Throttle body issues?
Old Feb 18, 2013 | 09:03 AM
EugeneC7152's Avatar
EugeneC7152
bump. Any other advice guys? I still have the question of whether or not the TB should be fully shut at idle or not. thanks again.
Old Feb 18, 2013 | 10:32 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
why would your tb be fully shut at idle?
Old Feb 18, 2013 | 02:41 PM
EugeneC7152
Don't know. I was wondering if maybe the IAC would bypass it. It is fully shut at idle though. I'm guessing the TB is the problem then?
Old Feb 20, 2013 | 06:26 PM
EugeneC7152
bump
Old Feb 20, 2013 | 10:19 PM
amr_electron's Avatar
amr_electron
Did you check the throttle body voltages as per the service manual ?
Try to run this test & see what voltage you will get, You will need a digital voltmeter, Cipher can read the both sensors voltage also,
350z82
Oct 1, 2015 06:25 PM
