Making power, No smoke in the exhaust, but coolant issues
Old Feb 16, 2012 | 04:15 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Originally Posted by ace32x
but wouldnt it smoke and have a loss of power if that was the case? and also there would be oil in the coolant or vice versa?
I never had any of those symptoms and i also had a clean compression check. In fact the car made 733 WHP on a Dyno Dynamics with the bad headgasket lol
Old Feb 16, 2012 | 05:57 PM
str8dum1's Avatar
str8dum1
that was pushing water with an unsleeved block where the stock bore was actually shifting causing water to get pushed. not your issue.
reading through an old post and came across this, that describes my issue to a T. except i have a koyo rad and a new koy radiator cap that we just put in. Do i need a larger overflow maybe?
because it doesnt do it the first pull, usually the second or third after the overflow is already full.
Old Feb 16, 2012 | 06:01 PM
Eno's Avatar
Eno
Sorry I can't contribute anything but ace I sure hope it gets sorted out. You going over this with intec or is it another shop helping you out?
Old Feb 16, 2012 | 06:08 PM
rcdash's Avatar
rcdash
Yea the tstat is opening and fans are coming on. And the temp is staying fine it hasn't been going over normal operating temps it just pukes out coolant after the overflow gets full, its good for 2 runs on the dyno before it fills and then it just pukes out. It goes back down though after it idles for a bit but during the process air is getting in somewhere
I really think the HG is toast. Sorry. You can ask your engine builder. I would. Communication and documentation is going to be important - best to take this offline for resolution. Good luck.
Old Feb 16, 2012 | 06:30 PM
ace32x's Avatar
ace32x
good friends with him im not worried about him trying to screw me on it just trouble shooting at this point.
it does look like the HG or head is having an issue though. pressure bled it tonight and kept it below -20hg when i drove around the block and it still filled the overflow
ace32x's Avatar
ace32x
and that is interesting lol ^
Old Feb 16, 2012 | 06:39 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Everything you wrote describes my head gasket failure. All of the pressure test were fine, no coolant in the oil still made lots of power but every time I got into the boost it pushed coolant.
Sad to say but I think you HG is done or if your sleeved it may have dropped a hair
Old Feb 17, 2012 | 03:17 AM
djtimodj's Avatar
djtimodj
I had a problem with coolant mate, I'm on the same turbos as you and I was boiling coolant when I shut the car off which was making air pockets in the coolant system. This caused me to puke coolant and over heat.
Car still made good power etc. I had to fit a new custom colant bleed system and I've not had any problems since then. Might not be your problems but get the car hot and shut it off and listen round the manifold turbo area for gurggling noise etc.
Hope you sort it.
Old Feb 17, 2012 | 07:28 AM
ace32x's Avatar
ace32x
Hope you sort it.
problem seems to be getting worse, looking more like a HG now, bubble bleed it then pressure bled it last night and drove it around a bit never got it over -40hg and it still filled the overflow and got an airpocket in somehow. Ran fine for 15 mins before the airpocket got in though. and there was a little residue in the oil cap. Odd thing is its not coolant in the oil it looks like methanol
Chris350z03
Oct 8, 2023 07:19 PM
allmycarsdie
May 13, 2016 04:38 PM
smithmt3
Sep 11, 2015 08:25 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
