View Poll Results: Which fuel pump is better
DW 300 lph fuel pump
26.67%
Aeromotive 340 lph fuel pump
22
73.33%
Voters: 30. You may not vote on this poll
Aeromotive 340lph fuel pump or DW 300 lph fuel pump
Old Nov 5, 2011 | 11:35 PM
ccchaorule's Avatar
ccchaorule
Default Aeromotive 340lph fuel pump or DW 300 lph fuel pump
I am deciding between the two, they are about the same price.. is ther any pros an cons of each?? thankss
Old Nov 5, 2011 | 11:41 PM
350z006's Avatar
350z006
I use the Aeromotive:
Pro - More flow than DW
Con - Have to change polarity of power wiring for pump
Old Nov 5, 2011 | 11:53 PM
ccchaorule's Avatar
ccchaorule
and the dw is just a straight drop in like the walbro?
Old Nov 6, 2011 | 12:30 AM
350z006's Avatar
350z006
Both pumps are drop in like the Walbro...
Old Nov 6, 2011 | 06:41 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Your con is not really a con since they fixed that issue. You only had to change the polarity on the first batch they released.
Old Nov 6, 2011 | 07:26 AM
ETZ's Avatar
ETZ
Default .
That help's me out....Aeromotive it is,thanks dikspiel
Old Nov 7, 2011 | 12:01 AM
350z006's Avatar
350z006
Dammit! I rewired my fuel bucket too! Oh well...
Old Nov 7, 2011 | 06:23 AM
Chris@DW's Avatar
Chris@DW
DW = 3-year warranty and E85 compatible.
Also, we have a 350Z specific fitment pump and install kit now available. The A340 and non-350Z fitment DW will require some trimming to make fit.
-Chris
Old Jan 6, 2012 | 05:05 PM
bishop_98's Avatar
bishop_98
I tried looking for the app-specific pump, but aeromotive dont seem to go that in-depth. Is the 340LPH pump a drop-in? (aka, no extra parts/wires?)
Old Jan 7, 2012 | 08:19 AM
str8dum1's Avatar
str8dum1
they are all drop in
Old Jan 7, 2012 | 07:20 PM
binder's Avatar
binder
I like both companies.
The only reason i would lean more towards the aeromotive is the fact that they have been making high hp fuel pumps for quite some time already.
DW has great products and fully tests their stuff so i wouldn't worry about them having quality issues either, though.
Old Jan 9, 2012 | 07:26 AM
Chris@DW's Avatar
Chris@DW
Not true. The DW301, W255, A340 all require trimming of either the assembly or pump to make fit.
We introduced the DW301 smooth bottom pump for the 350Z/G35 assemblies so that it would be a true drop-in fitment pump.
Also, the DW300/DW301 is a 320LPH pump that flows more than the similar in-tank pumps above 65psi. Which, in a FI application, is where you need more flow.
Old Jan 9, 2012 | 07:56 AM
konrad's Avatar
konrad
Do you guys have a flow chart? Not a graph but a chart?
Also off topic do you guys do injector servicing? If so can you pm me with prices and details.
Old Jan 9, 2012 | 08:55 AM
ace32x's Avatar
ace32x
OP i have a dw 300 lph pump that came out of my z i has maybe 200 miles worth of use on it if your interested. ill let it go real cheap and im local :P
Old Jan 9, 2012 | 08:57 AM
Chris@DW's Avatar
Chris@DW
Sure.
http://www.deatschwerks.com/fuel-pump-tech/
Old Jan 9, 2012 | 09:21 AM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
aeromotive for sure. awesome pump. iirc the a340 is e85 compliant also.
Old Jan 9, 2012 | 09:23 AM
05SickSer's Avatar
05SickSer
Which A340 number are you guys with it running? The 11140, 11141 or 11142. Havent pulled my fuel pump out to look as the car is in storage an hour away
