Vortech advice (with a twist)
Old Oct 1, 2011 | 05:25 PM
rdrfronty's Avatar
rdrfronty
Default Vortech advice (with a twist)
First thing--I have a 08 Frontier that I need advice on. Unfortunately Frontier owners don't typically go with FI so I am unable to get any qualified advice from their sites. You guys are well versed in FI and your vq35de platform is as close to my vq40de that I can find. I'm hoping to get some constructive opinions and/or advice here.
So as the title indicates, I'm looking at supercharging my truck. By means of a Vortech V3 custom system. I intend to base this kit closely with the vq35de kit that is readily available.
So here is the basics on my truck as it sits
Performance stats----
276whp/288ftlbs (dynojet SAE) & runs a 14.1 & 95.88mph(though likely slightly better now) with a 4250lb racing weight(driver included)
Current mods---
Uprev dyno tuned
BC stage 2 cams(vq35de)
350z upper & lower plenum(custom spacer to make fit)
Motordyne 5/16" plenum spacer
6spd manual transmission
JWT clutch & flywheel
Truetrac LSD with 4.11 gears
Full 2.25" dual custom magnaflow exhaust with x-pipe and no cats.
Shorty equal length headers
Lightened UDP (5.25" dia)
CAI
So here are my planned mods--
Vortech V3 with 3.12 pulley
Modified or custom vq35de cog style pulleys & bracket
Air to Air intercooler routed with 2.5" tubing
Walbro 255 fuel pump
Injector Dynamics 725cc injectors
Uprev GT Maf
Vortech bypass valve
Uprev retune
My goals are not too high I think. Hoping for about 350-375whp & 350-375ftlbs or so too by keeping it in the 6-7psi range. Also hoping for about a 13.0 in the 1/4 as long as I can hook it up. The vq40 pistons are our weak point, so I don't won't to go beyond the 7psi on my stock lowers. I'm thinking my UDP with the 5.25"dia vs your stock 5.75"dia along with a 3.12 Vortech pulley will put me close to that PSI range. I want this setup reasonable safe for a daily driver.
So what do you guys think? The parts list ok? My performance goals within reach?
Thanks in advance for any advice & opinions. I have talked a briefly with Uprev about this, but you guys are about my only other good source for information.
Old Oct 1, 2011 | 10:42 PM
350Z400rwhp's Avatar
350Z400rwhp
The hardest part it going to make a custom bracket. Sounds like you have everything else covered.
Old Oct 2, 2011 | 08:01 AM
rdrfronty's Avatar
rdrfronty
Thanks. My timing cover is pretty similar to vq35de where the bracket attaches, so I'm hoping it can fit without major modifications. If its too far off, I'll just have to get a custom bracket CNC'd.
One other question-whats the basic difference between the Vortech Si & SCi? Advantages of one vs the other?
Old Oct 2, 2011 | 09:17 AM
binder's Avatar
binder
I can't remember which one but I do believe the S wheel is higher boost than the SC.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
