I/C Discussion
Old Nov 25, 2011 | 10:07 AM
TurboBob's Avatar
TurboBob
Originally Posted by OldManZ350
Don't have them but this could just as easily be stock. The point I was trying to make is that cooler air is denser and can accommodate more timing.
Old Nov 25, 2011 | 12:26 PM
Eno's Avatar
Eno
Originally Posted by TurboBob
Yes but you aren't breathing 4500 psi so the oxygen for a given mass of air is the same as the atmosphere. The oxygen percentage doesn't go up with compression, however, the amount of oxygen in say 10 pounds of air is more than the oxygen in 1 pound of air. So if I am compressing air into the engine under say 10 psi and that equates to 10 pounds of air than I have more oxygen than at atmospheric pressure. Hence the measure of pounds/minute as a measure used rather than cubic feet per minute.
Okay when you explain it like that I can interpret his question differently- so yes. Instead of all that oxygen being in a space the size of a building it's all mashed into something the size of a cylinder. That would mean more oxygen compressed in the same space.
Pretty cool information though broken down this way. So when f/a mixtures are represented the pump is trying to deliver a ratio of fuel based on air delivered in its compressed state- similar to breathing at depth as oppose to breathing ambient pressure?
Old Nov 25, 2011 | 02:14 PM
TurboBob's Avatar
TurboBob
You are on the right track. What the ECU tries to do is keep a given Air/Fuel ratio (AFR) depending on the load on the engine. For cruise conditions this is generally around 14.7 to 1. Under heavy load/boost that will drop to somewhere around 12 or 11 to 1, so less air more fuel. In order to keep that ratio the ECU looks at the amount of air entering the system in pounds/min. So when it sees heavier (compressed air and/or colder denser air) it adds more fuel to keep the requested AFR.
Now things get a little more complicated than that as the main table generally used in engine tuning is the volumetric efficiency table or VE table. Volumetric efficiency is a measure of how much air enters the engine compared to the maximum volume of air that can fit into a cylinder when the piston is at bottom dead center. The ideal would be 100% but that cannot be reached without a pump to force more air into the cylinder (turbocharger or supercharger). When the air is colder and therefore denser the volumetric efficiency is increased because there are more molecules of air per area (it’s compressed). The volumetric efficiency table represents the engine’s intake efficiency under different conditions.
I/C Discussion-ve-table.jpg
On the graph kPa is metric for pressure which in the imperial system would be psi.
Old Nov 25, 2011 | 11:40 PM
jerryd87's Avatar
jerryd87
not completely true on the VE portion, you can achieve 100% or greater ve without forced induction. Prostock engines are around 106% volumetric effecient at peak power, the velocity is so great moving through the engine that the air actually compresses itself slightly when it slams into the cylinder, then the intake valve closes before it can fully escape and equalize. iirc the DE is about 102% VE at peak power which is why bolt ons dont do much. dont remember the source for the de engine ve so i can be wrong on that. the source for the pro stock engines is the rediculous number of articles done interviewing pro stock engine builders, i used to have like 6 different ones interviewing different engine builders before i had to throw them out when i moved to hawaii. my wife wouldnt let me bring a file cabnet full of magazines.
also volumetric effeciency is constant regardless of temp, the volume entering the engine is not changing its just the denisty which are both very different things that people often confuse as the same thing. for instance a 1 square inch block of steel and a 1 square block of mallory metal(what they use to add weight to crankshafts during balancing) both have the same volume(one cubic inch) however since the mallory metals molecules are much closer togeather it weighs about twice as much, hence it is twice as dense. density is just a correlation of volume vs mass.
Attachment 327944
Attachment 327944
Old Nov 26, 2011 | 04:41 AM
TurboBob's Avatar
TurboBob
Originally Posted by jerryd87
not completely true on the VE portion, you can achieve 100% or greater ve without forced induction. Prostock engines are around 106% volumetric effecient at peak power, the velocity is so great moving through the engine that the air actually compresses itself slightly when it slams into the cylinder, then the intake valve closes before it can fully escape and equalize. iirc the DE is about 102% VE at peak power which is why bolt ons dont do much. .............
Yep - you are right on both counts. I'm more embarrassed about the temperature item as that was where the confusion was to start with. The issue is converting MAF readings to volume which does require a temperature conversion. Thanks.
Old Nov 26, 2011 | 08:48 AM
jerryd87's Avatar
jerryd87
eh no biggie we all make mistakes =/ im glad theres a meaningful discussion without flaming which seems to happen often. go go progress haha
Old Nov 26, 2011 | 11:29 AM
jpc350's Avatar
jpc350
Really great discussion and appreciate all the good comments as well as education..The reason I started this thread was to understand the benefits of going to a bigger I/C than the puney Vortech unit... Is there a cost benefit/ performance basis for changing?
Performance benefit is elusive since it not easy to calculate it based upon potential delta I/C temp's and at a specific boost level..So what I have done is to calculate the mass delta of O2 for several cases of I/C temp's and at 10 psi..(my systems boost level). Determing how much additional 02 is flowing into the engine as an approximation/ measure of performance increase.
The weight of 02 in air represents approx 23 % of the total weight regardless of temp and pressure.
Looking at the air density chart (at 10 psi) for air at different temp's (representing I/C temp's):
weight of air/density / 02 weight (23%)
150 deg F. / 0.109 lb/ft3 / 0.0250 lb/ft3
140 deg F. / 0.111 lb/ft3 / 0.0255 lb/ft3
120 deg F. / 0.115 lb/ft3 / 0.0265 lb/ft3
100 deg F. / 0.119 lb/ft3 / 0.0274 lb/ft3
So whats the bottom line?
If I buy a larger I/C to get the temp's down from say 150 F to 120 F. the 02 level will increase by 0.0015 lb/ft3 or about a 6% increase..Anyone want to weigh in on how this will effect perf.?? Re tune ? Timing change?
Old Nov 26, 2011 | 12:15 PM
DaveJackson's Avatar
DaveJackson
Master
Totally just thinking out loud, here, so feel free to correct me...
6% isn't much and I doubt that all of that will turn into ponies. Also, I don't know that a bigger intercooler can grab you 30°F lower temp. That sounds like quite a bit of heat to remove when the delta-T isn't that big.
Old Nov 26, 2011 | 12:31 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
It can, if the IC is good. On my car, I have seen IAT's at the drag strip only about 12-15deg F above ambient. This is after a pull from first to top of 4th gear.
So if you have a cheap, small, restrictive FMIC these IAT's may be 40 or 50deg above ambient. Of course it all depends on boost levels, and the overall efficiency of the entire setup. There are a lot of factors to consider here. For example, if your exhuast is restrictive, the IAT's will also go up regardless of how big the FMIC is.
Old Dec 5, 2011 | 09:33 AM
Eno's Avatar
Eno
I was going to ask this question in my own thread but this thread has been trending in the right direction with the air cooling issue and the ECU calculating fuel output.
What if the air is ALREADY cold- but the tune was done while air was being cooled to something above ambient. It's not possible to drop the temperature of incoming air past the IC below ambient- save I suppose for WMI or something more exotic I guess-
But if the tune is performed in 15-20C and the car is running in 4-8C in the cooler months will this cause fuel problems? Additionally, will it throw advanced timing off? Will a tune need to be adjusted to accommodate lower temps?
Intec told me that they would make arrangements to come up and do a cold weather / warm weather tune if I wanted them to do that and originally I'd declined the offer. Now as I start to get my head around the bigger picture I'm starting to wonder if it's not a bad idea...
I don't think it's been covered already but I think a lot of the right people are watching this thread to clear up some of the concern.
Old Dec 5, 2011 | 09:42 AM
str8dum1's Avatar
str8dum1
It all depends on how your tuner setup the temperature compensation tables. Most tunes use coolant temp as the big correction with small tweaks from AIT. Thats how mine is setup.
Old Dec 5, 2011 | 12:32 PM
Eno's Avatar
Eno
Sorry str8- I looked through your garage but I don't see your fmu. Are you running haltech or another map driven device? Wondering if an maf based input would be different?
Old Dec 5, 2011 | 12:41 PM
Boosted Performance
I know with Haltech (and I am sure this goes for all EMS's) there are compensation tables. If you leave the car outside over night and the temperature falls below 0 C, the ECU will be adjusting fueling differently than if you were to start it at 20 C. It will look up coolant and IAT tables for adjustments. I found that if the car is parked and running in the summer, the IAT sensor will get heat soaked, so I had to adjust the IAT tables. This is because the coolant will only go up to a certain temperature, and stay there.
In the cold, I find that I had to adjust coolant compensation tables at startup/during warm up. So it all depends I guess. This is just my experience, and I am not a pro at this.
jerryd87's Avatar
jerryd87
your IAT temp correction should go across all range of temps the vehicle could see. the tuning dosnt jump like say you deliver x fuel at 10c and y fuel at 15c then its not going to simply jump from the x to y calculation it will increase in very small amount as the temp changes, it varies on the tuning solution for how small the increments will be. so theres no reason to have a super tune for one temp range and need another for different months, it should be done across the entire range in the same tune.
there are actually alot of ways to lower the IAT below ambient but your gona know about those, theres meth injection, cryogenics on the intercooler, air to water intercooler, the ford lightening even had a/c refrigerant go through the heat exchanger on one of the model years to super cool the the incoming air.
Old Dec 5, 2011 | 02:14 PM
str8dum1's Avatar
str8dum1
i've had UTEC, Haltech, and now Proefi. They are all the same in terms of ability to compensate for coolant temp and AIT.
I've never fussed with MAF tuning, but i'd imagine external AIT compensation would be even smaller since AIT is already incorporated into MAF measurements.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
