928 + 2.87???
Old Jan 5, 2012 | 05:08 AM
Exemption's Avatar
Exemption
Default 928 + 2.87???
Would both of these upgrades work with a stock bottom end?
or would it be to much( i.e. snap a rod)?? I cant seem to find any threads on both of
these being used. I even googled
Old Jan 5, 2012 | 05:27 AM
tonyzS/C03's Avatar
tonyzS/C03
I think that theres a few guys on here that are running that set-up but i'm not 100% sure... I dont see a problem with that as long as the tune is good, and you keep the torque down below 400ish ft/lbs
Old Jan 5, 2012 | 05:30 AM
Exemption's Avatar
Exemption
i wouldnt think a vortech would be able to pull that kind of torque with a stock block. im scared to try it =/ my 04 only has 46k miles dont want to blow it up pre-maturely
Old Jan 5, 2012 | 05:40 AM
05Z33's Avatar
05Z33
I've been running that same setup for over a year on stock block. Just get a good tune and you are good to go.
Old Jan 5, 2012 | 06:15 AM
Exemption's Avatar
Exemption
if i may ask what are your supporting mods and dyno #'s?? i have full bolt-ons down to headers and going to use cams with the setup
Old Jan 5, 2012 | 06:17 AM
Threads's Avatar
This!
If you have a little time before you make your decision, you can follow my thread here: https://my350z.com/forum/forced-indu...-v3-setup.html
I'm running the 928M impeller with the 928M 2.62 pulley. I should be getting some results soon.
Old Jan 5, 2012 | 06:27 AM
Exemption's Avatar
Exemption
Originally Posted by Threads
This!
they make a 2.62 pulley??
hm i am very interested in this thread
Old Jan 5, 2012 | 06:54 AM
Threads's Avatar
I believe they also make a 2.75 pulley. http://www.928motorsports.com/parts/6ribpulley.php
You might want to read through my entire thread. Or at least until the convo starts/ends regarding the issues I had with my blower's trim and the 928M impeller. Really good info in there that I wish I had before ordering.
Old Jan 5, 2012 | 08:26 AM
tonyzS/C03's Avatar
tonyzS/C03
https://my350z.com/forum/forced-indu...injectors.html
read that thread... hes running your set up and more and makes phenominal power
Old Jan 5, 2012 | 08:58 AM
OldManZ350's Avatar
OldManZ350
Who's Setup I'm I Running?
I have an Old Style V2- SC trim Blower, I DO NOT have a 928 Impeller.
Old Jan 5, 2012 | 09:48 AM
tonyzS/C03's Avatar
tonyzS/C03
sorry about that, just knew that you were running a stock bottom end and a Vortech making good power...
Old Jan 5, 2012 | 10:24 AM
05Z33's Avatar
05Z33
Before the impeller I made 350 whp on a low reading mustang dyno. One week prior I made 400 whp on a dj dyno with the 2.87 on a 3.12 tune. After the impeller I made 385 whp on the mustang dyno, I never made it back to the dj dyno after that though. I have full bolt-ons including headers but no cams. I'll be installing a 31x12x4 intercooler in the coming weeks and will post a before and after dj dyno results.
Old Jan 6, 2012 | 12:06 PM
jpc350's Avatar
jpc350
Do you know the before and after Tq #'s with the impeller mod.?
Old Jan 6, 2012 | 12:34 PM
05Z33's Avatar
05Z33
Just to make a correction on the before and after dyno numbers, 332whp and 273tq before impeller and 375whp with 319tq after. This was on the mustang dyno. Also the tq curve was a little bit fatter with the impeller.
Old Jan 6, 2012 | 01:05 PM
jpc350's Avatar
jpc350
Really significant increase. About 17 %. Fatter or flatter?
Old Jan 7, 2012 | 07:07 AM
05Z33's Avatar
05Z33
Here is the before and after tuned mustang dyno results.
Old Jan 7, 2012 | 07:39 AM
jpc350's Avatar
jpc350
Outstanding improvement...Best cost effective mod for Vortech powered cars...Let us know how the I/C swap does..Thanks
Old Jan 7, 2012 | 10:18 AM
Exemption's Avatar
Exemption
thank you gentlemen for all the great info! with both upgrades and cams i am expecting 430 at the wheels? that will be more than enough for me.
Old Mar 23, 2013 | 11:34 PM
TSG-Z's Avatar
TSG-Z
I currently have the 2.87 pulley and looking to order the 928 impeller this week. However, I have the Forged shortblock so I'm looking to be somewhere in the mid 500whp.
Old Mar 24, 2013 | 07:08 AM
Threads's Avatar
Without knowing more about your setup, I think you're going to need a smaller pulley (or a bigger crank pulley) to get you mid 500whp with just the 928 impeller.
Calinismo350z
Sep 14, 2015 04:04 PM
Quamen
Jan 30, 2009 01:18 PM
