I Need help BAD with my Vortech SC!
Old Aug 21, 2011 | 07:28 AM
ONEBADZEE's Avatar
ONEBADZEE
Default I Need help BAD with my Vortech SC!
Can someone please call me ASAP who knows about and has installed the V2 Vortech kit? PM me with your number and ill call you. When at idle, the BOV is pushing air out. When i gas it, everything gets quiet but i get no boost and no power. On top of that SOMETIMES it it will kick in and i get massice power but it quickly goes away.... I need help as this is my daily driver. THANKS GUYS!!!
Old Aug 21, 2011 | 08:00 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
You dont ( or shouldn't) have a BOV. You should have a BPV which is short for Bypass Valve.
At idle, low throttle it should let air dump out pre-intercooler. Under WOT or heavy throttle it will close.
Full kit with vortech fuel pump ect? Tuned?
Boost gauge?
Be sure to check the screw setting on the BPV.
Used kit?
Old Aug 21, 2011 | 08:05 AM
ONEBADZEE's Avatar
ONEBADZEE
Used kit, BPV (sorry for the typo), and everything is running great at idle. I havent messed with the BPV settings.
Old Aug 21, 2011 | 08:41 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
vortech supplied fmu and aux pump? piggy back ecu?
Old Aug 21, 2011 | 08:46 AM
verdict.'s Avatar
verdict.
Moved to Forced Induction...
Old Aug 21, 2011 | 09:05 AM
jpc350's Avatar
jpc350
From your description, could be a bad BPV...Intermintlly closes under boost but then re-opens...
Old Aug 21, 2011 | 10:16 AM
ONEBADZEE's Avatar
ONEBADZEE
OK, so i got everything working correctly now. The filter on the back of the BPV was completely blocked off. Now the issue is the fuel pump. I tested the power to it and when the SS box detects the throttle down it turns the fuel pump on... or its supposed to. If i connect the pump up directly it kicks on without issue. It doesnt kick on with the power from the SS box... Any help?
Old Aug 21, 2011 | 11:25 AM
rx7/350z's Avatar
rx7/350z
there are settings in the ss box to turn the fuel pump on. they should be set to -4 vac and 1250 rpm
Old Aug 21, 2011 | 02:07 PM
jpc350's Avatar
jpc350
More info please..Did it ever work properly? New install?
Old Aug 22, 2011 | 02:06 AM
ONEBADZEE's Avatar
ONEBADZEE
OK, sorry for the lack of info. I got the fuel pump to work correctly now. (Bad wire) Everything seems to be working, but the BPV is constantly blowing out air very loudly. I have to really get on the throttle to get it to shut up and build boost which is causing a huge lag in the mid rpm range. I have no idea how to adjust the BPV as i dont really understand how they work. Google to the rescue i hope or if you guys could point me to a good article on adjusting one would be awesome. Thanks for all the hlep guys.
Old Aug 22, 2011 | 03:18 AM
OldManZ350's Avatar
OldManZ350
Sounds like it's working just as it should.....
Watch you Boost Gauge, it should close around 8 to 10 in/vac.
It is Loud, that's why I made a muffler for mine.
You will not be building boost in less your in the throttle hard upwards of 4000rpm
Old Aug 22, 2011 | 06:40 AM
jpc350's Avatar
jpc350
Screw adjustment on the BPV...6 screw threads is the nominal setting...You can adjust to suit..
Old Aug 22, 2011 | 07:56 AM
OldManZ350's Avatar
OldManZ350
To Suit what???????
Old Aug 22, 2011 | 08:06 AM
jpc350's Avatar
jpc350
Originally Posted by OldManZ350
To Suit what???????
My preference is a button down triple breasted...However if you want the BPV to open later in boost adjust the threads ..
Old Aug 22, 2011 | 08:21 AM
OldManZ350's Avatar
OldManZ350
BPV does Not open in Boost......
Old Aug 22, 2011 | 09:01 AM
tylerxfire's Avatar
tylerxfire
make sure ur not getting belt slip..def. need a boost gauge and a/f gauge..
adjust the screw on the back of the bpv to about 6-7 threads showing..as long as it blows off and doesnt flutter its fine..shouldnt be any lag to get into boost...makes me think belt slip...u will always have air venting to the atmosphere when not in boost then the bpv will close and become quiet while in boost until u let off and it will blow off and vent again...
Old Aug 22, 2011 | 09:22 AM
str8dum1's Avatar
str8dum1
the fail is strong in this thread.
Old Aug 22, 2011 | 09:32 AM
jpc350's Avatar
jpc350
You are correcto..
Old Aug 23, 2011 | 02:40 AM
ONEBADZEE's Avatar
ONEBADZEE
Alright, i didnt think about the belt slipping... ill check that when i get some time. As for the BPV, The nut on the top is tightened all the way to the BPV. I can loosen it, but its just like a nut on anything else, it will spin freely... has my BPV been tampered with? Another question too, I have some oil at the front intake of the blower, its enough to wipe off with a paper towell. It isnt dripping, but looks like it could be enough to if i didnt clean it every few days... what up with that?
Old Aug 23, 2011 | 08:39 AM
tonyzS/C03's Avatar
tonyzS/C03
see attached photo...
as for the oil on the intake of the blower, this may cause some belt slip issues, i would look into to doing the Tim Rod or GTM belt mods to get rid of it...
https://my350z.com/forum/forced-indu...er-pulley.html
https://my350z.com/forum/forced-indu...stall-diy.html
GL OP let us know if you get it worked out.
