and will be up there in HP soon w big FI.
Glad that wasnt wasted money.
Subd.
Old Jul 5, 2011 | 11:27 AM
djamps's Avatar
djamps
Subd.
How is the engagement compared to stock with the combo? I don't want any shuddering or harshness AT ALL. Sick of it with my now dead comp combo. I shouldn't have to put up with all that for a measly 400whp.
Old Jul 5, 2011 | 11:31 AM
bmccann101's Avatar
bmccann101
i mean its chattery sounding, sure.. but i gotta be honest.. its not a bad sound.. and im super picky w nasty noisese, vibrations squeaks.. im super **** about that stuff.
You cant hear it in the car w windomws up one bit either.. so Drivethrus are really the only time its an issue
As fas as engagement, its been great.
Very smooth.
I ahve some other trans issues so my overall experience has been shaky, but as soon as its all fixed up, should be fantastic.
From what i heard, its really the way to go.. very stock feel but grabs very well.
Old Jul 5, 2011 | 11:34 AM
tonyzS/C03's Avatar
tonyzS/C03
OP was your comp combo at full face or a pucked cluch disc? if it was a pucked cluch thats were all of your chatter and noise and harshness were coming from, things will be much more tame with a full face clutch disc like the JWT combo. hope this helps
Old Jul 5, 2011 | 11:36 AM
bmccann101's Avatar
bmccann101
agreed.. full face ftw..
just say no to on / off switch clutches.
Old Jul 5, 2011 | 11:43 AM
djamps's Avatar
djamps
Yea the noise isn't so much of a concern as the actual engagement. However, I am really leaning towards a stock flywheel as the lightweight tends to bog and overheat easily on 1/4 mile...My mechanic and I also have a feeling that light flywheels can sometimes cause timing instability I'm currently experiencing during hard shifts with the comp flywheel (crank sensor related perhaps).
Thoughts on a new OEM dual mass + JWT combo?
Old Jul 5, 2011 | 11:57 AM
musubi's Avatar
musubi
I remember seeing a member on here with a JWT flywheel and stock clutch. Opposite, I know, but I can't see why it wouldn't work. You could look for a heavier solid flywheel, but nothing beats the DM.
Old Jul 5, 2011 | 12:01 PM
tonyzS/C03's Avatar
tonyzS/C03
I think that an OEM flywheel with JWT full face cluch will be more than enough for the 450 ft/lbs your looking to put down, with over 2500 lbs of clamping force, it sould be more than sufficant for that, and like you mentioned with an OEM flywheel shifts will be much smoother and you wont loose as many rpm's between shifts keeping you in the power longer
Old Jul 5, 2011 | 12:27 PM
thatv35guy's Avatar
thatv35guy
I’m in the same boat, installed a new Exedy stage 1 organic clutch and JWT flywheel thinking it’d be perfectly fine as I was “only” pushing 360whp at the time… 3 months later I bend a rod at the drag strip and start building my motor, lol… I’m really hoping that my combo holds 450 lbs. of tq.
Oh and you shouldn’t have any trouble running a JWT clutch with the OEM dual mass flywheel.
Old Jul 6, 2011 | 06:08 AM
thom000001's Avatar
thom000001
768rwhp 711rwtq on stock flywheel and Southbend stage 5 full face disc (full boost at 3krpm at the time too).
Tom
Old Jul 6, 2011 | 06:48 AM
tonyzS/C03's Avatar
tonyzS/C03
Tom
GOOD GWAD!!!!!! thats impressive.
Old Jul 6, 2011 | 02:50 PM
failsafe306's Avatar
failsafe306
But rev matching is so much better with a lighter fly...why not go middle of the road and get the full JWT combo?
Old Jul 7, 2011 | 05:58 AM
djamps's Avatar
djamps
Would have been quite a bit cheaper to do the full combo. I don't know, I was so p!ssed off at my previous setup I wanted something as stock as possible and I got the stock flywheel at dealer cost. Plus, the stock flywheel will aid in my process of elimination on an ignition timing issue. I have a slight feeling my previous flywheel (with regards to the crank sensor) wasn't jiving 100% with uprev.
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
