Thermostat = best cooling mod
Old Sep 23, 2011 | 07:14 PM
Cannysage's Avatar
Cannysage
Default Thermostat = best cooling mod
sup all.. long time no post.
My thermostat was in it's last leg and I just replaced it with the Nismo. The price difference is huge. $20 for stock and $180 for the Nismo. I've figured that it would cool down my car by a few degrees. To my surprise, my oil temp was running 20 deg cooler consistently. Not only that, it takes a lot longer to reach the maximum, normal driving temp. I'm also running a Stillen radiator. I'm very surprised and pleased with this 'mod'
Old Sep 23, 2011 | 11:28 PM
jerryd87's Avatar
jerryd87
mishimoto is alot cheaper and opens the same temp as the nismo one
Old Sep 23, 2011 | 11:46 PM
Cannysage's Avatar
Cannysage
^ couldn't wait and the shop had one in stock.
oh also, I've gained 1-2mpg
Old Sep 24, 2011 | 02:07 AM
pce60's Avatar
pce60
Wow surprising! good to know
Old Sep 24, 2011 | 02:33 AM
JCITY's Avatar
JCITY
Question ??
???I'm running a Nismo thermostat.How did you get 1-2 more mpg?
Mine's the same..temp is down for sure.Don't see what the therm. has to do with mpg?
Old Sep 24, 2011 | 07:52 AM
jpc350's Avatar
jpc350
Cooler engine more efficient less friction??
Old Sep 24, 2011 | 07:58 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
just picked up one of these as well though i paid $150 not $180 suckaaa
Old Sep 24, 2011 | 12:14 PM
binder's Avatar
binder
a thermostat won't cool your system down more. the radiator is causing the cooling. The thermostat only controls at what temp it allows the cool fluid into the engine.
once it's all the way open it will be the same "cooling" as a normal thermostat which means while driving it hard there is no difference.
your results are from adding the increased radiator, not the thermostat.
Old Sep 24, 2011 | 05:42 PM
Cannysage's Avatar
Cannysage
coolant flows at a lower temp with Nismo. I didn't think it had any relations either but apparently it does.
Old Sep 24, 2011 | 05:45 PM
Ruthless18x's Avatar
Ruthless18x
I would say be "budget" cooling mod, not best cooling mod overall.
Old Sep 24, 2011 | 07:06 PM
baileyrx's Avatar
baileyrx
way of topic but,
i miss the classic cat with the watermelon/cantelope hat...
Old Sep 25, 2011 | 04:11 AM
mw9's Avatar
mw9
Exactly, once its open no difference
Old Sep 25, 2011 | 08:09 PM
CTZ860's Avatar
CTZ860
So general consensus is no need for a cooler tstat? Why do they make them in general?
Old Sep 25, 2011 | 09:03 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
There is better mods to do first before doing this mod that's all.
Old Sep 26, 2011 | 07:17 AM
jpc350's Avatar
jpc350
Open up sooner (lower engine temp) than oem..Greater flow thru it???
Old Sep 26, 2011 | 08:18 AM
CTZ860's Avatar
CTZ860
I.e. oil cooler?
Old Sep 26, 2011 | 08:20 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
radiator, oil cooler, pathfinder mod, water injection
Old Sep 26, 2011 | 09:29 AM
bmccann101's Avatar
bmccann101
Originally Posted by baileyrx
way of topic but,
all i have to add to thread is my agreeance to this. ^^
Or the CHick talking to the banana /telephone with bed head.
Both win.
Old Sep 26, 2011 | 09:35 AM
bmccann101's Avatar
bmccann101
actually not true, DIK.. i jsut pulled upa thread about the pathfinder mod.. whats the scopp w that.. my build is already a clusterfawk, i dont want to add any roadblocks.. but should i roll one of those rear crossovers too? Does it create any pitfalls at all, or just gain? I have mishimoto radiator and cap goin in there, cooling plate, new water pump etc.
Thanks man.
Old Sep 26, 2011 | 11:56 AM
ace32x's Avatar
ace32x
Thanks man.
very worth it from what I gather. It routes cooling from one head to another from cooling passages that were blocked on the de and rev up. Friend of mine with a built g just put this mod in aswell as tapping his block and running coolant lines to each the turbo and he said it stayed quite a bit cooler ( and helped with some air bubbles in his cooling system he was having troubles getting out)
