VQ35 turbo hr race engine
Old Feb 21, 2013 | 12:37 PM
  #41
jerryd87's Avatar
jerryd87
do you have to use the quaife? the cd009 has shown it will handle that power without trying, and they make a sequential shifter for it. not sure how flexible you are on gear ratios
Originally Posted by racer59
Hi the engine has done a seasons racing we had a broken l19 head stud what caused a blown head gasket on the dyno ,fixed that and it made around 800hp at 17psi on our engine dyno.
The only problem we have had is it likes to eat gearboxs ,it has a qualife g69 6 speed box behind it now hopefully it wont eat that, and while it was out we pulled the engine to check bearings etc and they where like brand new.
The engine is going back on the dyno in the next few weeks i have some 2000cc injecters to set up .
Old Feb 21, 2013 | 12:41 PM
  #42
redline06's Avatar
redline06
love this, any pics or videos of the beast in action?
Old Feb 21, 2013 | 05:15 PM
  #43
racer59's Avatar
racer59
We used to use a tko 600 tremec but it broke 3rd gear, being a track car the quaife works great, flat shift and u can chose your ratios.
The cd09 boxs ratios didnt suit the rest of the drive line
I have got some in car vids have to dig them out
Old Feb 22, 2013 | 06:35 AM
  #44
junglefever's Avatar
junglefever
Great, been wondering when you were going to do that!
Old Jun 11, 2013 | 03:00 PM
  #45
koshin's Avatar
koshin
racer59 , you ever find/post those in-car vids?
I want to see this thing eat track.
Old Jun 11, 2013 | 11:52 PM
  #46
racer59's Avatar
racer59
Hi havent had a change yet, got the motor back on the dyno at the mo
Old Jun 12, 2013 | 01:25 AM
  #47
Resmarted's Avatar
Resmarted
More pics,
VIDEOS
More info!!
Please
Old Jun 14, 2013 | 12:17 AM
  #48
racer59's Avatar
racer59
Finished dynoing motor tonight it made 760hp and 650ftp at 15 psi, think i have run out of compresser more boost made not much more power.
Does any one no the VE of these engines?
Old Jun 17, 2013 | 12:44 AM
  #49
racer59's Avatar
racer59
Run the engine today just cant get it past 780hp, Getting small gains per psi. Thinking the standard cams might be the problem has any body had hr cams past this point or do i need to upgrade? The engine is making around 680 at 11psi and 740 at 15 and 780 19psi.
Old Jun 17, 2013 | 02:24 AM
  #50
bmyles's Avatar
bmyles
What changed since this post? How did you make 800 @ 17psi and now you're stuck at 780 with more boost?
Old Jun 17, 2013 | 02:33 AM
  #51
mw9's Avatar
mw9
In for updates!
Old Jun 17, 2013 | 04:26 AM
  #52
Cass007's Avatar
Cass007
Originally Posted by djamps
Alot of folks here with certain EMS (even a tuned stock ECU) have this problem past a certain HP. You're probably the first to use this EMS on a VQ (in public at least) so who knows if you have this same issue. Narrower gap and/or ignition booster should help.
Robbie = Driven1 has used it for many years. The Autronic was a precursor to ViPec.
Old Jun 17, 2013 | 09:49 AM
  #53
binder's Avatar
binder
I haven't head of any oem cams (hr or de) past 750. I would say you are definitely in the power range for some nice big cams.
Old Jun 17, 2013 | 02:11 PM
  #54
racer59's Avatar
racer59
Thanks thats what we thought its making great power from 4500 to 6500 then flattens so it looks like cams. Might leave it and change them on next build.
Old Jun 17, 2013 | 02:43 PM
  #55
taywan's Avatar
taywan
wow
Old Jun 18, 2013 | 07:44 AM
  #56
binder's Avatar
binder
Ya, changing them is a pain on this car since the front timing set has to be removed.
You are probably getting some great midrange on those stock cams already I bet.
Old Jun 18, 2013 | 11:23 AM
  #57
Resmarted's Avatar
Resmarted
Me thinks the engine was on an engine dyno, and this new result is on a chassis dyno?
Old Jan 27, 2014 | 02:58 PM
  #58
racer59's Avatar
racer59
Here is a video of my last race meeting i will post some more soon
Old Jan 27, 2014 | 03:03 PM
  #59
pyshin's Avatar
pyshin
Jesus... That power/gearbox in a Toyota Levin...
Old Jan 27, 2014 | 05:36 PM
  #60
OldManZ350's Avatar
OldManZ350
Your passing everyone!!!!!!!
Like that gearbox.
