Fuel Pressure Gauge - Weird Condition Change
Old Sep 13, 2011 | 12:15 PM
OldManZ350's Avatar
OldManZ350
Default Fuel Pressure Gauge - Weird Condition Change
Vortech, 440cc Injectors, Walbro, Returnless Fuel System w/ FMU 6/1
Fuel Pressure Gauge Behavior Normal with above setup.
1. Key On/ Engine/Off, pump runs for 1-2 seconds and shuts off. Reading 54 PSI steady every time on the money with above setup
2. Engine/ON, No change, (Normal)
New Setup, Added 600cc Injector, change FMU from 6/1 to 3/1
Fuel Pressure Gauge Behavior with this change
1. Key On/ Engine/Off, pump runs for 1-2 seconds and Shuts Off. Reading first 1-2 seconds while pump is running, 54 PSI, when Pump shuts off, gauge instantly drops to 48PSI, and then continues to drop at a rate of 2PSI every 60 Seconds.
Also I should Note that the Pump is not always shutting off w/ key on/engine/off, it's about 50/50 now. It did that just a hand full of time in 3 years with the 440cc.
2. Engine/ON, Steddy 54PSI
OK, first thing I think of is a Fuel Leak, Right.....
I have no signs of a Leak other than pressure drop.
No Fuel Smell.
Could this all be going on in the Tank? And if so, why this change when I added larger injectors?
Please Experience Fuel System People Only......Thanks.....
Thanks Again,
TimRod
Old Sep 13, 2011 | 03:21 PM
OldManZ350's Avatar
OldManZ350
Anybody.......
Old Sep 13, 2011 | 04:17 PM
str8dum1's Avatar
str8dum1
my pressure drop just like that, but I have a RFS. You are using a non-return setup, correct? The only way it could be doing that is against the pump.
Why it started when you changed injectors might just be coincidence.
Old Sep 13, 2011 | 04:40 PM
OldManZ350's Avatar
OldManZ350
it's a non return setup.....
what do mean against the pump?
Old Sep 14, 2011 | 06:31 AM
str8dum1's Avatar
str8dum1
the check valve in the pump is leaking
Old Sep 15, 2011 | 06:32 AM
str8dum1's Avatar
str8dum1
any update?
as long as the FP is holding steady/rising when you are driving, I wouldnt worry about it.
Old Sep 15, 2011 | 05:35 PM
OldManZ350's Avatar
OldManZ350
today I pulled off the fuel line before the rails and installed a pressure gauge. I did exactly the same thing. Verified, check valve trickle down, no worrys......
All is good, thanks for the help......
Uriyo_
Sep 8, 2021 08:46 AM
apex locator
Jul 23, 2021 02:27 AM
