Who's car is this
Old Jul 31, 2011 | 03:54 PM
  #41
BornSlippyZ's Avatar
BornSlippyZ
That car is sick!
Love everything about it, thanks for your service CMyTailsBlink.
Old Jul 31, 2011 | 04:16 PM
  #42
str8dum1's Avatar
str8dum1
weird, taht say that. its not that uncommon. heck, they even put the turbos in the back of this car
Originally Posted by CMyTailsBlink
Pictures might have to wait til i can get it on a lift again. I'll look to see what i have now, but i don't think i have much under the car.
The turbo kit started as a corvette rear mount kit, but honestly, there is nothing left about the original kit other that the turbos themself. The Full setup was designed and fabricated by Bobby at CIN. Funny thing is, Rick Squire, owner of STS, told Bobby that his rear mount intercooler set up wouldn't work at all. at 14lbs of boost, intake temps were in the 90's on the day the car was tuned.
Old Jul 31, 2011 | 04:53 PM
  #43
2004Black350z's Avatar
2004Black350z
Exhaust Whore
uncommon on the Z. As a matter of fact its uncommon to most on the boards which is why so many are so interested. And of course the universal design of the rear mount may be common but bobbys work and how HE did things are not. Know what i mean?
Old Jul 31, 2011 | 04:55 PM
  #44
CMyTailsBlink's Avatar
CMyTailsBlink
If the weather is good tomorrow, I'll see about taking some high res pictures and posting them up. I'll tyr to capture as much detail as possible, but some of the stuff in the car isn't easily identifiable and needs to be pointed out and explained.
Old Jul 31, 2011 | 06:05 PM
  #45
redman333's Avatar
redman333
Hey i didn't know you were located so close to me. I'd love to take a look at this in person sometime. I have contemplated an ls z for awhile but still wanted to run turbos or a turbo and your car was one of the first I've seen with this. I am very happy that you saw this thread. Btw, you have an amazing machine.
Old Aug 1, 2011 | 08:55 AM
  #46
redman333's Avatar
redman333
I have a question for you ls2 guys. With a rear mount turbo can you still run a front mount intercooler.
Old Aug 1, 2011 | 10:35 AM
  #47
str8dum1's Avatar
str8dum1
thats how you do it normally. but with twins that could be alot of piping.
Old Aug 1, 2011 | 11:15 AM
  #48
redman333's Avatar
redman333
Thats fine as long as it works. Also every swap I've seen is having issues with the factory tach. Why don't they just use a converter box for the tach signal like this one
http://www.dakotadigital.com/index.c...127/prd127.htm
That way they can use the factory tach. I don't know if any of the people have tried anything like this before or if anyone has had any experience with this type of product before. By the way I don't know the quality of the product I posted the link for I just googled tach converter and found this.
Old Aug 1, 2011 | 12:44 PM
  #49
Cass007's Avatar
Cass007
The info I have is that box will not work. The Nissan tach signal is processed through the CANBUS and without the math formula it is using to turn the signal into what the tach interputs it will not correctly control the stepper motor in the tach.
I have a spare center console out at a techs place now, he is seeing if he can just make his own formula to control the tach off an LS signal by circumventing the CANBUS and just controlling the stepper motor directly.
My ViPEC has access to the CANBUS, but without the math it doesn't really do any good.
Old Aug 1, 2011 | 01:00 PM
  #50
redman333's Avatar
redman333
Okay well that makes sense. Hopefully he can figure something out cause I'd rather run my stock tach.
Old Aug 1, 2011 | 01:07 PM
  #51
redman333's Avatar
redman333
Does Hinsons canbus piece work? This http://www.hinsonsupercars.com/p-352-cangateway.aspx
It looks like they got it. Kinda expensive though if thats it.
Old Aug 1, 2011 | 02:39 PM
  #52
Cass007's Avatar
Cass007
NOPE... it says it does, but it does NOT.
Old Aug 1, 2011 | 03:05 PM
  #53
redman333's Avatar
redman333
Haha talk about mis leading.
Edit: and for how much it costs I'd expect it to not only work but work flawlessly.
Old Aug 1, 2011 | 03:56 PM
  #54
bigcloud's Avatar
bigcloud
I'm a Software Engineer and could figure this out!!! I just need a stock cluster!
Old Aug 1, 2011 | 06:08 PM
  #55
redman333's Avatar
redman333
Wouldn't you need more than a cluster? I can get a cluster for you if you'd like to try. I just think you may need the ecu also.
Old Aug 1, 2011 | 06:28 PM
  #56
bigcloud's Avatar
bigcloud
I would need to simulate the output signals of the ECU. If I were to use an ECU it would need input signals as well. Thus, adding to the test setup. It would be easier if I could use my car, but I'm not ready to swap yet. What I would do is have someone rev the engine while I probe the cluster for the merged signals.
Old Aug 2, 2011 | 07:32 AM
  #57
Gingervitis526's Avatar
Gingervitis526
Bobby and Ben do some awesome work at CIN. If this car was there in December 2010 then I definitely saw it, I knew he was doing something crazy with it but never got the details. Either way, looks SICK!
Old Aug 2, 2011 | 08:52 AM
  #58
GBoger's Avatar
GBoger
sub'd
Old Aug 6, 2011 | 12:02 PM
  #59
Royal_T's Avatar
Royal_T
One word 'EPIC'
Old Aug 9, 2011 | 07:44 AM
  #60
can'tZme's Avatar
can'tZme
cmytailsblink, what did you do to the rear diff? Any changes at all?
