turning up the idle
Old Feb 24, 2012 | 05:14 PM
sandstrom.carl's Avatar
sandstrom.carl
Default turning up the idle
i heard to reduce the noise on the supercharger (that knocking noise) turning up the idle helps, my question is how do i do this?
Old Feb 24, 2012 | 05:39 PM
binder's Avatar
binder
if you have anything but a 2004.5 you can use cipher cable to raise it to 900rpms. Osiris flash will also allow an adjustment.
Old Feb 24, 2012 | 05:42 PM
konrad's Avatar
konrad
so 05 rev up I can bump it up with just the cipher ?? no need for reflash?
Old Feb 25, 2012 | 02:39 AM
str8dum1's Avatar
str8dum1
no, only non-revups can use cipher. ANything newer, you must buy the full Uprev reflash to adjust idle
Or just drill a hole in your throttle body plate for free.
Old Feb 25, 2012 | 04:10 AM
djamps's Avatar
djamps
Some throttle bodies have an idle screw. Worth checking out.
Keep in mind without a reflash you will have to re-raise the idle every time your battery is disconnected or ECU reset.
loudtoyz
Apr 6, 2023 04:52 AM
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
