Need help with Engine
Old Oct 14, 2011 | 04:35 PM
wbama387's Avatar
wbama387
Default Need help with Engine
So i hang out on driver and heard there are some technical experts over here. I am in the process of a stroker build 97mm bore with arias pistons. I called arias and they recommended .026" ring end gap on the top ring and .021" on the middle. From my understanding you want the second ring the same or larger because other wise it can cause flutter. What are yalls opinions and what do you think i should go with? Thanks
Old Oct 15, 2011 | 08:05 AM
wbama387's Avatar
wbama387
Anyone?
Old Oct 15, 2011 | 03:09 PM
binder's Avatar
binder
I would always do what the designer of the product says. They have engineers that know what they are talking about.
I used arias specs for my engine build with arias ED pistons.
Old Oct 15, 2011 | 05:18 PM
wbama387's Avatar
wbama387
Out of curiosity what were the specs you used?
Old Oct 16, 2011 | 08:36 AM
binder's Avatar
binder
not sure. I don't do machining so i have all that done by a shop. Since i'm pressed for time i just had them file my rings for me this time. Before i used .030 but this time the shop just called arias and used the gap they told them.
That's what most competent shops are going to do: use manufacturer recommended specs. I would trust they are correct.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
