Vortech V3 build begins
Old May 18, 2012 | 02:33 PM
  #61
unvmyg35's Avatar
unvmyg35
Originally Posted by lillong1991
it would throw off the tune a little bit and also i would then have to pay another grand to get the car re-tuned. so im not sure whats gonna happen with the pulley. if i get a deal on the retune then i will put the custom pulley on.
Wow, $1k for a retune seems outrageous! Im lucky if I even pay $200 for a retune. Nice numbers by the way!
Old May 19, 2012 | 11:15 PM
  #62
Nismomonkey's Avatar
Nismomonkey
Holy powerful car. This thread has made me reconsider the capability of SC motors.
Old May 20, 2012 | 03:57 PM
  #63
Crasez's Avatar
Crasez
Now for the million dollar question - - can you get to the V3 supercharger oil dipstick to check the level from under the hood of the car.
I can hardly reach the dipstick from the open hood of my car and to really check the oil level or change the supercharger oil on my V3, I pretty much have to remove the inner wheel well on the front/ drivers side.
Does your setup have the same problem?
Old May 21, 2012 | 08:31 AM
  #64
lillong1991's Avatar
lillong1991
Originally Posted by 350zhp306
Congrats on your numbers......very good numbers for a stock block. Using 3.125 pulley? How much boost?
yes using the 3.125 pulley and it hit 12.5psi at 7200rpms on the dyno but when im running it on the street the highest i have seen is 9psi.
yeah its expensive but i havent seen another Z on here that came within 15whp of my car with the same mods.
yeah I have this problem, however im just gonna have frank change my oil when it needs to be changed.
Old May 21, 2012 | 10:22 AM
  #65
Crasez's Avatar
Crasez
What kind of rpm's do you need to have the engine winding before you go from vacuum to 0 and then to positive boost on your AEM boost gauge?
I seem to drive around in vacuum well up to 2500 rpm then the gauge sits at zero for a while and I only start to really see boost at around 3500 - 4000 rpm.
Since I have never had a supercharger on this or any of my cars previously I'm just curious if that is typical for yours too as we both are running the 3.125 pulley on a V3 Vortech.
I don't often wind my engine much above 6500 rpm and at that rpm I'm only showing about 5 or maybe 6 lbs. of boost.
Is your car and tune similar?
Thanks!
Old May 21, 2012 | 11:24 AM
  #66
lillong1991
Thanks!
My car stays in vacuum pretty much all the time no matter the rpms. the only time it will build boost is if i want it to. for instance it will only make positive boost if i put the gas pedal on or close to the floor. but when i do this it makes boost instantly. I love this set up, so much more reliable for the car.
Old May 21, 2012 | 11:42 AM
  #67
str8dum1's Avatar
str8dum1
it will only build boost based on load and rpm. The bypass valve does not close until there is enough load on the engine to bring the vacuum up to 3-4" Hg or less.
Once that closes, boost is 100% related to rpm. So it wont make boost instantly unless you have enough rpms.
I think i had ~2psi at 3200 rpms. I posted impeller rpm vs boost charts for various pulley combinations in some of my older supercharger threads. That way you can predict exactly how much boost you will at a given rpm for any pulley setup.
Old May 22, 2012 | 04:11 AM
  #68
Crasez's Avatar
Crasez
Thanks for the feedback!
Much appreciated.
Old May 22, 2012 | 04:04 PM
  #69
Crasez's Avatar
Crasez
I was also curious about where you found room to mount your oil catch can?
I have a Mishimoto piece that looks similar to yours and I don't see too many options for where to mount it that running the hoses wont be problematic.
Old May 22, 2012 | 06:28 PM
  #70
lillong1991
we just ditched it, there was absolutely no room to mount it anywhere. it was too big and wasnt gonna do much if anything at all.
Old May 22, 2012 | 07:14 PM
  #71
unvmyg35's Avatar
unvmyg35
I mounted my mishimoto can behind the coolant res. Check it out.
Old May 22, 2012 | 07:18 PM
  #72
unvmyg35's Avatar
unvmyg35
I keep forgetting im on 350Z site! Not sure how much difference is the engine bay from the G.
Old May 22, 2012 | 07:33 PM
  #73
Ruthless18x's Avatar
Ruthless18x
I figured out how to mount my ARC V2 in the center off the rad support. Could prolly mount any of them there, but might help if you have a aftermarket fan shroud.
Old May 22, 2012 | 07:38 PM
  #74
djamps's Avatar
djamps
Not to jack your thread, but do you mean 400tq on DynoJet or 400tq on DynoDynamics? There was a recent member on the forum that pushed his Vortech'd stock motor and it finally gave out. He was pushing approx 440whp/394tq on DynoDynamics.
FYI at Hill's Garage, Frank's DynoDynamics is calibrated to output DynoJet numbers. Although it's not exact (it appears to read higher than DynoJet in my experience) there is technically no 'conversion' needed with their dyno.
Old May 22, 2012 | 08:47 PM
  #75
OldManZ350's Avatar
OldManZ350
This is what I did...
Attached Thumbnails Vortech V3 build begins-p1010009.jpg   Vortech V3 build begins-p1010012.jpg
Old May 23, 2012 | 05:24 AM
  #76
Crasez's Avatar
Crasez
Thanks for the feedback on the catch can locations.
I just took a look again on my car and I think the Mishimoto can is just too big to work in my car with the Vortech and everything else packed in there(that's why I bought their smaller size catch can unit which I thought would work).
I'm going to see if I can pick up an ARC (preferably version 1) unit if someone decides to part out their car.
Thanks again for the feedback.
Old May 23, 2012 | 09:18 AM
  #77
lillong1991
^yeah not too much room in our engine bay
Old May 23, 2012 | 09:19 AM
  #78
lillong1991
Frank told me that their dyno reads exactly 11% higher then a different type of dyno, i do not recall what brand he said though.
Old May 23, 2012 | 10:38 AM
  #79
str8dum1's Avatar
str8dum1
i believe he told me it was exactly 7.43% higher when the humidity is under 83.7%
Old May 23, 2012 | 12:16 PM
  #80
lillong1991
Cant tell if serious... haha
