Built engine went pop
Old Oct 16, 2011 | 02:59 PM
Fluid1's Avatar
Fluid1
Originally Posted by str8dum1
i guess you know if your wrist pin went, it woulda still destroyed a sleeved block. The original post read like sleeves will solved any issues.
you should have darton do your sleeves like you plan, but make sure you get carrillo's with CARR bolts. That will save your motor more than sleeves will.
Thanks.
Old Oct 16, 2011 | 03:20 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I'm curious... What turbo kit are you trying to make 750whp with?
Old Oct 16, 2011 | 03:24 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Overbuilding in 2011?
Not needed, in fact not recommended, but what do I know...
Old Oct 16, 2011 | 03:42 PM
zmedic16's Avatar
zmedic16
if there is anyone who been to hell n back, maybe 20k+ lost in built "sleeved" motor it would be this guy ^^^^^
Old Oct 16, 2011 | 04:28 PM
Fluid1's Avatar
Fluid1
Greddy 20g's w/custom xtra large intercooler
I've been around long enough to know what Berto's been through, **** he helped me build my last one.
I'm not trying to just throw $ away, that's for sure.
Old Oct 16, 2011 | 05:31 PM
ace32x's Avatar
ace32x
outa curiosity how come you need a bigger intercooler? the greddy 20g kit one not sufficient? (dont know a whole lot about their kits)
Old Oct 16, 2011 | 06:08 PM
binder's Avatar
binder
at that power level the heat produced will start to become exponential therefore going with a large intercooler to start with saves time and money.
Old Oct 16, 2011 | 06:19 PM
ace32x's Avatar
ace32x
ah gotcha makes sense
Old Oct 16, 2011 | 08:41 PM
TreeFiddyGee's Avatar
TreeFiddyGee
I don't know what the hell you are saying here but this isn't a thread about that crap. I'm getting sleeves, I give less of a **** about what anyone says. If it's overkill, great.
Dean, no, I'm about to spend that much.
Assumptions, people. Assumptions. They make you look foolish
You're kinda just making yourself look foolish.
Old Oct 16, 2011 | 09:45 PM
Resmarted's Avatar
Resmarted
I skipped a bunch of the banter and saw this.
+1 on darton doing the sleeves if you are persistent with the idea. The 8xxwhp thread that's open right now (meatbag with twin 20g's) has his darton installed sleeves since 2005.
I don't think it's a bad idea at all or overkill. Only reason I didn't do it was cost
Str8 and I have differing opinions about rods, but then again Str8 likes to have 900whp
Just make sure who-ever does the machining and building really know's their ish.
Eagle rods for example have a taper on the conrod/conrod bolts... if they aren't correctly stretched/torqued to compensate for stretch they will eat sh*t and die. A lot of shops don't even know about it. Proof? A local guy was just hand torquing the conrod bolts in, and they got stuck at maybe 5lbs. They had to trash the bolts and machine the holes because the taper got the bolt stuck in there. I'm pretty sure he lost a rod or two.. idk the whole story.
Also were you running wiseco pistons?
If so, the wrist pins that come with the pistons are not good for much more than 500hp. You need to upgrade them. I called wiseco to verify that they wanted 4 thou piston wall clearance, and to ask what the pistons could take maximum. They told me then the originally supplied wrist pins aren't that good, and when you get the 'upgraded' pins you could make 1000hp without 'issue'. It was like 100 bucks for the set, and the pins are made of probably a stronger metal and the wall of the pin is about 2x the thickness. I'm pretty sure Z1's 'custom' wiseco pistons are just the upgraded pins + coatings (the cost somewhat reflects this idea too).
Old Oct 17, 2011 | 05:09 AM
Fluid1's Avatar
Fluid1
....and you are? I had built motor, and will have another, where are you @?
Old Oct 17, 2011 | 05:10 AM
Fluid1's Avatar
Fluid1
Meatbag's setup is pretty much exactly what I'd like with pump gas.
Old Oct 17, 2011 | 05:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I myself wouldnt do sleeves (for a 3rd time) unless you plan on running 750+whp all day long.
20G + fuel system + cams can be deadly as we know from meatbag. Standard 18G's can produce sick numbers too on pump and pump + meth as I have proven.
In your case, Id rather run something in the 600whp range on pump easily and push it to 750-800whp on meth or race gas OCCASIONALLY than go for sleeves full time and take the chance going down that path pushing tons of power you likely cant even use all the time.
Old Oct 17, 2011 | 05:31 AM
Fluid1's Avatar
Fluid1
Yeah, that's more levelheaded I suppose, but I've already been right at that 600 mark, I said to myself that when and if I ever rebuilt I'd go higher. Maybe E85. We have time. I already have 11" wide wheels, I could go much higher in tire and get some custom rear fenders to put the power down, I do plan to use it.
Old Oct 17, 2011 | 05:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Well like everyone said then, if you do choose sleeves have Darton themselves do it.
Dont let any Z or big name shops fool you into telling you they can install them with success, no shops here that Ive seen that didnt use Darton have kept these motors together.
Good luck!
Old Oct 17, 2011 | 05:44 AM
Fluid1's Avatar
Fluid1
Thanks Berto
Old Oct 17, 2011 | 10:31 AM
bmccann101's Avatar
bmccann101
i have heard that sleeved VQs are problem prone as well.. just adding my .02 is all. , sleeves moving, crank walk etc.. losts of fun stuff i hear, i did not chose to use them on my build.
Im a noob tho, but again, just my .02.
call it a plus 1 to Albertos comment... i think the issues i heard of were all attributed to installations that were sub par as compared to Nissans OEM engineering etc.
Old Oct 17, 2011 | 02:38 PM
  #38
Resmarted's Avatar
Resmarted
I agree with that statement; pretty much my build in a nutshell. Except with a 7175 single turbo and stock heads. mid 700whp on meth. Maybe down the line when I can afford to pop the motor and have someone else do all the work I will push the whp up and see how long the eagles last. I know about str8's experience but I'm somewhat skeptical.
And to add to what bert said about the shops... i'd go either darton (if you are on the west coast because they are in cali) or Sound Performance. SP is one hell of a shop and has the cars/records/and experience to prove it. And their customer service is super friendly/spot on. In fact, I'd probably go straight to SP, because then you could buy a complete short block rather than take your freshly sleeved block to another machine shop...
Old Oct 17, 2011 | 08:01 PM
  #39
Fluid1's Avatar
Fluid1
I'm still in a holding pattern until Saturday. I'll know more about what all needs to be replaced then, and what direction I will be heading.
Old Oct 17, 2011 | 08:42 PM
  #40
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by Resmarted
I. Except with a 7175 single turbo and stock heads...
Do you have a build thread? I am also working on a PTE 7175 and 7675 as a production kit..
