Total D's 18G build......Finally!!!!!!
Old Jan 9, 2012 | 07:58 AM
  #61
Total D's Avatar
Total D
Appreciate it man. If we can't get the car off the dyno today, it'll be Thursday night we get her done. So, at least I'll be having fun before the weekend.
BTW: There is surprise to this.....
Old Jan 10, 2012 | 11:29 PM
  #62
XM 1's Avatar
fingers crossed man hope this time everything works fine for you!!!!!!!
Old Jan 11, 2012 | 07:04 AM
  #63
Total D's Avatar
Total D
We will find out Thursday nite, so I'm crossing my fingers as well.
I feel like a little kid the day before Christmas right now.
Old Jan 11, 2012 | 11:28 PM
  #64
bjmax's Avatar
bjmax
goodluck today..
Old Jan 12, 2012 | 02:43 AM
  #65
Total D's Avatar
Total D
Thanks man
Old Jan 12, 2012 | 01:56 PM
  #66
bjmax's Avatar
bjmax
And??????? We came to 540 for now at 14.5 psi
Old Jan 12, 2012 | 02:03 PM
  #67
Total D's Avatar
Total D
Nice numbers man, she will be fun on the street. We start on mine in about 2 hours.
Old Jan 12, 2012 | 02:11 PM
  #68
bjmax's Avatar
bjmax
Keep your camera ready. how much psi are you going for?
Old Jan 12, 2012 | 02:43 PM
  #69
Total D's Avatar
Total D
I have had it on charge all day for tonight. I'm going to try for 18psi tonight, then when I can get race gas, I'll tune her for what ever she'll hold.
Old Jan 12, 2012 | 02:47 PM
  #70
Ruthless18x's Avatar
Ruthless18x
18psi! Damn! Good luck tonight!
Old Jan 12, 2012 | 03:48 PM
  #71
Total D's Avatar
Total D
Thanks man.
15 mins until I get off work and head over to the dyno woot!!!
Will update you guys as it progresses!!
Old Jan 12, 2012 | 06:08 PM
  #72
Total D's Avatar
Total D
Update 1: 404rwhp @ 7psi
Well....ran into some problems with the boost controller on the Haltech. Thinking maybe the driver isn't working properly. The mac solenoid doesn't click while it is on. So, either I send the Haltech in, or I can just wire a boost controller up and do it external. Will give a call in the morning to see what would be the best option.
All the hype to be delayed for a few days longer. I apologize guys for the big let down.
Jeremiah
Old Jan 13, 2012 | 05:48 AM
  #73
Eno's Avatar
Eno
Nobody feels the sense of disappointment more than you man... and I'm almost positive everyone in here has been in the position at least once. I'm pretty much just counting the minutes until Hal weighs in here- Either way I'm sure things will get sorted out.
Good luck!
Old Jan 13, 2012 | 07:06 AM
  #74
Ruthless18x
It's all good man, it will get there.
Old Jan 13, 2012 | 07:14 AM
  #75
Total D's Avatar
Total D
Yea it is a bummer. I am talking to Haltech now, so we will see what the verdict is. He had his base map on and the solenoid worked fine, uploaded my map and the same problem I had, he had. So, I am waiting on a call back to see what they say.
Old Jan 13, 2012 | 09:08 AM
  #76
bjmax's Avatar
bjmax
It's a smal bumb in the road, and will be fixed.
My injectors run out on max.
598.4 WHP and 756.3 NM
Old Jan 13, 2012 | 09:22 AM
  #77
Total D's Avatar
Total D
Got some help from Haltech, so hopefully they found the fix.
How much psi where you running?
Old Jan 14, 2012 | 10:24 AM
  #78
binder's Avatar
binder
if the solenoid works with base map then the haltech is fine and somethign in the settings on your custom map need to be adjusted.
This is a common occurance people have. Usually just a slight overlook in the settings for the boost controller. It took me a little digging to get mine to work properly and it was a simple mistake on my part in the setup.
Should be an easy fix. I'm sure your tuner is using open loop (set duty cycle) but just in case he's not have him try that first before trying closed loop (like boost per speed, ect).
Old Jan 14, 2012 | 08:38 PM
  #79
Total D's Avatar
Total D
Well started the day at the dyno. Uploaded the new map from Haltech, to try the solenoid out again. We end up running into the same problem. Solenoid not clicking. Checked everything on the ecu side, all is good. Check solenoid, it's getting hot but not clicking. So, we hook up a new solenoid to the ecu and it starts clicking. Long story short, Haltech fixed my back-end problem with the map, and the solenoid was bad as well.
Now for the info you guys want to hear.
We dynoed at 18psi and made 602rwhp uncorrected and 581rwhp SAE. Needless to say, I have no kind of traction on the streets lol. I'm glad to finally have her all tuned. Now I can concentrate on the body, as she needs some love there..
I'll get the video upload here in a bit.
Jeremiah
Old Jan 14, 2012 | 08:43 PM
  #80
KingBaby's Avatar
KingBaby
Hardest Setting
congrats on the getting it panned out!
Enjoy...
