VQ35HR Custom Rear Mount Turbo
Old May 10, 2012 | 03:45 PM
xslangx's Avatar
xslangx
Talking VQ35HR Custom Rear Mount Turbo
Ok Just a few quick questions before I finalize this
Im going to be running about 6 psi on a GT35 w/ anti surge just on the wastegate spring.
As for oiling I am thinking of running a seperate trunk tank of about 2-3 quarts with an inline oil pump for feed and oil pump for return, will an external cooler be necesarrY?
I figure with the size of the GT35 and the fact its under the car the temps shouldnt get to crazy...
I dont have crazy power goals but a few main questions
How will I deal with crankcase pressure? Any links will be very helpful..I absouletely HATE crank case pressure and it has caused me many problems on my past turbocharged projects...
What fuel mods will I need, are larger injectors sufficient? Any links to tried and true ones will be godlike
6 Psi on a Gt35 should net me around 400whp Correct? I am shooting for daily drivability and RELIABILITY!!!
Old May 10, 2012 | 04:12 PM
str8dum1's Avatar
str8dum1
1. crankcase pressure should not be an issue, even with the stock PCV system. not sure why you had such a problem with it in the past
2. you will need injectors and fuel pump at the bare minimum
3. boost is just the measure of the amount of air not getting into the engine. if you have an efficient setup, you'll make 400whp easily.
Why a gt35 though, they use that small of a turbo on 2L hondas.
Old May 10, 2012 | 04:21 PM
xslangx's Avatar
xslangx
Stock PCV system is ok for 6-8 psi??
I was running 26 psi on a volvo 5 cylinder in the past...
any reccomendations on a turbo?
Old May 10, 2012 | 04:22 PM
xslangx's Avatar
xslangx
also any links on a decent injector combo / fuel pump ?
Old May 10, 2012 | 04:27 PM
djamps's Avatar
djamps
I run 10psi on stock PVC without any problem. That said pressure could be a problem at any PSI if your engine has excessive blow by. Just throw in a breather and a catch can setup if you are worried.
Old May 10, 2012 | 04:33 PM
Frosty87's Avatar
Frosty87
For 400hp a walbro 255 and 440 cc injectors should be okay
Old May 10, 2012 | 04:35 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Let me know if you need fuel support. I have 550cc, 750cc injectors with pigtails (plugn' play), and 340lph fuel pumps available. Gives you a lot of room to grow if you decide to take that route.
You will also need this with your fuel pump:
http://shop.cj-motorsports.com/CJM-F...CJM370zFPI.htm
Old May 10, 2012 | 04:37 PM
str8dum1's Avatar
str8dum1
personally, i'd run
T4 Precision 6766 with a 0.81 AR turbine housing and HP compressor cover.
ID1000 injectors on a walbro 485 pump.
good sized turbo that will work great on the street and a fuel system with lots of headroom.
Old May 10, 2012 | 07:31 PM
xslangx's Avatar
xslangx
personally, i'd run
To much injector, will run like ****..
Im looking for a turbo that I can get CHEAPLY preferably a ebay knockoff
I live in a terrible neighborhood and i dont want to risk getting a 1000$ turbo stolen, I want a cheap knockoff
Old May 10, 2012 | 07:50 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Cheap and Turbo don't mix... you know that already. I'm running a Supercharged HKS GT kit and this is my fuel list:
600cc DW
225 Walbro
CJM Stage 0 FRS
I have absolutely no fueling issues.
Old May 10, 2012 | 08:47 PM
R350Zz33's Avatar
R350Zz33
600cc DW
225 Walbro
CJM Stage 0 FRS
theres a guy on youtube that runs a ebay turbo on his dsm he did port the wastegate thing to make it open better but he has 0 problems with the turbo he just blows the end tanks on his all intercooler. its all in the tune
Old May 10, 2012 | 08:51 PM
Flo-ridaZ33
Maybe that instance and I've seen plenty of Ebay kits blow up... more than I want to admit. You can make any car fast but what you pay for is longevity.
Old May 10, 2012 | 09:30 PM
350Z400rwhp's Avatar
350Z400rwhp
Fast, cheap, or reliable: You can only pick two
Old May 10, 2012 | 11:22 PM
R350Zz33's Avatar
R350Zz33
they blow up due to the restrictions and people running them full out cause they know if i blow it its 300 bucks not the 2 grand a name brand turbo would cost
Old May 11, 2012 | 12:07 AM
R350Zz33's Avatar
R350Zz33
http://youtu.be/-OI7l4RdQDc
this guy runs ebay 20g he is crazy smart watch his blue print videos
Old May 11, 2012 | 06:47 AM
str8dum1's Avatar
str8dum1
too much injector only if you have a retard tuning the car. My 2000ccs run like stock. my 1200s were even easier to dial in.
but since you want cheap as possible, , ya just buy any ebay turbo, ebay wastegate, and BOV and it wont even matter.
Old May 11, 2012 | 09:02 AM
xslangx's Avatar
xslangx
Ebay turbos are more than sufficient, Ive ran them plenty of times...
Cheap doesnt mean shitty, It means being a smart buyer. I usually buy an Ebay knockoff of a garret and get the 190$ GARRET rebuild and vwallah, garret turbo for 320$
600cc's sound perfect for my application, just a walbro and the adapter that was posted earlier??
Im going to tune via OSIRIS uprev tuner, Ive heard good things
As for the oiling issue on the turbo, I was thinking of running a standalone tank with 2 inline pumps to keep the oil flowing...but my question is will a oil cooler be necesarry? I figure a turbo of that size + the fact its under the car I shouldnt..
what are your thoughts??
as for turbo size Im aiming for a garret so I can get a knockoff
do you truly believe that a rear mounted GT35 is to small? That doesnt make sense to me its a fairly large turbo compressor and inducer wise... It seems that alot of the comments that are being made are from forum sheeple,
Im only aiming for about 400whp and I will be happy as long as its reliable ..
Ive kinda got my eyes on a precision PT6776HPS its only a grand and its a nice turbo...similar to GT35 any thoughts?
Old May 11, 2012 | 09:07 AM
xslangx's Avatar
xslangx
PS Im avoiding supercharging because i want TORQUE I hate torqueless motors
Old May 11, 2012 | 09:13 AM
abushong504's Avatar
abushong504
If you want true reliability don't turbo the Z.
If you want more reliability, don't "cheap out" on main parts of the kit.
Blowing a cheap turbo may not be expensive, but messing up the motor is a bit more. Especially when you could of spent a few extra hundred dollars on something from get-go.
Just my .02
Just like str8dum1 said, my ID2000's idle like stock as well
Old May 11, 2012 | 09:15 AM
ace32x's Avatar
ace32x
i run 1000's with no issues what so ever idles great fires right up with a tiny bit of feathering. why do you ask for advice then try and tell some one who is experienced in the matter off? for your power goals a 1000cc set up may be a tad big but i wouldnt go any smaller than 850's. with the tuning options available theres no reason not to have some head room
